Problem connecting SIP Trunk to ISP
I am trying to connect my CME v9.1 (2921) with a SIP Trunk to my ISP.
Right now my connection is like this SCCP Phone --> CME --> FXO --> PSTN, the PSTN is connected using FXO ports, with 8 independent lines, but this lines are connected to 6 DLink Voip Telephone Adapters (DVG-5121SP), which connects to the ISP through a Ethernet RJ45 cable each. (everything works fine).
I would like to remove these VoIP Telephone Adapters, and i am trying to configure the SIP Trunk but it doesn't work.
First of all, I think i don't need CUBE (i don't have the licenses), i hope i am correct.
Second, i am configuring sip-ua, only with one user and password for one line, i am configuring this:
sip-ua
credentials username xxxxx password xxxxx
no remote-party-id
retry invite 2
retry register 10
retry options 0
timers connect 100
registrar dns:172.23.7.134 expires 3600
sip-server dns:172.23.7.134
host-registrar
dial-peer voice 105 voip
description Local Calls
destination-pattern 0[2-7].......
session protocol sipv2
session target ipv4:172.23.7.134
codec g711ulaw
voice translation-rule 3
rule 1 /23823867/ /4000/
voice translation-profile entrantes
translate called 3
dial-peer voice 106 voip
translation-profile incoming entrantes
incoming called-number 23823867
codec g711ulaw
dtmf-relay rtp-nte
no vad
but this doesn't work, i can't dial calls, nor receive them.
how could i test that everything is correct from my side?.
i issued the command debug ccsip messages, and obtain the log i am attaching..
i did this test with a SIP phone (i couldn't make it with a sccp phone, maybe that was the problem), with IP 172.16.164.90, which was registered to my CME (IP: 172.16.161.2), the dn number is 4105, i tried to call 045118106 (using dialpeer 105).
Contact: <sip:4105@172.16.164.90:3077>
To: <sip:045118104@172.16.161.2:5060> Contact: <sip:4105@172.16.164.90:3077>
hope somebody could help me with this or give me ideas of what i am doing wrong.
regards,
Juan Pablo
Hall of Fame Super Gold
You need a translation rule to route calls to extensions.
There are many posts on the subject, use the search funcion.
Hi Paolo,
thanks for your reply,
but i have this on my configuration:
translate called 3
codec g711ulaw
dtmf-relay rtp-nte
no vad
or this is a bad configuration?.
regards,
Juan Pablo
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_configuration_example09186a00808f9666.shtml
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
i tried several configurations but without success.
this is the debug ccsip messages,,
this is when i dial... but when i test a call from outside to the CME i didn't get any log..
is there a way i could know the problem is the ISP sip server, or something like that??. so i could talk to the ISP and tell them that the problem is their configuration..
on the logs there is a line that says:
Received:
SIP/2.0 500 Server Internal Error
this is my CME reporting the error? or the ISP SIP server reporting the error?.
regards,
Jul 22 01:55:24.171: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:045118106@172.16.161.2:5060 SIP/2.0
Via: SIP/2.0/UDP 172.16.164.90:1114;branch=z9hG4bK-d8754z-82780a6e1618f04d-1---d8754z-;rport
Max-Forwards: 70
Contact: <4105>
To: <045118106>
Call-ID: MDA4ZmM4MTIwOTk4MzA2ODgyYTdmODY5NjY3ODE0YWI.
CSeq: 1 INVITE
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE
Content-Type: application/sdp
Supported: replaces
User-Agent: 3CXPhone 6.0.20943.0
Content-Length: 408
v=0
o=3cxVCE 255171150 400780425 IN IP4 172.16.164.90
s=3cxVCE Audio Call
c=IN IP4 172.16.164.90
t=0 0
m=audio 40030 RTP/AVP 0 8 3 101
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:3 GSM/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=ptime:20
a=sendrecv
m=video 40028 RTP/AVP 34
a=rtpmap:34 H263/90000
a=fmtp:34 QCIF=1;CIF=1;SQCIF=1;CIF4=1;
a=sendrecv
Jul 22 01:55:24.179: //18248/9B973937813F/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <045118106>
Date: Mon, 22 Jul 2013 01:55:24 GMT
CSeq: 1 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-15.2.4.M2
Content-Length: 0
Jul 22 01:55:24.179: //18250/9B973937813F/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:045118106@172.23.7.134:5060 SIP/2.0
Via: SIP/2.0/UDP 172.25.3.84:5060;branch=z9hG4bK31F1663
To: <045118106>
Call-ID: 9B98721F-F1A811E2-81458DE9-8D33915@172.25.3.84
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 2610379063-4054323682-2168425961-0148060437
User-Agent: Cisco-SIPGateway/IOS-15.2.4.M2
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1374458124
Contact: <23823867>
Expires: 180
Max-Forwards: 69
Content-Disposition: session;handling=required
Content-Length: 347
v=0
o=CiscoSystemsSIP-GW-UserAgent 7398 5918 IN IP4 172.25.3.84
s=SIP Call
c=IN IP4 172.25.3.84
t=0 0
m=audio 17834 RTP/AVP 0 19
a=rtpmap:19 CN/8000
a=ptime:20
m=video 17836 RTP/AVP 34
b=TIAS:85000
a=fmtp:34 SQCIF=1;QCIF=1;CIF=1;CIF4=1;MAXBR=850
Jul 22 01:55:24.183: //18250/9B973937813F/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 172.25.3.84:5060;branch=z9hG4bK31F1663;rport=64861
To: <045118106>
CSeq: 101 INVITE
Content-Length: 0
Received:
To: <045118106>;tag=b88652ba
CSeq: 101 INVITE
Content-Length: 0
Jul 22 01:55:24.187: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:045118106@172.23.7.134:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Jul 22 01:55:24.187: //18248/9B973937813F/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 503 Service Unavailable
To: <045118106>;tag=3F00E2E4-F9B
CSeq: 1 INVITE
Reason: Q.850;cause=41
Content-Length: 0
Jul 22 01:55:24.199: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:045118106@172.16.1ex61.2:5060 SIP/2.0
Max-Forwards: 70
CSeq: 1 ACK
Content-Length: 0
Jul 22 01:55:35.363: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
VIP Super Bronze
You should contact your provider. They are disconnecting the call..
Received:
CSeq: 101 INVITE
Content-Length:
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
396
