Community Member
Problem on FXS-DID
It's my time.....
I've a 4FSX-DID module, with dial-perr voice associated like this:
dial-peer voice 200 pots
description analog phone
destination-pattern 888
port 0/2/0
Connected to port 0/2/0, an analog phone.
If I call from inside, the analog phone rings correctly, and the caller hear that the destination phone is ringing correctly.
But, if I call that phone from outside, the analog phone rings correctly but the caller doesn't hear the well known ringing tone...
Sorry for my basic questions.
Thanks a lot.
Marco.
Hall of Fame Super Gold
Re: Problem on FXS-DID
Marco,
Where from are you calling the fxs ? An ephone? a BRI? When you call from another phone in the same wic, do you hear ringtone?
Community Member
I'm calling the fxs from an E1: in this case I hear nothing.
With internal phones I can hear ring tone correctly.
Tomorrow I'll test the call from other analog phones connected to the FXS module.
Thanks.
On debug isdn q931, you will see if the router is sending alerting; that should make the caller hear ringback. If it does but no ringback, one check with the telco should be done, but in case they can't help, there are workarounds.
Community Member
I've done some tests.
This is an External call that calls the fxo port:
Mar 29 11:59:43.218: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x4C00
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA18388
Preferred, Channel 8
Calling Party Number i = 0x0183, '335999999'
Plan:ISDN, Type:Unknown
Called Party Number i = 0xA1, '348999999'
Plan:ISDN, Type:National
Sending Complete
Mar 29 11:59:43.222: ISDN Se0/0/0:15 EVENT: process_rxstate: ces/callid 1/0x4A calltype 2 CALL_INCOMING
Mar 29 11:59:43.222: ISDN Se0/0/0:15 EVENT: call_incoming: call_id 0x004A, Guid = D0AE0F3C804B
Mar 29 11:59:43.234: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0xCC00
Channel ID i = 0xA98388
Exclusive, Channel 8
Mar 29 11:59:43.238: ISDN Se0/0/0:15 Q931: TX -> PROGRESS pd = 8 callref = 0xCC00
Progress Ind i = 0x8188 - In-band info or appropriate now available
Mar 29 11:59:55.138: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x4C00
Cause i = 0x839F - Normal, unspecified
Progress Ind i = 0x8288 - In-band info or appropriate now available
it seems that the alerting is missing...
I've specified in the E1 (where the external calls arrive) "sending-alert", but nothig changed:
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn overlap-receiving T302 2000
isdn incoming-voice voice
isdn send-alerting
isdn sending-complete
isdn outgoing display-ie
no cdp enable
In externals calls to Cisco phones or calls between FXS the ring tone is regularly instead.
Any idea?
Thanks a lot.
Hi Marco,
That is strange, config is correct but alerting is not sent. Which IOS is this? E.g., on an 12.4(4)XJ1 I have alerting correctly sent even if I didn't configure "isdn send-alerting":
Mar 29 12:56:51.439: ISDN Se0/2/0:15 Q931: RX <- SETUP pd = 8 callref = 0x1553
Sending Complete
Standard = CCITT
Channel ID i = 0xA98382
Exclusive, Channel 2
Progress Ind i = 0x8083 - Origination address is non-ISDN
Calling Party Number i = 0xA1, '06442****'
Called Party Number i = 0xA1, '64425****'
Mar 29 12:56:51.455: ISDN Se0/2/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x9553
Mar 29 12:56:51.471: ISDN Se0/2/0:15 Q931: TX -> ALERTING pd = 8 callref = 0x9553
Something you can try, but probably will not help, can you try to add a dollar sign "$" at the end of destination-pattern for the FXS ports ?
Community Member
Version 12.4(11)XJ
(c2800nm-spservicesk9-mz.124-11.XJ.bin)
Adding $ sign doesn't resolve the situation.
Can I ask you if it's normal this output?
voip#sh dspfarm
DSPFARM Configuration Information:
Admin State: DOWN, Oper Status: DOWN - Cause code: ADMIN_STATE_DOWN
Transcoding Sessions: 0(Avail: 0), Conferencing Sessions: 0 (Avail: 0)
Trans sessions for mixed-mode conf: 0 (Avail: 0), RTP Timeout: 600
Connection check interval 600 Codec G729 VAD: ENABLED
The other calls are working regularly...
Thanks.
I would go ahead and upgrade to XJ1 that is available on the ftp.cisco.com when logged with your CCO username and password.
I have the same installation/configuration and alerting is sent correctly for the FXS extensions. Only, I did not define any timer for "isdn overlap-receive".
The dspfarm show down because you haven't configured anything, this is normal.
Community Member
Thanks always for your precious advices.
I don't know how I have found this, but the command:
voice call send-alert
resolved my problem :)
" To enable the terminating gateway to send an alert message instead of a progress message after it receives a call setup message, use the voice call send-alert command in global configuration mode"
Marco.
This is good news Marco.
In fact the "isdn send-alerting" it an older command that may apply to data calls only.
The correct behavior by the router would be to send first call-progress to ack the setup, and then alerting when the destination is actually ringing.
Perhaps some bug in XJ(no 1) or an unseen configuration twist is causing the above to not happen in your installation.
Anyway as anyone that can fix his own problems your post got rated by me for that.
417
