Problem installing VIC2-BRI NT/TE on C2901k9
Luis Ruiz Lopez
Hope someone could give me a hand on this. I have a Cisco 2901 with IOS version c2900-universalk9-mz.SPA.152-4.M3.bin and I want to install and configure a VIC2 - BRI-NT/TE card on it. The card is already inserted and I can see it when I do "sh diag":
WIC Slot 0:
        VIC2 - BRI-NT/TE Voice daughter card (2 port)
        Hardware Revision        : 1.1
        Top Assy. Part Number    : 800-33406-01
        Board Revision           : D0
        Deviation Number         : 0-0
        Fab Version              : 03
        PCB Serial Number        : FOC172383PM
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Product (FRU) Number     : VIC2-2BRI-NT/TE
        Version Identifier       : V03
        CLEI Code                : CNUIAVZAAB
When I do "sh version" or "sh hardware" I cannot see the card and therefore I cannot configure it:
Cisco CISCO2901/K9 (revision 1.0) with 897024K/45056K bytes of memory.
Processor board ID FCZ1730620W
2 Gigabit Ethernet interfaces
3 terminal lines
1 Virtual Private Network (VPN) Module
2 Cellular interfaces
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
And also if I do "sh inventory" the card is not there neither:
NAME: "CISCO2901/K9", DESCR: "CISCO2901/K9 chassis, Hw Serial#: FCZ1730620W, Hw Revision: 1.0"
PID: CISCO2901/K9      , VID: V06 , SN: FCZ1730620W
NAME: "3G WWAN EHWIC-QuadBand HSPA+R7/HSPA/UMTS QuadBand EDGE/GPRS and GPS on Slot 0 SubSlot 1", DESCR: "3G WWAN EHWIC-QuadBand HSPA+R7/HSPA/UMTS QuadBand EDGE/GPRS and GPS"
PID: EHWIC-3G-HSPA+7   , VID: V01 , SN: FOC172155GE
NAME: "Modem 0 on Cellular0/1/0", DESCR: "Sierra Wireless MC8705"
PID: MC8705            , VID: 1.0, SN: 357115040673787
NAME: "PVDM3 DSP DIMM with 16 Channels on Slot 0 SubSlot 4", DESCR: "PVDM3 DSP DIMM with 16 Channels"
PID: PVDM3-16          , VID: V01 , SN: FOC17226EBZ
NAME: "C1941/C2901 AC Power Supply", DESCR: "C1941/C2901 AC Power Supply"
PID: PWR-1941-2901-AC  , VID:    , SN:
I tried swaping the card into a different slot and still the same, I cannot configure any command. I was thinking in downgrading the IOS to c2900-universalk9-mz.SPA.152-4.M2.bin because I have these image running fine in other routers.
Does anyone know how I make this work? Is there anything that I am missing?
Thanks a lot for your support in advance.
Hi Lopez,
Seems to be license problem as pointed by Mr. Amine.You can generate the evaluation license and check the same.
http://www.cisco.com/en/US/prod/collateral/routers/ps10616/white_paper_c11_556985_ps10537_Products_White_Paper.html
regds,
aman
13 Replies 13
Amine Nouasri
Level 3
Level 3
Can you post a sh license feature?
You probably need a license to unlock the UC feature before you can provision the voice ports on the router.
Please rate helpful answers!
Hi Luis.
Can you please post the output of a show diag and show run?
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi Lopez,
regds,
aman
Seems to be an issue with the license:
Index 3 Feature: uck9
        Period left: Not Activated
        Period Used: 0  minute  0  second
        License Type: EvalRightToUse
        License State: Not in Use, EULA not accepted
        License Count: Non-Counted
        License Priority: None
I am trying to generate the right evaluation licenses until I have the PAK file from my provider, do you know the name of the right license to use:
  • Cisco Emergency Responder - Evaluation
  • Cisco Smart Business Portal Demo
  • Cisco Unified Call Manager Evalulation
  • Cisco Unified CallConnector Demo
  • Cisco Unified Communications Demo License
  • Cisco Unified Communications Manager Business Edition 3000 Eval
  • Cisco Unified Intelligence Center - Demo
  • Cisco Unified Intelligence Center Demo 2
  • Cisco Unified Intelligence Suite Demo
  • Cisco Unified MeetingPlace Demo
  • Cisco Unity Express Eval
  • ICSUnity 4.x Demo
  • IP IVR - Demo
  • IPCC Express - Demo
  • MeetingPlace Express Software Demo
  • MeetingPlace Express VT Software Demo
  • SIP Proxy Server Demo
  • Unity Connection 1.1 Evaluation
  • Unity Connection Demo
  • Unity Connection Speech View Demo License
  • Unity Demo
  • Unity Pooling License
Thanks! I will rate your posts as soon as I have this ready!
You need IOS upgrade
Plz check you latest release or T release
Haitham
Hi Lopez,
You need to go for Cisco Unified Communications Demo License.
regds,
aman
I could activate the evaluation license with following command:
conf t
license boot module c2900 technology-package uck9
reload
Now I will wait for my final license.
Thank you!
Hi.
use this command and do a show license again
license accept end user agreement
Carlo
Hi Lopez,
Can u post the show license feature output now?
regds,
aman
Sure
Feature name             Enforcement  Evaluation  Subscription   Enabled  RightToUse
ipbasek9                 no           no          no             yes      no
securityk9               yes          yes         no             yes      yes
uck9                     yes          yes         no             yes      yes
datak9                   yes          yes         no             no       yes
gatekeeper               yes          yes         no             no       yes
SSL_VPN                  yes          yes         no             no       yes
ios-ips-update           yes          yes         yes            no       yes
SNASw                    yes          yes         no             no       yes
hseck9                   yes          no          no             no       no
cme-srst                 yes          yes         no             no       yes
WAAS_Express             yes          yes         no             no       yes
UCVideo                  yes          yes         no             no       yes
I have just gotten the SRST license but no yet the UC license, In order to apply the SRST, I guess I need to wait for the final license right?
Hi Lopez,
The SRST licenses are honour based.
Can u run the command show license detail cme-srst and send output?
regds,
aman
Feature: cme-srst                        Period left: 8  weeks 4  days
Index: 1        Feature: cme-srst                          Version: 1.0
            Evaluation total period: 8  weeks 4  days
            Evaluation period left: 8  weeks 4  days
            Period used: 0  minute  0  second
        License Count: 0/0  (In-use/Violation)
        Store Index: 7
        Store Name: Built-In License Storage
Hi Lopez,
You need to enter the command
license accept end user agreement [yes]
you can also refer the link
https://supportforums.cisco.com/thread/2075698
regds,
aman
