Problem counters With FXO cart
omar_youn
I have Cisco Router 3945 with carts E1 and FXO. The version IOS is: c3900-universalk9-mz.SPA.152-2.T1.bin
The communication through E1 passed well without any problem. But I have some problem with FXO communication.
The problem that I have actually, when I start a call from IP phone to PSTN the counter displayed in the screen and begins calculating after that the user answer and he speak (for example, he told: ALLO).
If the user answers in this communication without speaking (told Allo) the counter don’t start in the IP phone.
My configuration FXO is:
voice class custom-cptone omar
dualtone busy
frequency 425 425
cadence 500 500
dualtone ringback
frequency 425 425
cadence 1000 4000
dualtone reorder
frequency 425 425
cadence 250 250
dualtone out-of-service
frequency 425 425
cadence 320 320
dualtone disconnect
frequency 425 425
cadence 500 500
voice-port 1/0/0
supervisory disconnect dualtone mid-call
supervisory answer dualtone sensitivity high
supervisory custom-cptone omar
supervisory dualtone-detect-params 67
no battery-reversal
timeouts interdigit 2
timeouts call-disconnect 0
timeouts wait-release 1
connection plar opx 5123
caller-id enable
Please, can you help me to resolve this problem?
Tanks in advanced,
Best Regards,
Omar
Actually there is no problem at all, the product is working as designed, as explained in my post above.
6 Replies 6
paolo bevilacqua
voice-port 1/0/0
no supervisory answer dualtone
Hi Paolo,
Thanks for your update.
When I enter the command "no supervisory answer dualtone" in voice port, the counter begain when I  dial the number in my IP phone (in the moment of the ring tone and before the user answer in thecall ).
Do you have any other idea?
Thanks a lot,
Best Regards,
Omar
There are only two options for two answer supervision on FXO ports:
1. voice-detection based answer supervsion, as per your original config (and it's working).
or
2. no answer supervision.
Choose one, or the other.
Please remember to rate useful posts clicking on the stars below.
HI Paolo,
Do you think that the problem is in the configuration of supervisory answer?
it's possible that the problem is lied in the configuration of supervisory custom-cptone?
what do you think?
Best regards,
Omar
Thanks Paolo,
I rate for 100% correct answer for you.
The customer doesn't accept this situation.
I will open a case with TAC.
Thanks again
