Problem in Extension mobility
Hello Friends ,
I am using CCM 7.02 and i am trying to do extension mobility with my Cisco 7940 phones
When i press the services button i simply get "Host not found error"
I have tried all the standard troubleshooting steps suggested as per the URL https://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080093e72.shtml
But to my surprise the same thing works perfectly fine with my Cisco 7906 phones without any issues
My question is is there any reported bug with 7940 and CCM 7 or is there something i am missing on
Re: Problem in Extension mobility
You might want to try upgrading the FW on your 7940s to the latest  compatible one and try again.
If they're in another network segment from working phones check for routing issues.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Hi Java,
There could be no routing issues as it is on the same network segemnt rather on a layer-2 switch
I have upgraded the firmware to 8.12 which is the latest for 7940 phones still it says "Host not Found"
Any other suggestions !!
VIP Super Bronze
What is the url for your services in your enterprise parameter. It should be
http://X.X.X.X:8080/ccmcip/getservicesmenu.jsp
where X.X.X.X=Ip address of your publisher. If you are using FQDN here, its recommended you use IP address so as to eliminate any dependency on DNS
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
239
