Community Member
Private Lines
I have one cluster with two gateways, there is a qsig connection to NORTEL system, everything works i have 136 ports FXO i need to connect a analog lines from CO as private lines in some Phones.
Plsz if any body have a good senario with explelination and configuration file from cisco router, and if we have to configure the gateway as h323 or mgcp.
thanks
1 ACCEPTED SOLUTION
Community Member
Re: Private Lines
Hi Ali,
I am putting only H.323 configuration as personally its faster than MGCP in these kind of situations.
For Inbound configuration:
Identify the voice-port where line terminated and configure PLAR to send incoming call directly to user for example with extension 101
voice-port 0/0/0
connection plar opx 101
For Outbound configuration:
Requires configuring CoR in H.323 gateway, match outbound call with calling extension and apply CoR to only see outgoing pattern containing the appropriate voice-port to exit
dial-peer cor custom
name user101
dial-peer cor list user101
member user101
dial-peer voice 101 voip
corlist incoming user101
destination-pattern 101
session target ipv4:
dial-peer voice 1101 pots
corlist outgoing user101
destination-pattern 9T
port 0/0/0
forward-digits all
The CoR configuration makes sure that only dial-peer 1101 is seen for outgoing calls starting with 9.
Hope this helps.
Pratik
1 REPLY
Community Member
Re: Private Lines
Hi Ali,
voice-port 0/0/0
name user101
member user101
port 0/0/0
forward-digits all
Hope this helps.
Pratik
147
