Community Member
Problem on forward internal calls to voice mail
Hi voice team,
     I configured on CME extension 4815 the option:
     call-forward busy 6800 -> VOICE MAIL EXTENSION
     call-forward noan 6800 timeout 10
     I have a problem in my CME because when i calling from my extension 9072 (CUCM) to CME extension 4815 after ringing 4 times, 4815 dont forward to voice mail 6800, the extension 4815 still ringing (the connection gets stuck), but when i call from external number to 4815, the 4815 forward to 6800 normally.
From my extension 4815 i can digit to voice mal normally too.
PS: attached are the sh run from my CME router.
Hello Thiago,
A quick quesiton, does all calls from CUCM to any Extn to CME 4815 does not work? How CME and CUCM is connected (Connection) ?
Br,
Nadeem
Please rate all useful post.
Br, Nadeem Please rate all useful post.
Community Member
Hello Nadeem, all calls to CME works fine. The CME is connected through SIP Ttrunk to CUCM.
Hall of Fame Super Red
Hi Thiago,
In addition to the good ideas from my friend Nadeem (+5 )
I might check out this similar thread;
https://supportforums.cisco.com/message/1093094#1093094
And;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/srnd/design/guide/clproc.html#wp1068478
Cheers!
Rob
"Seek it out and ye shall find  "
- OneRepublic
Re: Problem on forward internal calls to voice mail
Do not see call-forward pattern  in your below config.
telephony-service
max-ephones 42
max-dn 144
ip source-address 10.19.1.254 port 2000
service phone videoCapability 1
service dss
timeouts interdigit 20
timeouts busy 20
timeouts ringing 30
system message DUAS RODAS-CAM
time-zone 17
time-format 24
date-format dd-mm-yy
voicemail 6800
max-conferences 8 gain -6
moh flash:/musica.ulaw
transfer-system full-consult
secondary-dialtone 0
directory entry 1 004199418400 name JeanIT7
create cnf-files version-stamp Jan 01 2002 00:00:00
Just add call-forward pattern .T and make the test call,
@Rob thanks for the Hi5, I think you have already answered it.(+5) for you.
Br,
Nadeem
Community Member
I did it, but the problem persist, i need to add the transfer-pattern .T too ??
Yes add it and do no create cnf and create cnf.
Br,
Nadeem
Community Member
I add and do the cnf files, but the problem persist,
Can you try disabling this under voice-service voip, give it shot if didn't work we need to look into the debug why CME is not  even try do a transfer to the voicemail, the phone keep ringing and the originating side keep hearing the ringback for time.
voice service voip
 no supplementary-service h450.2
Br,
Nadeem
Community Member
Hi Nadeem, i made this but the problem persist.
Attached are the debug log:
Debug voice ccapi inout
Debug ccsip messages
Not work log
Calling extension: 9072
Called extension: 4815
Work log
Calling number: 4733729072
Called number: 4815
Voice mail number: 6800
Hi Thiago,
Was checking your CME router configuration , as per configuration the inbound dial-peer from CUCM is 10 .You said your CME router is configured as sip trunk but dial-peer is not configured as SIP peer.
dial-peer voice 10 voip
incoming called-number .
dtmf-relay h245-alphanumeric
no vad
What i think its matching the default dial-peer when you call from CUCM to CME , which is creating this problem. You can try this and let us know if that resolves your issue.
session protocol sipv2
no vad
Rate all the helpful post.
Manish
Community Member
I made this config, but not work. Internal calls keeping ringing and dont transfer to voice mail.
.Internal calls keeping ringing and dont transfer to voice mail.- what do you mean by that , from cme ext to cme ext its also the same issue?
Community Member
Yes, works normally.
CME tranfer to another CME extension and CME transfer to another CUCM extension.
The debugs are attached.
Not work
Work scenario
Called number: 4815
Community Member
Sorry Mauro Pasetto i delete your post unintentionally
Hi Thiago.
Log captured seems incomplete. Please upload a full output of the debug to analyze better what is happening.
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
Community Member
Its the full output log.
Community Member
Hi voice team,
The engineer Pablo Gonzales discovered that when the call hit Exchange, Exchange was requesting to moved temporarily to port 5065 on sip connection and however, GW(CME) was still sending the INVITE to exchange on port 5060.
So we issue a "no notify redirect ip2ip" on dial-peer 7 and this fix the issue. Now the calls are using port 5065 to Exchange and hitting Voicemail correctly.
305
