Problem for incoming calls
Hi voice team,
I'm having trouble with an extension in CUCM 8.6, I can make calls but can not receive both internal and external calls, the call is diverted to the Unity Connection 8.6. I've checked all the configuration, has no deviation, can anyone help me?
thanks.
Thiago
Everyone's tags (2)
Hall of Fame Super Silver
Thiago,
is the DN assigned to a phone and set as Active?
Is it in proper partition?
If call forward all possible set on it?
Chris
Hi, another problem hehe
Yes the phone as registered and set as active, its in proper partition and call forward is not set.
Have you tried resetting the phone?
Is database replication in proper state?
Is there another DN that is the same in perhaps another partition?
What does Dialed Number Analyzer show?
Chris
Yes i resetting the phone, how do to check the database replication? There´s no another DN, I have not Dialed number analyzer.
DNA is available under serviceability page.
To check DB replication see this doc:
https://supportforums.cisco.com/docs/DOC-13672
Chris
can you explain to me how to verify replication?
Hi follows the config:
A Cisco DBRunningFri Jul 6 18:42:57  201210 days  19:46:58
A Cisco DB ReplicatorRunning
Did you read the doc I posted link to?
Chris
yes, i read the doc, but i can´t find a solution to my problem.
Hi, when the extension 8011 makes a call appears on the other device 36278800 and when the extension 8094 makes a call appers on the display of other device 36278000, but both are on the same range, I can make an outside call for 8094, but for 8011 I can not
OK, can you tell exactly what extension is calling what number and where does it land?
Do both phones have the same Calling Search Space assigned to the device level and DN level?
Are you using device mobility?
Chris
The extension 8011 is not receiving any calls, internal or external, the extension 8094 works fine.
When 8011 makes a call, on the other phone display appears 3627 8800, and when 8094 makes a call, on the other phone display appears 3627 8000.
The phone are on the same Partition and Calling Search Space.
Yes, we are using device mobility.
Thiago
VIP Super Bronze
You need to check the External Phone number Mask on Extension 8011. The mask its showing is 36278800. Is this number part of your DDI range?
Are you using ISDN or SIP Trunk to your service provider?
Can you p ost a debug isdn q931 if you are using isdn or debug ccsip messages if you are using sip
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Hi, the external phone number mask is the same for all phones: 3627XXXX, and the number 8800 to 8899 is my other number range.
i´m using EI- CAS on my service provider.
I cant find the debug command for that.
can you provide us your gateway configuration?
Sure, follows the config:
version 12.4
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
service sequence-numbers
hostname RT-TELEFONIA
boot-start-marker
boot-end-marker
card type e1 0 0
logging message-counter syslog
no logging queue-limit
logging buffered 1000000
no logging rate-limit
no logging console
no logging monitor
enable secret 5 $1$koJb$DmqYTyrAcuUydAql07qF9.
--More--                           no aaa new-model
clock timezone BRA -3
clock summer-time horariodeverao date Oct 17 2009 0:00 Feb 13 2010 0:00
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
dot11 syslog
ip source-route
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 172.26.149.129
ip dhcp excluded-address 172.26.149.130
ip dhcp excluded-address 172.26.149.131
ip dhcp excluded-address 172.26.149.132
ip dhcp excluded-address 172.26.149.140
ip dhcp excluded-address 172.26.149.141
ip dhcp excluded-address 172.26.149.142
ip dhcp excluded-address 172.26.149.143
ip dhcp excluded-address 172.26.149.144
ip dhcp excluded-address 172.26.149.133
ip dhcp excluded-address 172.26.149.135
--More--                           !
ip dhcp pool REDE-TELEFONIA
   network 172.26.149.0 255.255.255.0
   domain-name snr.group
   default-router 172.26.149.144
   option 150 ip 172.26.149.133
   lease 0 12
no ip domain lookup
ip host cur1sr05 172.26.149.130
ip host cur1sr06 172.26.149.133
no ipv6 cef
trunk group BRASILTELECOM
hunt-scheme random
--More--                           !
