problem of voice communication between a gateway 2901 and CUCM 8.5
hi
i have the next problem
I have outgoing but not incoming calls, I have configured my gateway as h323 in callmanager I got discharged, I can make calls to the PSTN (outcoming) and everything works fine, but incoming calls do not work, and the carrier sends me a voice message, which tells me that the call can not be answered because the phone is off hook or repair.
I've checked the settings on the gateway and everything looks good.
I share the computer's configuration.
Building configuration...
Current configuration : 8555 bytes
! Last configuration change at 19:33:36 UTC Tue Mar 25 2014 by Cysco
version 15.2
hostname ############
boot-start-marker
boot-end-marker
card type e1 0 1
enable secret 4 kKt2Se69p1vj8oXsVcOb4nVtT/YpLyKoYfbXdt49ZWc
no aaa new-model
network-clock-participate wic 1
ip cef
ip dhcp excluded-address 192.168.18.1
ip dhcp excluded-address 10.77.3.1
ip dhcp excluded-address 10.77.4.1
ip dhcp pool lan-user
 network 10.77.3.0 255.255.255.0
 default-router 10.77.3.1
 dns-server 10.2.1.70
ip dhcp pool movil-user
 network 10.77.4.0 255.255.255.0
 default-router 10.77.4.1
ip dhcp pool voice
 network 192.168.18.0 255.255.255.0
 default-router 192.168.18.1
 option 150 ip 192.168.12.10 192.168.12.11
 domain-name ######.net
ip domain name ######.net
no ipv6 cef
voice-card 0
 dsp services dspfarm
voice service voip
 no ip address trusted authenticate
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 h323
 sip
  registrar server expires max 600 min 60
voice class codec 1
 codec preference 1 g711ulaw
 codec preference 2 g711alaw
 codec preference 3 g729r8
voice register global
 max-dn 200
 max-pool 15
voice register pool  10
 id network 192.168.18.0 mask 255.255.255.0
 preference 1
 proxy 192.168.18.1
 voice-class codec 1
voice moh-group 1
 moh flash:/CUCM(MoH).wav
 description Internal MOH
 multicast moh 239.1.3.2 port 16384 route 192.168.18.1
license udi pid CISCO2901/K9 sn FTX1809808V
hw-module pvdm 0/0
redundancy
controller E1 0/1/0
 framing NO-CRC4
 ds0-group 0 timeslots 1-10 type r2-digital r2-compelled ani
 cas-custom 0
  country telmex
  category 2
  answer-signal group-b 1
  caller-digits 4
  dnis-digits min 1 max 4
  groupa-callerid-end
 description Controladora de voz a PSTN
ip ssh version 2
class-map match-any mark_datos-criticos
 match access-group name rpvm_datos-criticos
class-map match-any rpvm_datos-criticos
 match ip dscp cs2
 match ip dscp af31
 match ip dscp af32
 match ip dscp af33
class-map match-any rpvm_voz
 match ip dscp cs3
 match ip dscp cs5
 match ip dscp ef
class-map match-any mark_voz
 match access-group name rpvm_voz
class-map match-any rpvm_business
 match ip dscp cs1
 match ip dscp af21
 match ip dscp af22
 match ip dscp af23
class-map match-any mark_business
 match access-group name rpvm_business
policy-map pa12_lan
 class mark_voz
  set ip dscp ef
 class mark_datos-criticos
  set ip dscp af32
 class mark_business
  set ip dscp af22
 class class-default
  set ip dscp default
policy-map rpvm_pa12_out
 class rpvm_voz
  police cir percent 25
   conform-action transmit
   exceed-action drop
 class rpvm_datos-criticos
  bandwidth percent 52
  queue-limit 66 packets
 class rpvm_business
  bandwidth percent 16
  queue-limit 20 packets
 class class-default
  bandwidth percent 1
  queue-limit 32 packets
policy-map rpvm_pa12_in
 class rpvm_voz
   exceed-action drop
  police cir percent 50
   exceed-action transmit
 class rpvm_business
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 no ip address
 duplex auto
 speed auto
interface GigabitEthernet0/1
 description TRUNK-HACIA-SWITCH
 no ip address
 duplex full
 speed 1000
interface GigabitEthernet0/1.11
 description ADMON
 encapsulation dot1Q 11
 ip address 10.77.1.1 255.255.255.0
 h323-gateway voip interface
 h323-gateway voip bind srcaddr 10.77.1.1
interface GigabitEthernet0/1.13
 description LAN-user
 encapsulation dot1Q 13
 ip address 10.77.3.1 255.255.255.0
interface GigabitEthernet0/1.14
 description movile-user
 encapsulation dot1Q 14
 ip address 10.77.4.1 255.255.255.0
interface GigabitEthernet0/1.16
 description voice
 encapsulation dot1Q 16
 ip address 192.168.18.1 255.255.255.0
interface Serial0/0/0
 bandwidth 512
 ip address 187.219.41.178 255.255.255.252
 encapsulation ppp
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 187.219.41.177
ip sla auto discovery
snmp-server community redes2000 RW
snmp-server enable traps entity-sensor threshold
snmp-server host 10.2.1.13 version 2c redes2000
control-plane
call fallback active
voice-port 0/1/0:0
ccm-manager music-on-hold
mgcp profile default
sccp local GigabitEthernet0/1.16
sccp ccm 192.168.12.11 identifier 2 priority 2 version 7.0
sccp ccm 192.168.12.10 identifier 1 priority 1 version 7.0
sccp
sccp ccm group 1
 bind interface GigabitEthernet0/1.16
 associate ccm 1 priority 1
 associate ccm 2 priority 2
 associate profile 2 register CFB_#####
 associate profile 1 register XCODE_######
dspfarm profile 1 transcode
 codec g729abr8
 codec g729ar8
 codec g711alaw
 codec g711ulaw
 codec g722-64
 codec g729br8
 maximum sessions 4
 associate application SCCP
dspfarm profile 2 conference
 codec g729br8
 codec g729r8
 codec g729abr8
 codec g729ar8
 codec g711alaw
 codec g711ulaw
 codec g722-64
 maximum sessions 2
dial-peer voice 1 pots
 incoming called-number .
