01-26-2014 10:10 PM - edited 03-16-2019 09:26 PM
Hi All ,
I have Problem with E1 in Cisco Call Manager , when outgoing call using E1 in phone ,status is always busy
here is the debug q931
Jan 27 06:04:13.459: ISDN Se0/3/0:15 Q931: TX -> SETUP pd = 8 callref = 0x008B
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839F
Exclusive, Channel 31
Called Party Number i = 0x80, '081381XXXXX'
Plan:Unknown, Type:Unknown
*Jan 27 06:04:13.495: ISDN Se0/3/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x808B
Cause i = 0x82AC - Requested circuit/channel not available
and when I check debug q921 here is what i got :
*Jan 27 06:02:30.311: ISDN Se0/3/0:15 Q921: User RX <- SABMEp sapi=0 tei=13
*Jan 27 06:02:31.311: ISDN Se0/3/0:15 Q921: User RX <- SABMEp sapi=0 tei=13
*Jan 27 06:02:32.311: ISDN Se0/3/0:15 Q921: User RX <- SABMEp sapi=0 tei=13
*Jan 27 06:02:33.311: ISDN Se0/3/0:15 Q921: User RX <- SABMEp sapi=0 tei=13
*Jan 27 06:02:34.271: ISDN Se0/3/0:15 Q921: User RX <- RRp sapi=0 tei=0 nr=13
*Jan 27 06:02:34.271: ISDN Se0/3/0:15 Q921: User TX -> RRf sapi=0 tei=0 nr=15
*Jan 27 06:02:34.311: ISDN Se0/3/0:15 Q921: User RX <- SABMEp sapi=0 tei=13
*Jan 27 06:02:35.311: ISDN Se0/3/0:15 Q921: User RX <- SABMEp sapi=0 tei=13
*Jan 27 06:02:37.311: ISDN Se0/3/0:15 Q921: User RX <- SABMEp sapi=0 tei=13
*Jan 27 06:02:38.311: ISDN Se0/3/0:15 Q921: User RX <- SABMEp sapi=0 tei=13
*Jan 27 06:02:39.311: ISDN Se0/3/0:15 Q921: User RX <- SABMEp sapi=0 tei=13
*Jan 27 06:02:40.311: ISDN Se0/3/0:15 Q921: User RX <- SABMEp sapi=0 tei=13
*Jan 27 06:02:41.311: ISDN Se0/3/0:15 Q921: User RX <- SABMEp sapi=0 tei=13
*Jan 27 06:02:42.311: ISDN Se0/3/0:15 Q921: User RX <- SABMEp sapi=0 tei=13
*Jan 27 06:02:43.311: ISDN Se0/3/0:15 Q921: User RX <- SABMEp sapi=0 tei=13
*Jan 27 06:02:44.271: ISDN Se0/3/0:15 Q921: User TX -> RRp sapi=0 tei=0 nr=15
*Jan 27 06:02:44.283: ISDN Se0/3/0:15 Q921: User RX <- RRp sapi=0 tei=0 nr=13
*Jan 27 06:02:44.283: ISDN Se0/3/0:15 Q921: User TX -> RRf sapi=0 tei=0 nr=15
*Jan 27 06:02:44.287: ISDN Se0/3/0:15 Q921: User RX <- RRf sapi=0 tei=0 nr=13
*Jan 27 06:02:44.311: ISDN Se0/3/0:15 Q921: User RX <- SABMEp sapi=0 tei=13
*Jan 27 06:02:45.311: ISDN Se0/3/0:15 Q921: User RX <- SABMEp sapi=0 tei=13
*Jan 27 06:02:46.311: ISDN Se0/3/0:15 Q921: User RX <- SABMEp sapi=0 tei=13
*Jan 27 06:02:47.311: ISDN Se0/3/0:15 Q921: User RX <- SABMEp sapi=0 tei=13
*Jan 27 06:02:48.311: ISDN Se0/3/0:15 Q921: User RX <- SABMEp sapi=0 tei=13
I wonder where is the problem , while my e1 status
ISDN Serial0/3/0:15 interface
dsl 1, interface ISDN Switchtype = primary-net5
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 1 CCBs = 0
The Free Channel Mask: 0xFFFF7FFF
Number of L2 Discards = 0, L2 Session ID = 10
Total Allocated ISDN CCBs = 0
and E1 is up
anyone kindly help ?
Solved! Go to Solution.
01-28-2014 11:52 PM
Believe me it's a provider issue.
Provider sends a RX, 'channel not available'. Provider has to tell you why they send this message. There must be a reason for it. And again, THEY send this message! Not you!
Several years ago I had a similar issue, and customer wanted to throw out Cisco, because provider says they are not blocking channels etc, finally customer wanted to sue provider, and then provider changed some equipment and all was solved.
And 1 year ago, with another customer, same issue. Provider says, they don't block channels, I told my customer, that it is a problem with the provider, and I can do nothing, and it's up to customer and provider.
After a week or so engineer from provider comes on site, does something and viola, it works! (a year without issues now)
Good luck!
Bye,
Jan
01-26-2014 10:16 PM
Hello Tommy
what is the status of the CIC? can you paste below below command?
show isdn status
show isdn service
show controllers E1 XXX
Br,
Nadeem
Please rate all useful post.
01-26-2014 10:26 PM
Hi Nadeem
here is the status
show isdn status
Global ISDN Switchtype = primary-net5
Layer 1 Status:
ACTIVE
Layer 2 Status:
Layer 3 Status:
sh isdn service
PRI Channel Statistics:
ISDN Se0/3/0:15, Channel [1-31]
Configured Isdn Interface (dsl) 1
Channel State (0=Idle 1=Proposed 2=Busy 3=Reserved 4=Restart 5=Maint_Pend)
Channel : 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0 1
State : 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 3 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
Service State (0=Inservice 1=Maint 2=Outofservice 8=MaintPend 9=OOSPend)
State : 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 2 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
show controllers e1
Applique type is Channelized E1 - balanced
No alarms detected.
alarm-trigger is not set
Version info FPGA Rev: 08121917, FPGA Type: PRK1
Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line.