voice service voip
fax protocol pass-through g711alaw
voice translation-rule 1
rule 1 /^000/ /0014/
rule 2 /^00800/ /0800/
--More--                            rule 3 /^00300/ /0300/
rule 4 /^00/ /014/
rule 5 /^0/ //
voice translation-rule 2
rule 1 /^41/ /0/
rule 2 // /00/
voice translation-rule 4
rule 4 /^00/ /023/
voice translation-profile ENTRADA
translate calling 2
voice translation-profile INTELIG
translate called 1
voice-card 0
dsp services dspfarm
--More--                           application
service onramp-app flash:/app_faxmail_onramp.2.0.1.3.tcl
service offramp-app flash:/app_faxmail_offramp.2.0.1.1.tcl
username cisco password 7 143443180F56
archive
log config
  hidekeys
controller E1 0/0/0
framing NO-CRC4
ds0-group 0 timeslots 1-15,17-30 type r2-digital r2-compelled ani
cas-custom 0
  country brazil
  metering
  double-answer
--More--                             category 2
  answer-signal group-b 1
description LINK BRASILTELECOM 1
controller E1 0/0/1
framing NO-CRC4
cas-custom 0
  country brazil
  metering
  double-answer
  category 2
description LINK BRASILTELECOM 2
interface FastEthernet0/0
ip address 172.26.149.132 255.255.255.0
duplex auto
speed auto
--More--                           !
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 172.26.149.144
ip http server
no ip http secure-server
control-plane
voice-port 0/0/0:0
--More--                           voice-port 0/1/0
cptone BR
connection plar 8000
station-id name Ligacao Celular
caller-id enable
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
voice-port 0/0/1:0
voice-port 0/2/0
cptone BR
voice-port 0/2/1
cptone BR
voice-port 0/2/2
cptone BR
--More--                           voice-port 0/2/3
cptone BR
voice-port 0/3/0
cptone BR
voice-port 0/3/1
cptone BR
voice-port 0/3/2
voice-port 0/3/3
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 172.26.149.133
ccm-manager config
mgcp
mgcp call-agent cur1sr05 2427 service-type mgcp version 0.1
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
--More--                           mgcp package-capability sst-package
mgcp package-capability pre-package
mgcp default-package mt-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp profile default
sccp local FastEthernet0/0
sccp ccm 172.26.149.133 identifier 3 version 7.0
sccp
sccp ccm group 30
description Transcoder
bind interface FastEthernet0/0
associate ccm 3 priority 3
associate profile 3 register MTP002255D8A1A8
dspfarm profile 3 transcode
codec g711ulaw
codec g711alaw
--More--                            codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 4
associate application SCCP
dial-peer voice 100 pots
description REDE PUBLICA
translation-profile incoming ENTRADA
translation-profile outgoing INTELIG
destination-pattern 0T
fax rate disable
direct-inward-dial
port 0/0/0:0
forward-digits all
no register e164
dial-peer voice 101 pots
--More--                            fax rate disable
direct-inward-dial
port 0/0/1:0
forward-digits all
no register e164
dial-peer voice 1 voip
preference 2
destination-pattern 8...$
session target ipv4:172.26.149.133
dtmf-relay h245-signal
dial-peer voice 1001 pots
description 8080-FAX GERAL
destination-pattern 8080
fax rate disable
port 0/2/0
dial-peer voice 1002 pots
description 8081-FAX COMERCIAL
destination-pattern 8081
fax rate disable
port 0/2/1
--More--                           !
dial-peer voice 1005 pots
description 8085-AUDIO CONF
destination-pattern 8085
fax rate disable
port 0/3/0
dial-peer voice 1006 pots
description 8072-MODEM
destination-pattern 8072
fax rate disable
port 0/3/1
dial-peer voice 102 pots
description CELULAR LOCAL
destination-pattern 0[7-9].......$
direct-inward-dial
port 0/1/0
forward-digits 8
dial-peer voice 999020 pots
service mgcpapp
port 0/2/0
--More--                           !
dial-peer voice 999021 pots
service mgcpapp
port 0/2/1
dial-peer voice 999022 pots
service mgcpapp
port 0/2/2
dial-peer voice 999023 pots
service mgcpapp
port 0/2/3
dial-peer voice 999030 pots
service mgcpapp
port 0/3/0
dial-peer voice 999031 pots
service mgcpapp
port 0/3/1
dial-peer voice 1004 pots
port 0/2/3
--More--                           !
