Community Member
Pro's and Con's of moving Call Manager to VM Ware?
I'm a bit old school, I like to have my voice components separated and on it's own hardware.
For those of you that have made the migration or are considering it, what are the upsides and downsides?  Any unique problems encountered on VM Ware?
TB
Everyone's tags (1)
1 REPLY
Considering that 10.X is
Considering that 10.X is allowed only on ESXi and not on baremetal, you have no option but to go new school if you have any intentions of keep working with Cisco UC.
As for the PROs/CONs of virtualization, you can google that up, I'm sure there are hundreds of pages explaining the PROs and CONs of it.
In my opinion, less rack space, less heat units to care about, less switch ports, and all of the ESXi features that are enabled if you have vCenter (vMotion for example)
java
if this helps, please rate
www.cisco.com/go/pdi
77
