Community Member
Problem GW underflow
Hello I have a problem with GW I get this mesage:
Oct 18 17:24:29.389: %PQUICC_ETHER-3-UNDERFLO: Unit 0, underflow error
Oct 19 19:37:01.373: %TCP-2-BADREFCNT: Tty0: Bad refcnt for packet 0x83E5FF80 during retransmit, 10.100.2.253(46158) to 180.33.186.120(1720), state 4 -Traceback= 0x801BA7C0 0x804F94D4 0x804F996C 0x804FFB98 0x80500080 0x802FEACC 0x803022D0
Oct 19 19:37:01.373: %SYS-2-BADSHARE: Bad refcount in datagram_done, ptr=8388AAEC, count=0 -Traceback= 0x801BA7C0 0x8025B4A4 0x805371AC 0x80537D7C 0x80537DB0 0x8054A188 0x804F91B8 0x804F9DA4 0x804FFB98 0x80500080 0x802FEACC 0x803022D0
Oct 19 19:37:06.426: %TCP-2-BADREFCNT: Tty0: Bad refcnt for packet 0x83E5FF80 during retransmit, 10.102.1.253(46158) to 190.34.187.130(1720), state 4 -Traceback= 0x801BA7C0 0x804F94D4 0x804F996C 0x804FFB98 0x80500080 0x802FEACC 0x803022D0
Oct 19 19:37:19.766:
TCP0: extra packet reference for pak 0x83E5FF80 found:
Oct 19 19:37:19.766: %TCP-2-BADQUEUE: Multiple entry for packet 83E5FF80 -Process= "CCH323_CT", ipl= 0, pid= 167 -Traceback= 0x801BA7C0 0x804FE880 0x80502338 0x80504698 0x805E961C 0x805EFFB8 0x816EFB38 0x816DE3B4 0x816745D8 0x816748A4 0x8167D0B4 0x81681C88 0x816B2494 0x81687E4C 0x81655310 0x8166C44C
Oct 19 19:37:19.766:     pak: UNKNOWN:46158, UNKNOWN:1720, seq 1532416589 length 138
I have a flash:c1700-k9o3sv8y7-mz.124-25d.bin
anyone can helpme?
Hall of Fame Super Gold
Re: Problem GW underflow
Try a reload.
VIP Super Bronze
Memory allocation errors are almost always a bug unless you are oversubscribing the router. I searched for bugs but found nothing; not that it means anything since many are not public.
If the problem repeats, I would definitely try a newer IOS version.
I decoded the tracebacks and they are related to TCP sockets and retransmissions, and h225/h245.  I also didn't see any bugs, internal nor external.
I'd suggest you open a case regarding this.  It would also be of benefit to collect the following during an error, to identify root cause.
debug voip ccapi inout
debug ip tcp trans
debug cch323 all
debug h225 asn1
debug h245 ans1
Collect via:
Router(config)# service sequence
Router(config)# service timestamps debug datetime msec
Router(config)# logging buffered 10000000 7
Router(config)# no logging con
Router(config)# no logging mon
Router(config)# voice iec syslog
Router# term len 0
Router# sh logg
Are you running NAT and CME on this box?  I did find that this had similar errors:
CSCsi26454
New feature request: CME and NAT in the same box
666