gateway
timer receive-rtp 1200
telephony-service
max-conferences 8 gain -6
transfer-system full-consult
create cnf-files version-stamp Jan 01 2002 00:00:00
line con 0
line aux 0
line vty 0 4
password 7 044805140C285F4D065C5447
login local
scheduler allocate 20000 1000
ntp logging
ntp update-calendar
ntp server 10.0.0.253
end
--More--
RT-TELEFONIA#    sh inve
RT-TELEFONIA#sh inventory
NAME: "2811 chassis", DESCR: "2811 chassis"
PID: CISCO2811         , VID: V05 , SN: FTX1232A2QX
NAME: "VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot 0", DESCR: "VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC2-2MFT-T1/E1  , VID: V01 , SN: FOC12305S9Z
NAME: "2nd generation four port FXO voice interface daughtercard on Slot 0 SubSlot 1", DESCR: "2nd generation four port FXO voice interface daughtercard"
PID: VIC2-4FXO         , VID: V03 , SN: FOC122802LX
NAME: "Four port FXS DID voice interface daughtercard on Slot 0 SubSlot 2", DESCR: "Four port FXS DID voice interface daughtercard"
PID: VIC-4FXS/DID=     , VID: 3.1, SN: FOC12151YM9
NAME: "Four port FXS DID voice interface daughtercard on Slot 0 SubSlot 3", DESCR: "Four port FXS DID voice interface daughtercard"
PID: VIC-4FXS/DID=     , VID: 3.1, SN: FOC12280Z6W
NAME: "PVDMII DSP SIMM with four DSPs on Slot 0 SubSlot 4", DESCR: "PVDMII DSP SIMM with four DSPs"
PID: PVDM2-64          , VID: V01 , SN: FOC12301ZBQ
NAME: "PVDMII DSP SIMM with four DSPs on Slot 0 SubSlot 5", DESCR: "PVDMII DSP SIMM with four DSPs"
PID: PVDM2-64          , VID: V01 , SN: FOC12295SC6
Re: Problem for incoming calls
try configuring this
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
supplementary-service h450.12
fax protocol t38 nse force ls-redundancy 0 hs-redundancy 0 fallback cisco
h323
  h225 timeout tcp call-idle never
  h225 timeout t302 2
  h225 timeout setup 3
  call preserve
modem passthrough nse codec g711ulaw
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
voice class h323 1
h225 timeout tcp establish 3
voice-class codec 1
voice-class h323 1
session target ipv4:IP ADDRESS CALL MANAGER
dtmf-relay h245-alphanumeric
fax rate disable
no vad
but this setting will affect all other extensions, I'm with a problem only in 8011, I can muster, but he does not receive internal and external calls
oh sorry... my mistake.
you see route plan report to see what happen?
you use DNA? on serviciability...
Ok, no problem, how do I test the number using the route plan report ? I use the DNA, and the result is the same with the others phone.
Go to:
Call routing --> Route Plan Report --> put 8011 and press search...
If only an ip phone have 8011 configured must appear below
yes, only appeared extension 8011
ok...
