Community Member
Problem between 6500 and voice module comunication
I'm configuring a Cisco Comunication Media Module on Cisco 6500. I have this module on slot 3 hence i must configuring gigabitethernet 3/1 on router, I do next:
1. enable
2. configure terminal
3. interface gigabitethernet 3/1
4. switchport
5. switchport access vlan 102
6. no shutdown
7. end
Next step i configure on gateway gigabitethernet next way:
1. enable
3. interface gigabitethernet 1/0
4. ip address 10.0.68.218 255.255.255.0
5. h323-gateway voip interface
6. h323-gateway voip bind srcaddr 10.0.68.218
I configure ip subnet-zero and
ip route 0.0.0.0 0.0.0.0 10.0.68.1
*10.0.68.1 corresponding to HSRP interface on VLAN 102 with network 10.0.68.0 255.255.255.0
Problem?? When i do sh ip route gw doesn't show static route 0.0.0.0 and with ip subnet-zero doesn't show in sh run. CDP is enable but nothing appears.
I have a 4500 series with voice module and the method is the same and works fine but with 6500 no.
Any ideas???
Thanks a lot
Re: Problem between 6500 and voice module comunication
i think ur config on the CMM should somthing liek
CMM1(config)#int gigabitEthernet 1/0
CMM1(config-if)#ip address 172.21.54.89 255.255.255.128
CMM1(config-if)#no shutdown
CMM1(config-if)#ip default-gateway 172.21.54.5
also check this link
http://www.cisco.com/en/US/products/hw/modules/ps2706/products_configuration_example09186a0080837b12.shtml
Community Member
Thanks for response!
I knew this link but is not my scenario, in this example on router has 1 gi and 4 fast on CMM module( as same as me) but on CMM module i've only on gi and zero fast.
The CMM provides Layer 2 forwarding only; if a packet needs to be Layer 3 routed, the packet is
forwarded. Therefore, you must enable ip routing and specify a static default route to the gateway
try to put in global config mode:
ip routing
Community Member
Hi!!,
i tried with ip routing wihtout results. i've upload my gw config in this config see that doesn't appear ip subnet-zero but i'ver load in.
And this is my "sh ip route", notice that my default route doesn't appear.
GW#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
C 127.0.0.0/8 is directly connected, EOBC0/0
the config mostly sounds good !
by the way i havt seen
ip classless
in ur config
try to add it
ABOUT ur Switch have u made SVI for vlan 102 ?
if not u have to as the following
interface vlan 102
ip address 10.0.68.1 255.255.255.0
no shut
if u didnt make this SVI the problem from here ofcourse
and let me know
good luck
Community Member
I don't understand you, SVI??
switchport voice interface?
I added ip classless but on sh run don't show it
ok cool
now
u HAVE PUT IN UR CMM
the 10.0.68.1 IP address of what?
this IP must be the IP addres of the vlan 102 interface according to your config
so in the
switch if u use 6500 with ios softeware
remove th hsrp now just check the connectivity with the switch first
and after removeing the hsrp
do the foloiwng
interface vlan 102
no shut
this will be the switch virtual interface SVI
and will be the default gateway for the CMM
if u do show ip route on the 6500 not the cmm
u see the 10.0.68.0 as a directly connected network
after that the show ip route on ur CMM acording to ur config should work
do it and let me know
good luck
did u try it ?
130
