Problem Adding New Phone Types
Hello All,
First off a little info, I got thrown into this project after having done one CCME/CCUE install, so I am a little behind the learning curve.
I have UCM 6.0.1 installed and I am trying to add phone loads/firmware for the 7945 phone. I downloaded the loads/firmware from the site, went to the OS Admin and installed them. It gave me a Install Successful screen and everything. So I go to UCM and try to add the new phone... no 7945 listed. So I figure services have to be restarted, I do so. Still no new phone...
So am I missing a step to load a new Phone Type or am I just being dumb?
Thanks for the help.
-epoteet55
Hall of Fame Super Red
Re: Problem Adding New Phone Types
Hi Evan,
No worries .. this gets confusing :) When you don't find the IP Phone model listed in the Device defaults you can either install the required Device Pack (which adds the Firmware as well) of upgrade to a supported later CCM Version. Here is the device Pack for the 7945 and CCM 6.0
6.0(1) cmterm-devicepack6.0.1.1102-1
From these release notes;
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7975g/firmware/8_3_2/english/release/notes/75832.html
Hope this helps!
Rob
Hi Rob,
Thanks for that info! I was experiencing the same issue and right now I'm able to register my 7945 =D
I had to download and install this device pack for CM 6.0.1:
cmterm-devicepack6.0.1.2116-1.cop
I read in the ReadMe file, that this one supports the 7945/65/75 firmwares.
5 for your post friend!
Best Regards,
-- adrián.
Hi Adrian,
You are most welcome :) Glad to be of some small help!
Take care,
Rob
279
