Community Member
Problem registering other 6921 ip phones
Good Morning/Afternoon/Evening
i have recently configured CME 2951 with the version 8.6
when i try to add more ip phones they just dont register.
currently i have 3 working 2 6921 and 1 7942
Please see below:
#sh ephone
ephone-1[0] Mac:A44C.1148.0831 TCP socket:[1] activeLine:0 whisperLine:0 REGISTERED in SCCP ver 22/17 max_streams=1
mediaActive:0 whisper_mediaActive:0 startMedia:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:0 caps:8
IP:192.168.179.129 * 35042 6921  keepalive 2650 max_line 2 available_line 2
button 1: cw:1 ccw:(0 0)
  dn 2  number 501 CH1   IDLE         CH2   IDLE
Preferred Codec: g711ulaw
Lpcor Type: none
ephone-2[1] Mac:A44C.1147.E293 TCP socket:[2] activeLine:0 whisperLine:0 REGISTERED in SCCP ver 22/17 max_streams=1
IP:192.168.179.131 * 35803 6921  keepalive 41 max_line 2 available_line 2
  dn 3  number 502 CH1   IDLE         CH2   IDLE
Lpcor Type: none
ephone-3[2] Mac:5C50.15A9.C0E2 TCP socket:[4] activeLine:0 whisperLine:0 REGISTERED in SCCP ver 19/17 max_streams=5
mediaActive:0 whisper_mediaActive:0 startMedia:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:0 caps:9
IP:192.168.179.138 * 50218 7942  keepalive 111 max_line 2 available_line 2
  dn 1  number 500 CH1   IDLE         CH2   IDLE
Lpcor Type: none
ephone-4[3] Mac:A44C.1147.E21E TCP socket:[-1] activeLine:0 whisperLine:0 UNREGISTERED
mediaActive:0 whisper_mediaActive:0 startMedia:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:0 caps:0
IP:0.0.0.0* 0 Unknown 0  keepalive 0 max_line 0 available_line 0
  dn 4  number 503 CH1   DOWN         CH2   DOWN
Lpcor Type: none
ephone-5[4] Mac:A44C.1147.E1D1 TCP socket:[-1] activeLine:0 whisperLine:0 UNREGISTERED
  dn 5  number 504 CH1   DOWN         CH2   DOWN
Lpcor Type: none
this is my config :
CME_CCMZ#sh run
Building configuration...
Current configuration : 7034 bytes
! Last configuration change at 12:45:32 UTC Thu Aug 23 2012 by cilix
! NVRAM config last updated at 13:07:39 UTC Tue Aug 21 2012 by cilix
version 15.1
hostname CME_CCMZ
boot-start-marker
boot-end-marker
card type e1 0 1
logging buffered 51200 warnings
no aaa new-model
network-clock-participate wic 1
no ipv6 cef
ip source-route
ip cef
ip name-server 4.2.2.2
isdn switch-type primary-net5
crypto pki trustpoint TP-self-signed-2614193851
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2614193851
revocation-check none
rsakeypair TP-self-signed-2614193851
crypto pki certificate chain TP-self-signed-2614193851
certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32363134 31393338 3531301E 170D3132 30373139 31343030
  35335A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 36313431
  39333835 3130819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100EF07 981916E8 B70AD7F4 30AA3332 B9E2AA9D B16453E9 813E350B FA55A982
  A44857A9 864D61FC E6556D8A B9DC9321 C188BDB8 A9AF1569 2B074F2C 44C47CCD
  CF4271BA B7A1E457 7653CBD6 59D5CF7A 1D3D408E B49DDDD2 E83AEEA7 F3C9B328
  B6B941B8 2D3FD81E 89A97873 188B8FB4 40AA16A4 07EA69D0 51DAF2B4 D520A1A7
  EB1B0203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 1473692E 574B0F09 A4813FB1 F2C3A4E9 B449DE6B 55301D06
  03551D0E 04160414 73692E57 4B0F09A4 813FB1F2 C3A4E9B4 49DE6B55 300D0609
  2A864886 F70D0101 05050003 8181002B 1454158E A74615FC 28C10C0C 22873C52
  D300F4BC 64E9255E 03803642 27D45D94 1D129659 CCCB2171 8ABA601E 97501FCC
  69847901 BFCF90A3 96B884E8 D30DB96B F30BA699 BE604AE1 80274B4B 9198FF89
  A0D4DFC5 2C41F185 E30B0784 2A7A4B5A 1544A1F7 A9C0F756 7AE3127A D6790A0B
  E48EFDEF 7F73C37F 81CC5B54 EC675D
        quit
voice-card 0
codec complexity medium
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service h450.7
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
no supplementary-service sip handle-replaces
