09-26-2013 03:17 PM - edited 03-16-2019 07:34 PM
Hi All:
I need an extra pair of eyes to look at this configuration for H.323 gateway.
PSTN>FXOTRUNK>PLAR>AA
Inbound calls are routed correctly but match dialpeer 0 and I am suspecting codec issue. Should this dial-peer 1 not match all calls on the inbound call leg prior to the outbound call leg to the AA? There are no translation patterns in the running configuration even though they are showing in the dialpeer.
dial-peer voice 1 pots
trunkgroup ALL_FXO
description FMM Incoming Calling
translation-profile incoming IncomingTranslation >>
incoming called-number .
direct-inward-dial
dial-peer voice 1000 voip
description Communications Manager Calling
destination-pattern 600
session target ipv4:x.x.x.x
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
Calling Number=, Called Number=, Voice-Interface=0x89A94500,
Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
Peer Info Type=DIALPEER_INFO_SPEECH
11686548: *Sep 26 12:23:59.897 MDT: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Result=NO_MATCH(-1) After All Match Rules Attempt
11686549: *Sep 26 12:23:59.897 MDT: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
11686550: *Sep 26 12:23:59.897 MDT: //-1/A5C844149469/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=
----- ccCallInfo IE subfields -----
cisco-ani=780xxxxxxx
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=600
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
cisco-redirectreason=0 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
11686551: *Sep 26 12:23:59.897 MDT: //-1/A5C844149469/CCAPI/cc_api_call_setup_ind_common:
Interface=0x89A94500, Call Info(
Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=600(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
Incoming Dial-peer=0, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=FALSE,
Source Trkgrp Route Label=ALL_FXO, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
11686552: *Sep 26 12:23:59.901 MDT: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
11686553: *Sep 26 12:23:59.901 MDT: :cc_get_feature_vsa malloc success
11686554: *Sep 26 12:23:59.901 MDT: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
11686555: *Sep 26 12:23:59.901 MDT: cc_get_feature_vsa count is 2
11686556: *Sep 26 12:23:59.901 MDT: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
11686557: *Sep 26 12:23:59.901 MDT: :FEATURE_VSA attributes are: feature_name:0,feature_time:2352397752,feature_id:3484
11686558: *Sep 26 12:23:59.901 MDT: //3484/A5C844149469/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=600(TON=Unknown, NPI=Unknown))
11686559: *Sep 26 12:23:59.901 MDT: //3484/A5C844149469/CCAPI/cc_process_call_setup_ind:
Event=0x89A3E898
11686560: *Sep 26 12:23:59.901 MDT: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=, Called Number=600, Peer Info Type=DIALPEER_INFO_SPEECH
11686561: *Sep 26 12:23:59.901 MDT: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=600
11686562: *Sep 26 12:23:59.901 MDT: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Result=Success(0) after DP_MATCH_DEST
11686563: *Sep 26 12:23:59.901 MDT: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=600, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
11686564: *Sep 26 12:23:59.901 MDT: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
List of Matched Outgoing Dial-peer(s):
1: Dial-peer Tag=1000
11686565: *Sep 26 12:23:59.901 MDT: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 600
11686566: *Sep 26 12:23:59.901 MDT: //3484/A5C844149469/CCAPI/ccCallSetContext:
Context=0x8C38ED18
11686567: *Sep 26 12:23:59.901 MDT: //3484/A5C844149469/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 3484 with tag 0 to app "_ManagedAppProcess_Default"
11686568: *Sep 26 12:23:59.905 MDT: //3484/A5C844149469/CCAPI/ccCallProceeding:
Progress Indication=NULL(0)
11686569: *Sep 26 12:23:59.905 MDT: //-1/A5C844149469/DPM/dpMatchPeersCore:
11686570: *Sep 26 12:23:59.905 MDT: //-1/A5C844149469/DPM/dpMatchPeersCore:
11686571: *Sep 26 12:23:59.905 MDT: //-1/A5C844149469/DPM/dpMatchPeersCore:
11686572: *Sep 26 12:23:59.905 MDT: //-1/A5C844149469/DPM/dpMatchSafModulePlugin:
11686573: *Sep 26 12:23:59.905 MDT: //-1/A5C844149469/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
