Problem CCME codec
I dont know if is possible to do global codec modification inside my CCME presently i believe the default is
g711ulaw  which presently using. Can i do a global config to change this like to g729AB.
Everyone's tags (2)
VIP Super Bronze
Problem CCME codec
Yes you can.
Configure the codec you want under the phone..
eg
ephone 1
codec g729
or if you are using sip phone
voice register pool
codec g729
Please rate useful posts
"For the love of God is broader than the measure of man's mind And the heart of the Eternal is most wonderfully kind"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Problem CCME codec
Sure, you correct. tell me if i have if  i dont have all those codecs available on, do i have to upgrade my IOS??
Before i can have them?
VIP Super Bronze
Problem CCME codec
I dont think it is an IOS issue. What IP Phones are you using and what is the version of your CCME. Most cisco phones can support g729ab (g729 annex-b)
Problem CCME codec
I have issues with my SIP trunk
thats from my ccme<==>sip server. here is the config
dial-peer voice 20 voip
description connect to Softswitch
destination-pattern 7890T
session protocol sipv2
session target ipv4:192.168.50.1
dtmf-relay rtp-nte
codec g711ulaw
When i call to from my  cisco phone extension to my GSM number it rings twice after that call goes of
And when i debug using "debug ccsip media" this is what i have
Jun 24 15:17:51.755: //131/0ACD1405812F/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 192.168.1.1
Jun 24 15:17:51.755: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIReserveRtpPort: reserved port 17740 for stream 1
Jun 24 15:17:51.755: //131/0ACD1405812F/SIP/Media/sipSPIAddSDPMediaPayload: Preferred method of dtmf relay is: 6, with payload: 101
Jun 24 15:17:51.755: //131/0ACD1405812F/SIP/Media/sipSPIProcessRtpSessions: sipSPIProcessRtpSessions
Jun 24 15:17:51.755: //131/0ACD1405812F/SIP/Media/sipSPIProcessRtpSessions: No active streams.
Jun 24 15:17:51.759: //131/0ACD1405812F/SIP/Media/sipSPIProcessRtpSessions: sipSPIProcessRtpSessions
Jun 24 15:17:51.759: //131/0ACD1405812F/SIP/Media/sipSPIAddStream: Adding stream 1 of type voice+dtmf (callid 131) to the VOIP RTP library
Jun 24 15:17:51.759: //131/0ACD1405812F/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 192.168.1.1
Jun 24 15:17:51.759: //131/0ACD1405812F/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
Jun 24 15:17:51.759: //131/0ACD1405812F/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
        laddr = 192.168.1.1, lport = 17740, raddr = 0.0.0.0, rport=0, do_rtcp=FALSE
        src_callid = 131, dest_callid = -1, stream type = voice+dtmf, stream direction = RECVONLY
        media_ip_addr = 0.0.0.0, vrf tableid = 0
Jun 24 15:17:51.759: //131/0ACD1405812F/SIP/Media/sipSPIUpdateRtcpSession: No rtp session, creating a new one
Jun 24 15:17:59.483: //131/0ACD1405812F/SIP/Error/sipSPICheckSingleStreamCriteria: Codec negotiation failed on single stream
Jun 24 15:17:59.483: //131/0ACD1405812F/SIP/Error/ccsip_api_call_cut_progress: MediaNegotiation Failure - Send Cancel
Jun 24 15:17:59.483: //131/0ACD1405812F/SIP/Error/sipSPIAddPrivacyHeader: Orig Container is NULL...should have value
Jun 24 15:17:59.531: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIMatchRespToReqTran: Error in matching To header tags
Can someone advise me on this!!
VIP Super Bronze
Problem CCME codec
You need to send your config...and debug ccsip messages..
