Problem in IP Communicator with CCM 5.1 ..
Hii all,
I am working with CCM 5.1. I registered a IP Communicator (Soft Phone). When I am trying to communicate with that Soft phone its ringing . and connected with caller but no voice is coming...
any body know , wth is the problem?
plz help me
Thanks & Regards
Madhab
Re: Problem in IP Communicator with CCM 5.1 ..
Hi Madhab,
I am working with CCM 5.1 but I don't have this problem. Do you can be more specific, maybe the problem not is de IP Communicator. The problem occur with another IP Phone?
sounds like a routing issue, check that you have all the proper routing for the RTP to be routed from IP Phone to IPC
also check codecs just in case
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
110