11686574: *Sep 26 12:23:59.905 MDT: //-1/A5C844149469/DPM/dpMatchPeersCore:
11686575: *Sep 26 12:23:59.905 MDT: //-1/A5C844149469/DPM/dpMatchPeersCore:
11686576: *Sep 26 12:23:59.905 MDT: //-1/A5C844149469/DPM/dpMatchPeersCore:
11686577: *Sep 26 12:23:59.905 MDT: //-1/A5C844149469/DPM/dpMatchSafModulePlugin:
11686578: *Sep 26 12:23:59.905 MDT: //-1/A5C844149469/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
11686579: *Sep 26 12:23:59.905 MDT: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=600, Called Number=600, Peer Info Type=DIALPEER_INFO_SPEECH
11686580: *Sep 26 12:23:59.905 MDT: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
11686581: *Sep 26 12:23:59.905 MDT: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
11686582: *Sep 26 12:23:59.905 MDT: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
11686583: *Sep 26 12:23:59.905 MDT: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
11686584: *Sep 26 12:23:59.905 MDT: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=600, Called Number=, Voice-Interface=0x0,
Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
11686585: *Sep 26 12:23:59.905 MDT: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=1000
11686586: *Sep 26 12:23:59.905 MDT: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
11686587: *Sep 26 12:23:59.905 MDT: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
11686588: *Sep 26 12:23:59.905 MDT: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
11686589: *Sep 26 12:23:59.905 MDT: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
11686590: *Sep 26 12:23:59.905 MDT: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
11686591: *Sep 26 12:23:59.905 MDT: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
11686592: *Sep 26 12:23:59.905 MDT: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
11686593: *Sep 26 12:23:59.905 MDT: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
11686594: *Sep 26 12:23:59.905 MDT: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
11686595: *Sep 26 12:23:59.909 MDT: //-1/A5C844149469/DPM/dpMatchPeersCore:
11686596: *Sep 26 12:23:59.909 MDT: //-1/A5C844149469/DPM/dpMatchPeersCore:
11686597: *Sep 26 12:23:59.909 MDT: //-1/A5C844149469/DPM/dpMatchPeersCore:
11686598: *Sep 26 12:23:59.909 MDT: //-1/A5C844149469/DPM/dpMatchSafModulePlugin:
dialstring=600, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
11686599: *Sep 26 12:23:59.909 MDT: //-1/A5C844149469/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
11686600: *Sep 26 12:23:59.909 MDT: //3484/A5C844149469/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=FALSE, Mode=0,
Outgoing Dial-peer=1000, Params=0x8C393DC8, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
11686601: *Sep 26 12:23:59.909 MDT: //3484/A5C844149469/CCAPI/ccCheckClipClir:
In: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
11686602: *Sep 26 12:23:59.909 MDT: //3484/A5C844149469/CCAPI/ccCheckClipClir:
Out: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
11686603: *Sep 26 12:23:59.909 MDT: //3484/A5C844149469/CCAPI/ccCallSetupRequest:
Destination Pattern=600, Called Number=600, Digit Strip=FALSE
11686604: *Sep 26 12:23:59.909 MDT: //3484/A5C844149469/CCAPI/ccCallSetupRequest:
Redirect Number=, Display Info=
Account Number=, Final Destination Flag=TRUE,
Guid=A5C84414-260F-11E3-9469-E9DB525C8024, Outgoing Dial-peer=1000
11686605: *Sep 26 12:23:59.909 MDT: //3484/A5C844149469/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-username=
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=600
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
11686606: *Sep 26 12:23:59.909 MDT: //3484/A5C844149469/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x88EAD8E0, Interface Type=1, Destination=, Mode=0x0,
Call Params(Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=600(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=1000, Call Count On=FALSE,
Source Trkgrp Route Label=ALL_FXO, Target Trkgrp Route Label=, tg_label_flag=1, Application Call Id=)
11686607: *Sep 26 12:23:59.909 MDT: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
11686608: *Sep 26 12:23:59.909 MDT: :cc_get_feature_vsa malloc success
11686609: *Sep 26 12:23:59.909 MDT: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
