Community Member
Problem calling to PSTN with MGCP gatway
For some reason I cant call to an outside line. After dialing an outside line I hear the busy tone.
debug mgcp packets and debug mgcp error are giving me the following response:
*May 1 09:36:22.439: MGCP Packet received from 10.0.1.100:2427--->
CRCX 113 BRI/S0/SU2/P0/1@VoiceGW MGCP 0.1
C: D000000001000040000000F50000000b
M: inactive
*May 1 09:36:22.439: Failed to create voice call leg, rc = -25!!!
*May 1 09:36:22.439: Following traceback is for INFO ONLY. -Traceback= 0x40A0E0A8 0x40A33EBC 0x40A27C8C 0x40A29BDC 0x40A0FE88 0x409D05CC 0x409D19A4 0x409D42C8 0x42110180 0x42110164
*May 1 09:36:22.439: MGCP Packet sent to 10.0.1.100:2427--->
400 113 Voice call setup failed-Incoming-Outgoing call collision
*May 1 09:36:23.455: MGCP Packet received from 10.0.1.100:2427--->
CRCX 10113 BRI/S0/SU2/P0/1@VoiceGW MGCP 0.1
M: inactive
*May 1 09:36:23.459: Failed to create voice call leg, rc = -25!!!
*May 1 09:36:23.459: Following traceback is for INFO ONLY. -Traceback= 0x40A0E0A8 0x40A33EBC 0x40A27C8C 0x40A29BDC 0x40A0FE88 0x409D05CC 0x409D19A4 0x409D42C8 0x42110180 0x42110164
*May 1 09:36:23
VoiceGW#.459: MGCP Packet sent to 10.0.1.100:2427--->
400 10113 Voice call setup failed-Incoming-Outgoing call collision
*May 1 09:36:23.463: MGCP Packet received from 10.0.1.100:2427--->
DLCX 114 BRI/S0/SU2/P0/1@VoiceGW MGCP 0.1
X: 1
S:
*May 1 09:36:23.463: MGCP Packet sent to 10.0.1.100:2427--->
250 114 already deleted connection
I use the following hardware:
MCS 7800 series Server with OS 2000.4.4aSR5
Callmanager 4.2(3)
Cisco 2851 ISR Router
- PVDM2-48 in slot 0
- VIC2-2BRI-NT/TE in HWIC 2
- VWIC-1MFT-E1 in HWIC 0 (not in use)
Anyone any idea's?
1 ACCEPTED SOLUTION
Community Member
Re: Problem calling to PSTN with MGCP gatway
BRI backhaul is not supported in 12.4 train on 2800 series. You need a 12.4T image.
http://www.cisco.com/en/US/products/ps6441/products_configuration_guide_chapter09186a0080541c9f.html
Community Member
The gateway config is as follows:
Building configuration...
Current configuration : 4382 bytes
version 12.4
service password-encryption
hostname VoiceGW
version 12.4
hostname VoiceGW
boot-start-marker
boot system flash:/c2800nm-ipvoicek9-mz.124-13b.bin
boot-end-marker
enable secret xxx
no aaa new-model
clock timezone CET 1
clock summer-time CET recurring last Sun Mar 2:00 last Sun Oct 2:00 1
no network-clock-participate wic 0
network-clock-participate wic 2
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.0.1.1 10.0.1.50
ip dhcp excluded-address 10.0.10.1 10.0.10.50
ip dhcp excluded-address 10.0.11.1 10.0.11.50
ip dhcp excluded-address 10.0.20.1 10.0.20.50
ip dhcp excluded-address 10.0.21.1 10.0.21.50
ip dhcp pool Data
network 10.0.1.0 255.255.255.0
default-router 10.0.1.1
dns-server 195.85.130.161 195.35.128.5
ip dhcp pool DataBedrijf1
network 10.0.10.0 255.255.255.0
default-router 10.0.10.1
option 150 ip 10.0.1.100
ip dhcp pool VoiceBedrijf1
network 10.0.11.0 255.255.255.0
default-router 10.0.11.1
ip dhcp pool DataBedrijf2
network 10.0.20.0 255.255.255.0
default-router 10.0.20.1
ip dhcp pool VoiceBedrijf2
network 10.0.21.0 255.255.255.0
default-router 10.0.21.1
isdn switch-type basic-net3
voice-card 0
dspfarm
dsp services dspfarm
username ap password xxx
archive
path flash:/archive/$h
maximum 14
write-memory
time-period 1440
controller E1 0/0/0
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.1
encapsulation dot1Q 1 native
ip address 10.0.1.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/0.10
encapsulation dot1Q 10
ip address 10.0.10.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/0.11
encapsulation dot1Q 11
ip address 10.0.11.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/0.20
encapsulation dot1Q 20
ip address 10.0.20.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/0.21
encapsulation dot1Q 21
ip address 10.0.21.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/1
ip address dhcp hostname CCM
ip nat outside
duplex auto
speed auto
interface BRI0/2/0
no ip address
isdn point-to-point-setup
isdn incoming-voice voice
isdn bind-l3 ccm-manager service mgcp
interface BRI0/2/1
no ip address
ip http server
no ip http secure-server
ip nat inside source list 1 interface GigabitEthernet0/1 overload
Community Member
Wait for Show ISDN Status, but depending on your provider, it's possible that the command "isdn static-tei 0" is missing under the interface BRI.
Community Member
I'm using dynamic tei's. So thats not the problem. My ISDN interface is up and running.
Community Member
Config Continued:
access-list 1 remark NAT
access-list 1 permit 10.0.1.0 0.0.0.255
access-list 1 permit 10.0.10.0 0.0.0.255
access-list 1 permit 10.0.11.0 0.0.0.255
access-list 1 permit 10.0.20.0 0.0.0.255
access-list 1 permit 10.0.21.0 0.0.0.255
control-plane
voice-port 0/2/0
compand-type a-law
cptone NL
voice-port 0/2/1
compand-type a-law
cptone NL
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 10.0.1.100
ccm-manager config
mgcp
mgcp call-agent 10.0.1.100 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface GigabitEthernet0/0.1
mgcp bind media source-interface GigabitEthernet0/0.1
mgcp profile default
dial-peer voice 20 pots
service mgcpapp
direct-inward-dial
dial-peer voice 21 pots
service mgcpapp
direct-inward-dial
gateway
timer receive-rtp 1200
banner exec ^C
You are logged on on $(hostname) via VTY $(line).
^C
line con 0
exec-timeout 0 0
logging synchronous
login local
line aux 0
line vty 0 4
private
login local
terminal-type monitor
scheduler allocate 20000 1000
ntp update-calendar
ntp server 192.43.244.18
end
Can you paste a sh isdn status
Community Member
I wont be at work till friday so I cant give you an exact show isdn status. But I can tell you that layer 2 is up and that layer 3 is under callmanager control. Thats what i remember since my last show isdn status.
And btw when there is a problem with my isdn interface, it wont register with CCM.
Community Member
Could it be that I need to register the PVDM's in CCM?
Or does the gateway automatically use its local PVDM's like CCM Express?
Community Member
Community Member
Ok, I'll try that tomorrow.
Community Member
This was indeed the solution to my problem!
Thanks!
Community Member
please can you post the runing configuration in your router ???
Community Member
I already did....
The only thing I changed later on was the following:
service mgcpapp
direct-inward-dial
port 0/2/0 <------------- Added this line
service mgcpapp
direct-inward-dial
port 0/2/1 <------------- Added this line
539
