Problem in 7985 Ip phone
amansoi_5
Hi All,
i am facing problem with cisco Video Phone 7985 .I had configured it for Directory number X earlier and was working fine.
suddenly,somebody did some changes & changed number to Y.I deleted the directory number Y but it is still showing on display as Y.
Now when we make a call for X or Y , call is landing on same phone.But when 7985 user makes a call , number displayed on receiving end is Y.
I deleted directory number and phone,while re-adding phone ,it automatically picks up the same number Y ,even though it is not existing in any of configs in CCM.
I tried changing the ip phone & added directory number X which is working fine
Can somebody guide on the same.?
regds,
aman
Jaime Valencia
did you deleted the DN from the unassigned DNs before recreating the device??
java
if this helps, please rate
java
I did not do this.I will check & let u know.
regds,
aman
I did not find the desired number in UNASSIGNED Number.
regds,
aman