on your gateway do this
apply command "sh dialplan number 8011#"
and paste your results
Hi, follows the result:
RT-TELEFONIA#sh dialplan number 8011#
Macro Exp.: 8011
VoiceOverIpPeer1
        peer type = voice, system default peer = FALSE, information type = voice,
        description = `',
        tag = 1, destination-pattern = `8...$',
        voice reg type = 0, corresponding tag = 0,
        allow watch = FALSE
        answer-address = `', preference=2,
        CLID Restriction = None
        CLID Network Number = `'
        CLID Second Number sent
        CLID Override RDNIS = disabled,
        rtp-ssrc mux = system
        source carrier-id = `', target carrier-id = `',
        source trunk-group-label = `',  target trunk-group-label = `',
        numbering Type = `unknown'
        group = 1, Admin state is up, Operation state is up,
        incoming called-number = `', connections/maximum = 2/unlimited,
        DTMF Relay = enabled,
        modem transport = system,
        URI classes:
            Incoming (Called) =
            Incoming (Calling) =
            Destination =
        huntstop = disabled,
        in bound application associated: 'DEFAULT'
        out bound application associated: ''
        dnis-map =
        permission :both
        incoming COR list:maximum capability
        outgoing COR list:minimum requirement
        Translation profile (Incoming):
        Translation profile (Outgoing):
        incoming call blocking:
        translation-profile = `'
        disconnect-cause = `no-service'
        advertise 0x40 capacity_update_timer 25 addrFamily 4 oldAddrFamily 4
        mailbox selection policy: none
        type = voip, session-target = `ipv4:172.26.149.133',
        technology prefix:
        settle-call = disabled
        ip media DSCP = ef, ip media rsvp-pass DSCP = ef
        ip media rsvp-fail DSCP = ef, ip signaling DSCP = af31,
        ip video rsvp-none DSCP = af41,ip video rsvp-pass DSCP = af41
        ip video rsvp-fail DSCP = af41,
        ip defending Priority = 0, ip preemption priority = 0
        ip policy locator voice:
        ip policy locator video:
        UDP checksum = disabled,
        session-protocol = cisco, session-transport = system,
        req-qos = best-effort, acc-qos = best-effort,
        req-qos video = best-effort, acc-qos video = best-effort,
        req-qos audio def bandwidth = 64, req-qos audio max bandwidth = 0,
        req-qos video def bandwidth = 384, req-qos video max bandwidth = 0,
        dtmf-relay = h245-signal,
        RTP dynamic payload type values: NTE = 101
        Cisco: NSE=100, fax=96, fax-ack=97, dtmf=121, fax-relay=122
               CAS=123, TTY=119, ClearChan=125, PCM switch over u-law=0,
               A-law=8, GSMAMR-NB=117 iLBC=116, AAC-ld=114, lmr_tone=0, nte_tone=0
               h263+=118, h264=119
               G726r16 using static payload
               G726r24 using static payload
        RTP comfort noise payload type = 19
        fax rate = voice,   payload size =  20 bytes
        fax protocol = system
        fax-relay ecm enable
        Fax Relay ans enabled
        Fax Relay SG3-to-G3 Enabled (by system configuration)
        fax NSF = 0xAD0051 (default)
        codec = g729r8,   payload size =  20 bytes,
        video codec = None
        voice class codec = `'
        voice class sip rsvp-fail-policy voice post-alert mandatory keep-alive interval 30
        voice class sip rsvp-fail-policy voice post-alert optional keep-alive interval 30
        voice class sip rsvp-fail-policy video post-alert mandatory keep-alive interval 30
        voice class sip rsvp-fail-policy video post-alert optional keep-alive interval 30
        text relay = disabled
        Media Setting = forking (disabled) flow-through (global)
        Expect factor = 10, Icpif = 20,
        Playout Mode is set to adaptive,
        Initial 60 ms, Max 1000 ms
        Playout-delay Minimum mode is set to default, value 40 ms
        Fax nominal 300 ms
        Max Redirects = 1, signaling-type = cas,
        VAD = enabled, Poor QOV Trap = disabled,
        Source Interface = NONE
        voice class sip url = system,
        voice class sip rel1xx = system,
        tvoice class sip outbound-proxy = system,
        voice class sip asserted-id = system,
        voice class sip privacy = system,
        voice class sip e911 = system,
        voice class sip history-info = system,
        voice class sip anat = system,
        voice class sip g729 annexb-all = system,
        voice class sip early-offer forced = system,
        voice class sip negotiate cisco = system,
        voice class sip authenticate redirecting-number = system,
        redirect ip2ip = disabled
        local peer = false
        probe disabled,
        Secure RTP: system (use the global setting)
        voice class perm tag = `'
        Time elapsed since last clearing of voice call statistics never
        Connect Time = 210133371, Charged Units = 0,
        Successful Calls = 6934, Failed Calls = 604, Incomplete Calls = 33
        Accepted Calls = 10453, Refused Calls = 570,
        Last Disconnect Cause is "10  ",
        Last Disconnect Text is "normal call clearing (16)",
        Last Setup Time = 265658672.
