Community Member
Problem change language 7911 phone
I have to change the locale languages on my phone (7911,7945) with cme 4.1.
There isn't any problem with 7945 phone, but I'm not able to change the languages on 7911 phone.
This is my configuration:
tftp-server flash:apps11.8-2-2ES1.sbn
tftp-server flash:cnu11.8-2-2ES1.sbn
tftp-server flash:cvm11sccp.8-2-2ES1.sbn
tftp-server flash:dsp11.8-2-2ES1.sbn
tftp-server flash:jar11sccp.8-2-2ES1.sbn
tftp-server flash:SCCP11.8-2-2SR1S.loads
tftp-server flash:term06.default.loads
tftp-server flash:term11.default.loads
tftp-server flash:apps45.8-3-1-22.sbn
tftp-server flash:cnu45.8-3-1-22.sbn
tftp-server flash:cvm45sccp.8-3-1-22.sbn
tftp-server flash:dsp45.8-3-1-22.sbn
tftp-server flash:jar45sccp.8-3-1-22.sbn
tftp-server flash:SCCP45.8-3-2S.loads
tftp-server flash:term45.default.loads
tftp-server flash:term65.default.loads
tftp-server flash:/it-be-sccp.jar alias Italian_Italy/be-sccp.jar
tftp-server flash:/it-tc-sccp.jar alias Italian_Italy/tc-sccp.jar
tftp-server flash:/it-ipc-sccp.jar alias Italian_Italy/ipc-sccp.jar
tftp-server flash:/g3-tones.xml alias Italy/g3-tones.xml
no auto-reg-ephone
load 7945 SCCP45.8-3-2S
load 7911 SCCP11.8-2-2SR1S
max-ephones 58
max-dn 116
ip source-address port 2000
timeouts interdigit 3
user-locale IT
network-locale IT
time-zone 23
time-format 24
date-format dd-mm-yy
max-conferences 4 gain -6
call-forward pattern .T
call-forward pattern 0T
transfer-system full-consult dss
transfer-pattern 0T
secondary-dialtone 0
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn 1 dual-line
number 122
pickup-group 1
label Sb
name Sb
huntstop channel
ephone-dn 2 dual-line
number 123
pickup-group 1
label Sa
name Sa
huntstop channel
ephone 1
mac-address 0024.97A8.E4A6
ephone-template 1
type 7911
button 1:1
ephone 2
mac-address 0024.97A8.E0EB
ephone-template 1
type 7945
button 1:2
Hall of Fame Super Gold
Re: Problem change language 7911 phone
.jar file may be corrupt ?
Also try upgrading FW, like 8.3.x
Try a factory reset on the 7911, if still problems do "debug tftp events" to see if the commands are configured right and the phone actually requests the language file.
Community Member
I've tried to do a factory reset, but the result is the same.
I've attached the syslog message on the phone and this is the debug tftp event:
000153: Jul 2 10:19:55.926 CEST: TFTP: Looking for CTLSEP002497A8E0EB.tlv
000154: Jul 2 10:19:55.982 CEST: TFTP: Looking for SEP002497A8E0EB.cnf.xml
000155: Jul 2 10:19:55.986 CEST: TFTP: Opened flash:/its/SEP002497A8E0EB.cnf.xml, fd 7, size 1273 for process 3
000156: Jul 2 10:19:56.006 CEST: TFTP: Finished flash:/its/SEP002497A8E0EB.cnf.xml, time 00:00:00 for process 3
000157: Jul 2 10:19:56.654 CEST: TFTP: Looking for Italian_Italy/tc-sccp.jar
000158: Jul 2 10:19:56.658 CEST: TFTP: Opened flash:tc-sccp.jar, fd 7, size 71446 for process 3
000159: Jul 2 10:19:56.842 CEST: TFTP: Finished flash:tc-sccp.jar, time 00:00:00 for process 3
000160: Jul 2 10:19:58.962 CEST: TFTP: Looking for Italy/g3-tones.xml
000161: Jul 2 10:19:58.966 CEST: TFTP: Opened flash:g3-tones.xml, fd 7, size 1339 for process 3
000162: Jul 2 10:19:58.970 CEST: TFTP: Finished flash:g3-tones.xml, time 00:00:00 for process 3
Community Member
Ok,now is all ok.
You're welcome, please remember to rate useful posts.