From the sample output it looks like a codec issue. But I cant tell why unless I see the debug and the sh run of your gateway
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Problem CCME codec
Here is the debug ccsip messages
Jun 25 05:49:19.793: //447/C8E71BA984DF/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 192.168.1.1
Jun 25 05:49:19.793: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIReserveRtpPort: reserved port 18856 for stream 1
Jun 25 05:49:19.797: //447/C8E71BA984DF/SIP/Media/sipSPIAddSDPMediaPayload: Preferred method of dtmf relay is: 6, with payload: 101
Jun 25 05:49:19.797: //447/C8E71BA984DF/SIP/Media/sipSPIProcessRtpSessions: sipSPIProcessRtpSessions
Jun 25 05:49:19.797: //447/C8E71BA984DF/SIP/Media/sipSPIProcessRtpSessions: No active streams.
Jun 25 05:49:19.813: //447/C8E71BA984DF/SIP/Media/sipSPIProcessRtpSessions: sipSPIProcessRtpSessions
Jun 25 05:49:19.813: //447/C8E71BA984DF/SIP/Media/sipSPIAddStream: Adding stream 1 of type voice+dtmf (callid 447) to the VOIP RTP library
Jun 25 05:49:19.813: //447/C8E71BA984DF/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 192.168.1.1
Jun 25 05:49:19.813: //447/C8E71BA984DF/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
Jun 25 05:49:19.813: //447/C8E71BA984DF/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
        laddr = 192.168.1.1, lport = 18856, raddr = 0.0.0.0, rport=0, do_rtcp=FALSE
        src_callid = 447, dest_callid = -1, stream type = voice+dtmf, stream direction = RECVONLY
Jun 25 05:49:19.813: //447/C8E71BA984DF/SIP/Media/sipSPIUpdateRtcpSession: No rtp session, creating a new one
Jun 25 05:49:19.813: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:789075697183@192.168.50.1:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.1:5060;branch=z9hG4bKE1AEE
Remote-Party-ID: "Raoul" <240>;party=calling;screen=no;privacy=off
To: <789075697183>
Date: Tue, 25 Jun 2013 05:49:19 GMT
Call-ID: D05287A9-DC9111E2-84E48911-59004C21@192.168.1.1
Supported: 100rel,timer,resource-priority,replaces
Min-SE:  1800
Cisco-Guid: 3370589097-3700494818-2229242129-1493191713
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1372139359
Contact: <240>
Expires: 180
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 277
v=0
o=CiscoSystemsSIP-GW-UserAgent 5126 6537 IN IP4 192.168.1.1
s=SIP Call
c=IN IP4 192.168.1.1
t=0 0
m=audio 18856 RTP/AVP 0 101 19
c=IN IP4 4192.168.1.1
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
a=ptime:20
VIP Super Bronze
Re:Problem CCME codec
This debug is incomplete. Pls send full debug..and your config. Attach them here
Sent from Cisco Technical Support Android App
Problem CCME codec
Jun 25 06:20:41.864: //458/2AA5BFB684F3/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 192.168.1.1
Jun 25 06:20:41.864: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIReserveRtpPort: reserved port 17522 for stream 1
Jun 25 06:20:41.868: //458/2AA5BFB684F3/SIP/Media/sipSPIAddSDPMediaPayload: Preferred method of dtmf relay is: 6, with payload: 101
Jun 25 06:20:41.868: //458/2AA5BFB684F3/SIP/Media/sipSPIProcessRtpSessions: sipSPIProcessRtpSessions
Jun 25 06:20:41.868: //458/2AA5BFB684F3/SIP/Media/sipSPIProcessRtpSessions: No active streams.
