Community Member
Problem loading unity on new MCS-7825-H4 server
Hey all,
I was wondering if anyone has run into loading unity on a new MCS-7825-H4 server.
I have tried loading it with the provided DVD and it looks like it is installing correctly.
It gets to where it needs to configure the raid controller with this messsage:
CAUTION
SATA RAID is not enabled in your system.
If you continue SATA RAID will be enabled and any pre-existing
software and data will be deleted.
Press Yes to continue or No to Exit
I have clicked yes to continue 4 times now and it just reboots and goes through the process again and gives me the same message.
Anyone seen this? i do have a tac case open. Thought i would run it by here as well..
thanks
Ken
Community Member
Re: Problem loading unity on new MCS-7825-H4 server
I may have figured it out.
After looking through all the dvd's, in the second dvd container which usually just has the different language cd's there is an actual DVD for the 7825-H4 server.
Trying it now
Community Member
Hi all,
I have a problem with the same server. I want to instal Unity connection 7 with DVD Cisco Unified Communication Manager 7. The wizard asked me to instal drivers. But i don't know which drivers i can instal.
128