11686610: *Sep 26 12:23:59.909 MDT: cc_get_feature_vsa count is 3
11686611: *Sep 26 12:23:59.909 MDT: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
11686612: *Sep 26 12:23:59.909 MDT: :FEATURE_VSA attributes are: feature_name:0,feature_time:2352395512,feature_id:3485
11686613: *Sep 26 12:23:59.909 MDT: //3485/A5C844149469/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
11686614: *Sep 26 12:23:59.909 MDT: //3485/A5C844149469/CCAPI/ccCallSetContext:
Context=0x8C393D78
11686615: *Sep 26 12:23:59.909 MDT: //3484/A5C844149469/CCAPI/ccSaveDialpeerTag:
11686616: *Sep 26 12:24:03.213 MDT: //3485/A5C844149469/CCAPI/cc_api_set_called_ccm_detected:
CallInfo(called ccm detected=TRUE ccmVersion 3)
11686617: *Sep 26 12:24:03.213 MDT: //3485/A5C844149469/CCAPI/cc_api_call_proceeding:
Interface=0x88EAD8E0, Progress Indication=NULL(0)
11686618: *Sep 26 12:24:03.217 MDT: //3485/A5C844149469/CCAPI/cc_api_set_called_ccm_detected:
11686619: *Sep 26 12:24:03.217 MDT: //3485/A5C844149469/CCAPI/cc_api_set_delay_xport:
CallInfo(delay xport=TRUE)
voice-port 0/1/0
trunk-group ALL_FXO 1
cptone CA
connection plar opx 600
description Analog Line
caller-id enable
voice-port 0/1/1
trunk-group ALL_FXO 2
cptone CA
caller-id enable
voice-port 0/1/2
trunk-group ALL_FXO 3
cptone CA
caller-id enable
voice-port 0/1/3
trunk-group ALL_FXO 4
cptone CA
caller-id enable
trunkgroup ALL_FXO
direct-inward-dial
dial-peer voice 911 pots
trunkgroup ALL_FXO
description FMM Emergency Calling
translation-profile outgoing CallingID
destination-pattern 911
forward-digits 3
dial-peer voice 9911 pots
trunkgroup ALL_FXO
destination-pattern 9911
forward-digits 3
dial-peer voice 780 pots
trunkgroup ALL_FXO
description FMM Local 10 digit Calling
destination-pattern 9780[2-9]......
forward-digits 10
dial-peer voice 587 pots
trunkgroup ALL_FXO
description FMM Long Distance Calling
destination-pattern 9587[2-9]......
forward-digits 10
dial-peer voice 110 pots
trunkgroup ALL_FXO
destination-pattern 91[2-9]..[2-9]......
forward-digits 11
dial-peer voice 411 pots
trunkgroup ALL_FXO
description FMM Service Calling
destination-pattern 9[2-8]11
forward-digits 3
dial-peer voice 9011 pots
trunkgroup ALL_FXO
description FMM International Calling
destination-pattern 9011.T
prefix 011
codec g711ulaw
no vad
regards,
John
09-26-2013 04:05 PM
John,
Your dial peer 1 pots is allocated to a trunk group called ALL_FXO.
Looking at your voice ports NONE of then are in that trunk group.
Just for a test can you change the trunk group on dial peer 1 to ALL_FXO 1
Then retest
Alex.
Please rate useful posts.
09-26-2013 04:24 PM
Hi Alex,
when i first looked at the voice ports i was thinking exactly the same thing, so i checked the options of that command and it was a preference.
So the voice ports are in order of preference from 1-4 but the trunkgroup is ALL_FXO. This must be true because all dialpeers outbound have ALL_FXO as well and calls work.
Im wondering when the outbound call leg is established there is a codec g711 command on dial peer 1000 - even though inbound call matches dial peer 0, would it even matter since it matches outbound dial peer 1000 on its way to AA and gets its codec there?
codec g711ulaw
no vad
BUT still dont know why dial peer 0 is matching inbound! Does the direct-inward-dial have to match the incoming called number . on the same dialpeer?
Would this work instead?
dial-peer voice 1 pots incoming called-number 600 direct-inward-dial
09-26-2013 05:07 PM
Hi Johnsnow,
My understanding is if it is an FXO you dont need a dial-peer to match incoming call because it's already taken care of the connection plar opx under the voice-port. Try removing the dial-peer voice 1 pots and make a call. Without that the call should still work.
09-27-2013 06:59 AM
Thanks, I have not thought about that on the PLAR. I will have to play with that configuration.
I tested some calls again and could see the call end to end successfully. I found out during this troubleshooting there was no AA application on the other end, it was terminating to UC mailbox. So the outbound call leg to CM dial peer gets used in this case and uses the g711 codec, no vad configuration as configured so that is what I wanted to see.
John