Jun 25 06:20:41.884: //458/2AA5BFB684F3/SIP/Media/sipSPIProcessRtpSessions: sipSPIProcessRtpSessions
Jun 25 06:20:41.884: //458/2AA5BFB684F3/SIP/Media/sipSPIAddStream: Adding stream 1 of type voice+dtmf (callid 458) to the VOIP RTP library
Jun 25 06:20:41.884: //458/2AA5BFB684F3/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 192.168.1.1
Jun 25 06:20:41.884: //458/2AA5BFB684F3/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
Jun 25 06:20:41.884: //458/2AA5BFB684F3/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
        laddr = 192.168.1.1, lport = 17522, raddr = 0.0.0.0, rport=0, do_rtcp=FALSE
        src_callid = 458, dest_callid = -1, stream type = voice+dtmf, stream direction = RECVONLY
Jun 25 06:20:41.884: //458/2AA5BFB684F3/SIP/Media/sipSPIUpdateRtcpSession: No rtp session, creating a new one
Jun 25 06:20:41.888: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.1.1:5060;branch=z9hG4bKF1C5F
To: <789075697183>
Date: Tue, 25 Jun 2013 06:20:41 GMT
Call-ID: 321FD1D7-DC9611E2-84F88911-59004C21@192.168.1.1
Min-SE:  1800
Cisco-Guid: 715505590-3700822498-2230552849-1493191713
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1372141241
Contact: <240>
Expires: 180
Content-Length: 277
v=0
o=CiscoSystemsSIP-GW-UserAgent 2027 4440 IN IP4 192.168.1.1
s=SIP Call
t=0 0
m=audio 17522 RTP/AVP 0 101 19
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
a=ptime:20
Jun 25 06:20:41.924: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Record-Route: <192.168.50.1:5060>
To: <789075697183>
CSeq: 101 INVITE
Contact: NSProxy <192.168.50.1:5060>
User-Agent: N-SOFT-UA-5.25.4 -RIN1-2939- www.n-soft.com
Allow: ACK, BYE, CANCEL, INVITE, OPTIONS, REGISTER, PRACK
Content-Length: 0
Jun 25 06:20:46.992: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <789075697183>;tag=JnT9nn7jSqLyqPDAMaD8A1msBK
CSeq: 101 INVITE
Content-Length: 0
Jun 25 06:20:46.996: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 183 Session Progress
To: <789075697183>;tag=GbQS3iZ3mXsJhLbXqp8BR8lCxO
CSeq: 101 INVITE
Content-Length:   222
v=0
o=- 1372141247 1372141247 IN IP4 192.168.50.1
s=anonymous
i= noinfo
c=IN IP4 192.168.40.1
t=0 0
m=audio 13550 RTP/AVP 101
a=ptime:20
a=sendrecv
a=silenceSupp:on - - - -
Jun 25 06:20:46.996: //458/2AA5BFB684F3/SIP/Error/sipSPICheckSingleStreamCriteria: Codec negotiation failed on single stream
Jun 25 06:20:46.996: //458/2AA5BFB684F3/SIP/Error/ccsip_api_call_cut_progress: MediaNegotiation Failure - Send Cancel
Jun 25 06:20:47.000: //458/2AA5BFB684F3/SIP/Error/sipSPIAddPrivacyHeader: Orig Container is NULL...should have value
Jun 25 06:20:47.004: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CANCEL sip:789075697183@192.168.50.1:5060 SIP/2.0
To: <789075697183>
CSeq: 101 CANCEL
Max-Forwards: 70
Timestamp: 1372141247
Reason: Q.850;cause=65
Content-Length: 0
Jun 25 06:20:47.012: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <789075697183>
CSeq: 101 CANCEL
Max-Forwards: 70
Content-Length: 0
Jun 25 06:20:47.020: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
To: <789075697183>;tag=1YLtlQVEAfAEtK5daELiIAqR5c
CSeq: 101 CANCEL
Content-Length: 0
Jun 25 06:20:47.024: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 487 Request Terminated
CSeq: 101 INVITE
Content-Length: 0
Jun 25 06:20:47.044: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:789075697183@192.168.50.1:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Jun 25 06:20:47.048: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIMatchRespToReqTran: Error in matching To header tags
Jun 25 06:20:47.048: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 CANCEL
Content-Length:
VIP Super Bronze
Problem CCME codec
This problem is from your service provider...Your provider is not selecting/sending any codec in the answer to your INVITE. The INVITE you sent has G711ulaw, but the answer from your provider doesnt have any codec. Please contact them and ask them why they are not offering you any codec...You can show the logs.
Problem CCME codec
wow
will get back to you
Problem CCME codec
Please can i do know the "line" which shows where the error is coming from?
VIP Super Bronze
Problem CCME codec
Here is the error..Thi is the 183 Session progress received from your ITSP..It has no codec in it.
Received:
CSeq: 101 INVITE
Content-Length:   222
v=0
s=anonymous
i= noinfo
t=0 0
a=ptime:20
a=sendrecv
658