International Bit: 1, National Bits: 11111
Data in current interval (323 seconds elapsed):
0 Line Code Violations, 43 Path Code Violations
26 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
34 Errored Secs, 8 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Data in Interval 1:
0 Line Code Violations, 170 Path Code Violations
74 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
101 Errored Secs, 29 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Data in Interval 2:
0 Line Code Violations, 165 Path Code Violations
98 Errored Secs, 27 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Data in Interval 3:
0 Line Code Violations, 168 Path Code Violations
74 Slip Secs, 1 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
100 Errored Secs, 29 Bursty Err Secs, 1 Severely Err Secs, 0 Unavail Secs
Data in Interval 4:
0 Line Code Violations, 2210 Path Code Violations
75 Slip Secs, 4 Fr Loss Secs, 0 Line Err Secs, 4 Degraded Mins
104 Errored Secs, 24 Bursty Err Secs, 4 Severely Err Secs, 0 Unavail Secs
Data in Interval 5:
1011 Line Code Violations, 206 Path Code Violations
65 Slip Secs, 2 Fr Loss Secs, 6 Line Err Secs, 0 Degraded Mins
97 Errored Secs, 34 Bursty Err Secs, 2 Severely Err Secs, 20 Unavail Secs
Total Data (last 5 15 minute intervals):
1011 Line Code Violations, 2919 Path Code Violations,
362 Slip Secs, 7 Fr Loss Secs, 6 Line Err Secs, 4 Degraded Mins,
500 Errored Secs, 143 Bursty Err Secs, 7 Severely Err Secs, 20 Unavail Secs
01-26-2014 10:35 PM
one important thing which forgot to mentioned, please check the "encapsulation" should be same on the both side, check framing and clock as well.
interface Serial3/0:15
encapsulation hdlc====it shud be same on both side
Br,
Nadeem
01-26-2014 11:06 PM
Hi Tommy,
I can see lot of slips and error seconds in E1 controller output.
Please check the clocking [network clock-participate] as suggested by Nadeem as well.
regds,
aman
01-26-2014 11:30 PM
Is it possible to change the cable and check as i can see slips and brust errors on this controllers.
Br,
Nadeem
01-26-2014 11:10 PM
I have check the encapsulation and framing with telco , framing is no-crc4 and encapsulation hdlc
network clock-participate wic 3 also already been configured ,
but the status is same , is it possible hardware problem ?
01-26-2014 11:15 PM
Hi Tommy,
If u have another E1 port available , please check.
what is the router model, show version and show inventory?please share.
regds,
aman
01-26-2014 11:21 PM
Hi Amanso,
unfortunately i only have 1 port of E1 ,
router model is 2901
sh version
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.2(4)M4, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Thu 20-Jun-13 13:06 by prod_rel_team
sh inven
NAME: "CISCO2911/K9", DESCR: "CISCO2911/K9 chassis, Hw Serial#: FGL1743107Y, Hw Revision: 1.0"
NAME: "2nd generation four port FXO voice interface daughtercard on Slot 0 SubSlot 1", DESCR: "2nd generation four port FXO voice interface daughtercard"
NAME: "2nd generation four port FXO voice interface daughtercard on Slot 0 SubSlot 2", DESCR: "2nd generation four port FXO voice interface daughtercard"
NAME: "VWIC3-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot 3", DESCR: "VWIC3-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1"
NAME: "PVDM3 DSP DIMM with 128 Channels on Slot 0 SubSlot 4", DESCR: "PVDM3 DSP DIMM with 128 Channels"
NAME: "Network Module Adapter for SM Slot on Slot 1", DESCR: "Network Module Adapter for SM Slot"
NAME: "High Density Analog Voice Network Module on Slot 1", DESCR: "High Density Analog Voice Network Module"
NAME: "2nd generation four port FXO voice interface daughtercard on Slot 1 SubSlot 0", DESCR: "2nd generation four port FXO voice interface daughtercard"
NAME: "2nd generation four port FXO voice interface daughtercard on Slot 1 SubSlot 1", DESCR: "2nd generation four port FXO voice interface daughtercard"
NAME: "Internal Services Module with Services Ready Engine on Slot 0", DESCR: "Internal Services Module with Services Ready Engine"
NAME: "C2911 AC Power Supply", DESCR: "C2911 AC Power Supply"
regards,
Tommy
01-26-2014 11:28 PM
Hi Tommy,
please refer the link on similar problem
https://supportforums.cisco.com/message/4002473#4002473
there is a bug
T1 interface behavior inconsistent across WIC Modules
regds,
aman
01-27-2014 12:59 AM
Hi Tommy.
Can you please post VG config and a show diag?
Carlo
Please rate all helpful posts
"The more you help the more you learn"
01-27-2014 01:41 AM
01-27-2014 02:11 AM
Hi Tommy,
can u share the output of show network-clock as well?
regds,
aman
01-27-2014 02:21 AM
Hi Aman ,
here is the network clock configuration
Network Clock Configuration
Priority Clock Source Clock State Clock Type
10 Backplane GOOD PLL
Current Primary Clock Source
Tommy
01-27-2014 02:43 AM
Hi Tommy,
ideally , the output should be somewhat like this
sh network-clocks
1 E1 0/3/0 GOOD E1
1 E1 0/3/0 GOOD E1
it seems that clock is not coming.
can you configure the command network-clock-select 1 E1 0/3/0 and then, share again output?
regds,
aman