        Last Disconnect Time = 265652096.
Matched: 8011   Digits: 2
Target: ipv4:172.26.149.133
ok, one more test...
try this command "sh call his voice brief" after make the call
RT-TELEFONIA#sh call his voice brief
: ms. + + pid:
  dur hh:mm:ss tx:/ rx:/ ()
IP : rtt:
  delay://ms
media inactive detected: media cntrl rcvd: timestamp:
long duration call detected: long duration call duration : timestamp:
  MODEMPASS buf:/ loss /
   last s dur:/s
FR [int dlci cid] vad: dtmf: seq:
  (payload size)
ATM [int vpi/vci cid] vad: dtmf: seq:
  (payload size)
Telephony (callID) [channel_id] tx://ms noise:dBm acom:dBm
  MODEMRELAY info:// xid:/ total:// disc:
             speeds(bps): local / remote /
Proxy :
bw: / codec:
  tx:
rx:
Telephony call-legs: 14
SIP call-legs: 0
H323 call-legs: 14
Call agent controlled call-legs: 0
Total call-legs: 28
8B1  : 40765 -1638949646ms.40756 +2100 +446330 pid:1 Originate 8028
dur 00:07:24 tx:15375/304591 rx:22211/444220 10  (normal call clearing (16))
IP 172.26.149.20:29450 SRTP: off rtt:0ms pl:437260/0ms lost:0/1/0 delay:60/60/70ms g729r8 TextRelay: off
  media inactive detected:n media contrl rcvd:n/a timestamp:n/a
  long duration call detected:n long dur callduration :n/a timestamp:n/a
8B1  : 40764 -1638949656ms.40757 +2120 +447400 pid:100 Answer 4130953078
dur 00:07:25 tx:15375/304591 rx:22211/621908 10  (normal call clearing (16))
Telephony 0/0/0:0 (40764) [0/0/0.2] tx:444220/304480/0ms g729r8 noise:-64dBm acom:15dBm
250E : 40774 -1638535496ms.40758 +29830 +44180 pid:1 Answer 8035
dur 00:00:14 tx:824/16182 rx:717/14340 10  (normal call clearing (16))
IP 172.26.149.44:25970 SRTP: off rtt:0ms pl:12850/0ms lost:0/0/0 delay:60/60/70ms g729r8 TextRelay: off
250E : 40775 -1638535186ms.40759 +29510 +44000 pid:100 Originate 35575353
dur 00:00:14 tx:824/16182 rx:717/20076 10  (normal call clearing (16))
Telephony 0/0/0:0 (40775) [0/0/0.7] tx:41040/16190/0ms g729r8 noise:-73dBm acom:21dBm
--More--                             long duration call detected:n long dur callduration :n/a timestamp:n/a
240E : 40772 -1638566686ms.40760 +17510 +120360 pid:1 Answer 8021
dur 00:01:42 tx:2541/49956 rx:5141/102820 10  (normal call clearing (16))
IP 172.26.149.102:22382 SRTP: off rtt:0ms pl:100950/0ms lost:0/0/0 delay:60/60/70ms g729r8 TextRelay: off
240E : 40773 -1638566386ms.40761 +17210 +120190 pid:100 Originate 36278500
dur 00:01:42 tx:2541/49956 rx:5141/143948 10  (normal call clearing (16))
Telephony 0/0/0:0 (40773) [0/0/0.24] tx:113560/49950/0ms g729r8 noise:-57dBm acom:18dBm
8D1  : 40777 -1638416046ms.40762 +2620 +220530 pid:1 Originate 8000
dur 00:03:37 tx:8283/164642 rx:10159/203180 10  (normal call clearing (16))
IP 172.26.149.102:26202 SRTP: off rtt:0ms pl:19020/50ms lost:0/0/0 delay:60/60/70ms g729r8 TextRelay: off
8D1  : 40776 -1638416056ms.40763 +2640 +221610 pid:100 Answer 4133325001
--More--                            dur 00:03:38 tx:8671/172345 rx:10159/284452 10  (normal call clearing (16))