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
  bind control source-interface GigabitEthernet0/0
  bind media source-interface GigabitEthernet0/0
voice class codec 1
codec preference 1 g711ulaw
voice register global
mode cme
source-address 192.168.179.2 port 5060
max-dn 100
max-pool 50
license udi pid CISCO2951/K9 sn FGL1623103H
hw-module pvdm 0/0
username cilix privilege 15 secret 4 WXflj66qPYunKhR1Sx5jv8grQracWG440463lTKXWxY
redundancy
controller E1 0/1/0
framing NO-CRC4
pri-group timeslots 1-31
no ip ftp passive
interface Embedded-Service-Engine0/0
no ip address
shutdown
ip address 192.168.179.2 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/0/0
no ip address
shutdown
negotiation auto
interface Serial0/1/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.179.1
ip route 192.168.1.25 255.255.255.255 192.168.179.100
ip route 192.168.1.226 255.255.255.255 192.168.179.100
ip route 192.168.1.244 255.255.255.255 192.168.179.100
nls resp-timeout 1
cpd cr-id 1
tftp-server flash:6921_SCCP/BOOT69xx.0-0-0-14.zz.sgn alias BOOT69xx.0-0-0-14.zz.sgn
tftp-server flash:6921_SCCP/DSP69xx.0-0-0-11-124120.zz.sgn alias DSP69xx.0-0-0-11-124120.zz.sgn
tftp-server flash:6921_SCCP/SCCP69xx.9-3-1-3.loads alias SCCP69xx.9-3-1-3.loads
tftp-server flash:6921_SCCP/SCCP69xx.9-3-1-3.zz.sgn alias SCCP69xx.9-3-1-3.zz.sgn
tftp-server flash:7942_7962_SCCP/SCCP42.9-3-1-1S.loads alias SCCP42.9-3-1-1S.loads
tftp-server flash:7942_7962_SCCP/apps42.9-3-1TH2-5.sbn
tftp-server flash:7942_7962_SCCP/cnu42.9-3-1TH2-5.sbn alias cnu42.9-3-1TH2-5.sbn
tftp-server flash:7942_7962_SCCP/cvm42sccp.9-3-1TH2-5.sbn alias cvm42sccp.9-3-1TH2-5.sbn
tftp-server flash:7942_7962_SCCP/dsp42.9-3-1TH2-5.sbn alias dsp42.9-3-1TH2-5.sbn
tftp-server flash:7942_7962_SCCP/jar42sccp.9-3-1TH2-5.sbn alias jar42sccp.9-3-1TH2-5.sbn
tftp-server flash:7942_7962_SCCP/term42.default.loads alias term42.default.loads
tftp-server flash:7942_7962_SCCP/term62.default.loads alias term62.default.loads
control-plane
voice-port 0/1/0:15
voice-port 0/2/0
voice-port 0/2/1
mgcp profile default
sccp local GigabitEthernet0/0
sccp
dial-peer voice 2 pots
description Moveis ou Celulares
destination-pattern 98[246].......
port 0/2/0
forward-digits 9
dial-peer voice 1 pots
description Nacionais e Locais
destination-pattern 92[13-9]......
port 0/2/1
forward-digits 8
dial-peer voice 3 pots
description Internacionais
destination-pattern 900T
port 0/2/1
prefix 00
dial-peer voice 4 voip
description dummy_DialPeer_For_Primary_CUCM
shutdown
session target ipv4:192.168.179.2
codec g711ulaw
gatekeeper
shutdown
telephony-service
no auto-reg-ephone
max-ephones 50
max-dn 100
ip source-address 192.168.179.2 port 2000
system message G. Camargo Correa
load 7942 flash:SCCP42.9-3-1-1S.loads
load 6921 DSP69xx.0-0-0-11-124120
max-conferences 8 gain -6
transfer-system full-consult
ephone-dn  1  dual-line
number 500
label 500
description Recepcao
ephone-dn  2  dual-line
number 501
label 501
ephone-dn  3  dual-line
number 502
label 502
ephone-dn  4  dual-line
number 503
label 503
ephone-dn  5  dual-line
number 504
label 504
ephone  1
mac-address A44C.1148.0831
max-calls-per-button 2
type 6921
button  1:2
ephone  2
mac-address A44C.1147.E293
type 6921
button  1:3
ephone  3
mac-address 5C50.15A9.C0E2
type 7942
button  1:1
ephone  4
mac-address A44C.1147.E21E
type 6921
button  1:4
ephone  5
mac-address A44C.1147.E1D1
type 6921
button  1:5
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
exec-timeout 0 0
logging synchronous
login local
transport input telnet ssh
scheduler allocate 20000 1000
end
i have tried adding via CLI and via Cisco Configuration Professional but no success.
please give me some feedback on this issue.
Patrick
1 REPLY
Community Member
Hi Patrick,
Try factory reset for the phones which are not registering.
710
