Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Problem loading CUE 7.0.6 on AIM-CUE in 2801
I've been working my way thru all the problems trying to get CUE loaded on an AIM-CUE card in a 2801.
Got to the point that the card will load the software from the FTP server, but after selecting the language (English only) it stops with the errors shown below.
I suspected a bad or wrong CF card, but have tried three different ones (three different manufacturers and sized, including Cisco, and from 512MB up to 2GB) with the exact same results.
Gone thru all the discussions already (really helped get me this far). Have all the files, including the cue-vm-license_12mbx_cme_7.0.6.pks, and have the default boot set to disk.
Ideas????
Remove: /mnt/dwnld/pkgdata/cue-vm-nl_NL-langpack.nm-aim.7.0.6.prt1
Remove: /mnt/dwnld/pkgdata/cue-vm-sv_SE-langpack.nm-aim.7.0.6.prt1
Remove: /mnt/dwnld/pkgdata/cue-vm-no_NO-langpack.nm-aim.7.0.6.prt1
Remove: /mnt/dwnld/pkgdata/cue-vm-fr_CA-langpack.nm-aim.7.0.6.prt1
Remove: /mnt/dwnld/pkgdata/cue-vm-pt_PT-langpack.nm-aim.7.0.6.prt1
Remove: /mnt/dwnld/pkgdata/cue-vm-tr_TR-langpack.nm-aim.7.0.6.prt1
Remove: /mnt/dwnld/pkgdata/cue-vm-hu_HU-langpack.nm-aim.7.0.6.prt1
Remove: /mnt/dwnld/pkgdata/cue-vm-en_GB-langpack.nm-aim.7.0.6.prt1
Remove: /mnt/dwnld/pkgdata/cue-vm-de_DE-langpack.nm-aim.7.0.6.prt1
Remove: /mnt/dwnld/pkgdata/cue-vm-da_DK-langpack.nm-aim.7.0.6.prt1
Remove: /mnt/dwnld/pkgdata/cue-vm-pt_BR-langpack.nm-aim.7.0.6.prt1
Remove: /mnt/dwnld/pkgdata/cue-vm-ko_KR-langpack.nm-aim.7.0.6.prt1
INIT: Sending processes the TERM signal
mount: /sys not mounted already, or bad option
mount: /dev/pts not mounted already, or bad option
mount: mount point /dev/shm does not exist
Remounting device 03:01 ... OK
Remounting device 01:00 ... OK
Done.
Restarting system.
Initializing memory.  Please wait. ... 256 MB SDRAM detected
BIOS Version: Cisco SE-AIM 01.02
BIOS Build date: 08/14/03
System Now Booting ...[BOOT-ASM]
Please enter '***' to change boot configuration:
Not a cisco supported CF. Please use cisco supported CF and reinstall the softw
are.
System Halted.
Everyone's tags (4)
Silver
Each AIM-CUE from Cisco is shipped with a signature on the flash card to verify that it is a genuine product. If the signature on the flash card is missing then the module will fail to boot. Did you get this module from Cisco or a Cisco partner?
Posted by WebUser Asad Raza from Cisco Support Community App
I got the AIM-CUE, with no CF, off EBay.
If what you say is correct, does that mean that all the AIM-CUE cards being sold every day on EBay will never work?
Silver
Some of them might work as long as they ship with the original CF cards.
All,
     I'm still having this problem. I've gone thru several CF cards, including a brand new 1GB Cisco card. Any ideas why this is happening.
     If you want to say it's the CF card, please don't, that's not it.
424