 direct-inward-dial
dial-peer voice 45 pots
 description CEL-LD
 shutdown
 destination-pattern 045..........
 port 0/1/0:0
 forward-digits all
dial-peer voice 3020 voip
 translation-profile outgoing 1
 destination-pattern 302..
 session target ipv4:192.168.12.10
 dtmf-relay h245-alphanumeric
 no vad
num-exp 7590 30202
sip-ua
 registrar ipv4:192.168.18.1 expires 600
gatekeeper
 shutdown
call-manager-fallback
 max-conferences 4 gain -6
 transfer-system full-consult
 ip source-address 192.168.18.1 port 2000
 max-ephones 25
 max-dn 50 dual-line
 moh "flash0:/CUCM(MoH).wav"
 multicast moh 239.1.1.1 port 16384 route 192.168.18.0 192.168.18.1
the gateway model 2901 and the Version 15.0(1r)M16.
the Gateway has SRST configuration, so when the SRST is active all calls works fine outcoming and incoming.
thank for your attention, greetings!
Did you reset the H.323
Did you reset the H.323 gateway in CUCM after adding it?  Is the inbound CSS on the H.323 gateway okay?
Hi Brian  yes, i reset the
Hi Brian
yes, i reset the gateway and the gateway okay
dude,  you have CUCM point to
dude,
you have CUCM point to:
 description ADMON
looking at your h225 and 245 debugs the gateway seems to bind with GigabitEthernet0/1.16  which has a different I address all together. what interface is used to route traffic from your gateway to your CUCM 192.168.12.10?   you need to sort this out first and make it consistent.
Please remember to rate useful posts, by clicking on the stars below.
VIP Super Bronze
Can you please configur the
Can you please configur the ff
service sequence-numbers
service timestamps debug datetime localtime msec
logging buffered 10000000 debug
no logging console
no logging monitor
default logging rate-limit
default logging queue-limit
Then enale the ff debugs
1. debug isdn q931
2. debug voip ccapi inout
3.debug h225 asn1
4. debug h245 asn1
<Enable session capture to txt file in terminal program.> (such as Putty)
then do the ff:
terminal length 0
NB: you need to enable the logs at the same time. Once you are done, attach the logs here
show logging
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Also make sure the H.323
Also make sure the H.323 gateway is added in CUCM as 10.77.1.1 since that's the address you binded to.
of curse the gateway is added
of curse the gateway is added in CUCM
Hello Mauro,You need to check
Hello Mauro,
You need to check is the call reaching to the call-manager from GW side. Try to collect the debug on GW and traces and call-manager side to check status of the calls whether it has been reaching to CUCM and the error message.
on GW collect Debug H245 asn1 and h225 ans1 and CCM traces on CUCM.
Br,
Nadeem Ahmed
Br, Nadeem Please rate all useful post.
of the debug h245 send this:
*Mar 25 22:17:46.327: //-1/208AA82F8057/CCAPI/cc_api_call_setup_ind_common:
   Sub Calling(TON=National, NPI=Unknown, Data=(, Length=34)
   Sub Called(TON=Unknown, NPI=Data, DatAP"'(AP<3, Length=3)cch323_ip_best_local_address: IP 192.168.18.1 found for bound IDB GigabitEthernet0/1.16term mon
and the debug h225 send this:
*Mar 25 22:21:32.875: //-1/A79321E4806C/CCAPI/cc_api_call_setup_ind_common:
so, i change the h323 of subinterface, it was before the subinterface 0/1.11 and now is on 0/1.16
197
