Problem in COR while configuring in CCME
i have configured COR by referrin to a doc but COR is not blocking any patterns as i configured.Here is the configuration..
dial-peer cor custom
name .T
name .0T
name .00T
dial-peer cor list localcall
member .T
dial-peer cor list nationalcall
member .0T
dial-peer cor list internationalcall
member .00T
dial-peer cor list users
member .T
dial-peer cor list Supervisiors
member .T
member .0T
dial-peer cor list managers
member .T
member .0T
member .00T
ephone-dn 1
number 2000
description 2000
corlist incoming managers
ephone-dn 2
number 2001
description 2001
ephone-dn 10
number 2010
description 2010
ephone-dn 11
number 2011
description 2011
corlist incoming Supervisiors
ephone-dn 12
number 2012
description 2012
ephone-dn 13
number 2013
description 2013
corlist incoming users
ephone-dn 14
number 2014
description 2014
ephone-dn 15
number 2015
description 2015
ephone-dn 16
number 2016
description 2016
ephone-dn 17
number 2017
description 2017
ephone-dn 18
number 2018
description 2018
ephone-dn 19
number 2019
description 2019
ephone-dn 20
number 2020
description 2020
Could you pls guide me here out...
thanks in advance
siva
Re: Problem in COR while configuring in CCME
Hi Sivakumar,
I believe the issue could be one of two problems or possibly both.
Firstly have you applied the outgoing cor list to the outgoing POTS dial-peer?
For example the corlist outgoing cointernationalcall should be applied to your International POTs dial-peer.
Secondly, as you are using variable length digit-strings, I suspect that these are overlaping and International will be using the National POTs dial-peer for the outbound call-leg.
Run a 'debug voice capi inout' when you attempt to make an outbound International call from an IP Phone which does not the permission.
The debug will indicate which outbound dial-peer was used. If this is the case then you will need to revise the destination-patterns to make them more explicit.
For example, is your local digit dialplan a fixed number of digits starting with a certain prefix. Here in the UK they start with 2-9 and can be 6,7 or 8 digits, at least this defines it from National calls which start 0 and internation which start 00.
dial-peer voice 1000 pots
corlist outgoing LocalPT
destination-pattern 9[2-9].......
forward-digits 8
Hope this helps.
Allan.
Pls rate helpful posts.
Hi friend,
As Allan said, check if your dial-peers are configured with corlist outgoing.
Please note that if there is no corlist outgoing, any ephone-dn could reach them regardless of its corlist incoming configuration.
- Adrián.
I have configured outgoing corlist under respective dial-peers but it's still not blocking.Could you guide me to move on further...
regards
siva
Could you paste your new config? (i.e. dial-peers, ephone-dns and dial-peer corlists...).
Regards.
Hi Sivakumar,
As I have previously mentioned, if you are using variable length digit-strings then it is possible that these are overlaping.
Run a 'debug voice capi inout' when you attempt to make an outbound International call from an IP Phone which does not the appropriate cor list.
The debug will indicate which outbound dial-peer was used. For example if you dial an international number from an IP Phone which is not permitted, the debug will show which dial-peer was used to place the call.
Please capture the appropriate debug as I have mentioned, and post the results.
Allan.
578
