problem in SRST mode registration
Hiii Experts
When the router connectvity to Server fails (via E1) ....the phone connected to switches...3905(SIP) and 6921(sccp) gets register into local srst mode within 2 minutes....but the 8945 phones are not registering itself into local SRST mode....phone not registered info comes....what may be the probable cause........plz help
Regards Nitesh
  • IP Telephony
2 ACCEPTED SOLUTIONS
Re: problem in SRST mode registration
That model is supported from srst version 8.8 that means at leat ios 15.2(1)
Upgrage the IOS and all should work fine
Carlo
Please rate all helpful posts "The more you help the more you learn"
if your IOS ver 15.1(4)M and SRST version is 8.6, then you have to add following IOS command in order to register phones.
Configuring Cisco Unified 8941 and 8945 SCCP IP Phones
To configure Cisco Unified 8941 and 8945 SCCP IP Phones in SRST mode,
perform the following commands:
Note This section is required only in SRST version 8.6 and is not required for version 8.6 and higher.
SUMMARY STEPS
1. enable
2. configure terminal
3. ephone-type phone-typ
4. device-id number
5. device-type phone-type
6. end
Add following to IOS global config:
Router# config term
Router(config)#ephone-type 8945
Router(config-ephone-type)#device-id 585
Router(config-ephone-type)#device-type 8945
Supported links and reference.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cusrst/admin/sccp_sip_sr
st/configuration/guide/SCCP_and_SIP_SRST_Admin_Guide/srst_setting_up_using_
sccp.html#wp1362302
st/configuration/guide/SCCP_and_SIP_SRST_Admin_Guide/srst_roadmap.html#wp10
92434
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cusrst/command/reference
/srstcr/srsa_a_m.html#wp1360124
Br,
Nadeem
Br, Nadeem Please rate all useful post.
Does your SRST version supports the 8945???
What protocol are you using??
Does it have the correct SRST reference?
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
at other location it supports SRST mode....r u talking abt the OS version of the router?
Hall of Fame Super Silver
Post your SRST configuration and "sh ver", and let us know if the 8945 is using SCCP or SIP.
Chris
Has this work ever I mean did ever 8945 phones falls into SRST and registered ? I have had this issue in my expeirence and which could be related compatability of 8945 with IOS version and have them registered additional configuration required on the router side. . But that only can be confirmed once you send all information as asked by Chris.
Br,
Nadeem Ahmed
chris...........the version is i remeber 15.1 and the phone is sccp
version in details i will post u soon as of now my router is not accesible to me
Carlo
Dear Carlo....thanx it worked
If this is a 2800 series router it is not going to work. The CME/SRST engine in those model routers does not support that model phone as Java was eluding to.
Have a look here:
https://supportforums.cisco.com/message/4028027#4028027
Tracy.........its cisco2951.....
1062