Telephony 0/0/0:0 (40776) [0/0/0.1] tx:217900/172330/0ms g729r8 noise:-48dBm acom:45dBm
260E : 40780 -1638256316ms.40764 +11020 +283180 pid:1 Answer 8091
dur 00:04:32 tx:7706/152785 rx:11073/221460 10  (normal call clearing (16))
IP 172.26.149.162:30402 SRTP: off rtt:0ms pl:71120/50ms lost:0/0/0 delay:60/60/70ms g729r8 TextRelay: off
260E : 40781 -1638256016ms.40765 +10710 +283020 pid:100 Originate 32217523
dur 00:04:32 tx:8388/166214 rx:11073/310044 10  (normal call clearing (16))
Telephony 0/0/0:0 (40781) [0/0/0.30] tx:273270/166180/0ms g729r8 noise:-63dBm acom:24dBm
280E : 40784 -1637979496ms.40766 +14020 +42050 pid:1 Answer 8071
dur 00:00:28 tx:903/17628 rx:1400/28000 10  (normal call clearing (16))
IP 172.26.149.2:16384 SRTP: off rtt:0ms pl:23320/0ms lost:0/0/0 delay:60/60/70ms g729r8 TextRelay: off
280E : 40785 -1637979196ms.40767 +13720 +41890 pid:100 Originate 36272510
dur 00:00:28 tx:903/17628 rx:1400/39200 10  (normal call clearing (16))
Telephony 0/0/0:0 (40785) [0/0/0.29] tx:39130/17630/0ms g729r8 noise:-44dBm acom:18dBm
8D8  : 40779 -1638380576ms.40768 +6680 +474370 pid:1 Originate 8065
dur 00:07:47 tx:13077/258445 rx:23382/467640 10  (normal call clearing (16))
IP 172.26.149.188:26774 SRTP: off rtt:0ms pl:464170/0ms lost:0/0/0 delay:60/60/70ms g729r8 TextRelay: off
8D8  : 40778 -1638380586ms.40769 +6700 +475440 pid:100 Answer 1150510278
dur 00:07:48 tx:13077/258445 rx:23382/654696 10  (normal call clearing (16))
Telephony 0/0/0:0 (40778) [0/0/0.2] tx:467670/258320/0ms g729r8 noise:-70dBm acom:7dBm
8E5  : 40787 -1637904376ms.40770 +3860 +41260 pid:1 Originate 8039
dur 00:00:37 tx:1263/24857 rx:1868/37360 10  (normal call clearing (16))
--More--                            IP 172.26.149.170:18976 SRTP: off rtt:0ms pl:33610/0ms lost:0/0/0 delay:60/60/70ms g729r8 TextRelay: off
8E5  : 40786 -1637904386ms.40771 +3870 +42340 pid:100 Answer 4132278700
dur 00:00:38 tx:1263/24857 rx:1868/52304 10  (normal call clearing (16))
Telephony 0/0/0:0 (40786) [0/0/0.1] tx:37390/24870/0ms g729r8 noise:-68dBm acom:18dBm
2A0E : 40790 -1637832576ms.40772 +5960 +12150 pid:1 Answer 8033
dur 00:00:06 tx:251/4924 rx:309/6180 10  (normal call clearing (16))
IP 172.26.149.110:28492 SRTP: off rtt:0ms pl:4670/0ms lost:0/0/0 delay:60/60/70ms g729r8 TextRelay: off
2A0E : 40791 -1637832266ms.40773 +5650 +11980 pid:100 Originate 0141143414355
dur 00:00:06 tx:251/4924 rx:309/8652 10  (normal call clearing (16))
Telephony 0/0/0:0 (40791) [0/0/0.18] tx:7130/4930/0ms g729r8 noise:-80dBm acom:6dBm
--More--
270E : 40782 -1638014166ms.40774 +7360 +206940 pid:1 Answer 8084
dur 00:03:19 tx:4424/86973 rx:9979/199580 10  (normal call clearing (16))
IP 172.26.149.240:22928 SRTP: off rtt:0ms pl:194990/0ms lost:0/1/0 delay:60/60/70ms g729r8 TextRelay: off
270E : 40783 -1638013856ms.40775 +7050 +206770 pid:100 Originate 39077091
