06-08-2014 04:10 AM - edited 03-16-2019 11:02 PM
Hi everyone, I have a problem on the customer's cp6921 ... I would like to enable the ForwardAll softkey on the user device to the 2nd line under CUCM 7.1.5. I have found out the workaround but as soon as I reach the last step and configuration options, have an error message on the web page (" requested resource Webdialer is not available"). I have not yet figured out if it is the correct path, but I can not continue ... help please!
06-08-2014 05:36 AM
Hello!
Have you already tried to restart Cisco WebDialer Web Service in Feature Services?
Kirill
06-08-2014 03:41 PM
no, not yet ... in fact I did not know this feature
06-10-2014 11:34 AM
Can not seem to find this feature on my server.
06-10-2014 11:38 AM
It's under Unified Serviceability->Tools->Control Center- Feature Services->Select publisher node in the Server dropdown.
06-10-2014 11:49 AM
Ok, it's deactivated...I will ask my supervisor if possible activate it.
What is its role as specific?
06-10-2014 11:52 AM
Usually it's used for things like Click To Call applications. I don't think it should be necessary for this though. Can you send a screenshot of how you're getting to this? My user webpage works fine to set the forward all.
06-08-2014 03:39 PM
06-09-2014 11:58 AM
Can you attach a screenshot?
06-10-2014 11:27 AM
06-10-2014 11:32 AM
What are you clicking to get to that page? Did you try restarting the Web Dialer service already?
06-10-2014 11:40 AM
I am clicking the only field with info, the address book on the user options...
how can I restart it?
06-10-2014 01:36 PM
How Brian has already said: Cisco Unified Serviceability->Tools->Control Center- Feature Services->Select publisher node in the Server dropdown...then press "Go" button and find Cisco WebDialer Web Service under CTI Services, check it and click Start/Restart ("Play" button).
Kirill
