Private Number cant get through
I've got a strange problem ringing DDIs.
I have callmanager 4.1(3) and a h323 gateway.
Under normal circumstances I can ring the number fine. But if I set my mobile phone to not present my number I cannot ring the DDIs. All I hear is a dialtone. Call is hitting the router ok. I just see connect and then a disconnect message straight away.
This is also the same when ringing the DDI from a landline that has their number blocked.
I know this is an odd one but if anyone has any idea......
Michael
Hall of Fame Super Gold
Re: Private Number cant get through
I think you're using H323 to the GW correct?
Please send router config relative to voice.
Watch out because if somebody has found the "feature", you can be exposed to toll fraud.
I forgot to put in the incoming called number . command on the pots dial peer. Working ok now
Probably in the same DP you had destination-pattern with direct-inward-dial and that made a match as long a calling number was present. That's why I had requested the config.
Please remember to rate useful posts with the scrollbox below!
141