dur 00:03:19 tx:4424/86973 rx:9979/279412 10  (normal call clearing (16))
Telephony 0/0/0:0 (40783) [0/0/0.19] tx:203440/86930/0ms g729r8 noise:-55dBm acom:45dBm
290E : 40788 -1637898356ms.40776 +9200 +147490 pid:1 Answer 8028
dur 00:02:18 tx:3658/72230 rx:6914/138280 10  (normal call clearing (16))
IP 172.26.149.20:20150 SRTP: off rtt:0ms pl:134590/0ms lost:0/0/0 delay:60/60/70ms g729r8 TextRelay: off
290E : 40789 -1637898056ms.40777 +8890 +147330 pid:100 Originate 33330340
dur 00:02:18 tx:3658/72230 rx:6914/193592 10  (normal call clearing (16))
--More--                            Telephony 0/0/0:0 (40789) [0/0/0.14] tx:142830/72220/0ms g729r8 noise:-66dBm acom:29dBm
2C0E : 40794 -1637807346ms.40778 +15970 +75980 pid:1 Answer 8033
dur 00:01:00 tx:1088/21078 rx:3000/60000 10  (normal call clearing (16))
IP 172.26.149.110:31324 SRTP: off rtt:0ms pl:54790/0ms lost:0/0/0 delay:60/60/70ms g729r8 TextRelay: off
2C0E : 40795 -1637807036ms.40779 +15650 +75800 pid:100 Originate 0141143905218
dur 00:01:00 tx:1088/21078 rx:3000/84000 10  (normal call clearing (16))
Telephony 0/0/0:0 (40795) [0/0/0.17] tx:67880/21050/0ms g729r8 noise:-59dBm acom:17dBm
2D0E : 40796 -1637722556ms.40780 +16130 +54340 pid:1 Answer 8041
dur 00:00:38 tx:865/16917 rx:1909/38180 10  (normal call clearing (16))
IP 172.26.149.18:21160 SRTP: off rtt:0ms pl:35910/0ms lost:0/0/0 delay:60/60/70ms g729r8 TextRelay: off
--More--
2B0E : 40792 -1637816046ms.40781 +19430 +147920 pid:1 Answer 8035
dur 00:02:08 tx:4038/79386 rx:6423/128460 10  (normal call clearing (16))
IP 172.26.149.44:32372 SRTP: off rtt:0ms pl:124400/0ms lost:0/0/0 delay:60/60/70ms g729r8 TextRelay: off
2D0E : 40797 -1637722246ms.40782 +15820 +54160 pid:101 Originate 30600778
dur 00:00:38 tx:865/16917 rx:1909/53452 10  (normal call clearing (16))
Telephony 0/0/1:0 (40797) [0/0/1.20] tx:50410/16930/0ms g729r8 noise:-61dBm acom:32dBm
2B0E : 40793 -1637815736ms.40783 +19120 +147750 pid:101 Originate 35575353
dur 00:02:08 tx:4038/79386 rx:6423/179844 10  (normal call clearing (16))
Telephony 0/0/1:0 (40793) [0/0/1.27] tx:144850/79350/0ms g729r8 noise:-63dBm acom:28dBm
2F0E : 40803 -1637659186ms.40784 +-1 +1250 pid:102 Originate 084046333
dur 00:00:00 tx:0/0 rx:0/0 22  (no circuit (34))
Telephony 0/1/0 (40803) [0/1/0] tx:0/0/0ms None noise:0dBm acom:0dBm
The number of call legs at the end of the show process
is not equal to the initial count. Some call-legs were
terminated or created during the viewing process.
Number of call-legs counted during viewing: 29
RT-TELEFONIA# exit
i cant see call leg...
yo make the call, then put that command and you receive that?
i think the number is not open on telco and isnt arrive to gateway never...
you get busy tone?
I made an outside call by entering the extension 8011, the call is forward to Unity connection.
And you get a voicemail box?
Try to put a print screen from
Call routing --> directory number --> 8011
and other from Route Pattern --> 8
1840
