Community Member
PROBLEM Replication between Subscriber and Publisher!!!
How can I resolve the solution, that is displaying on the picture?
The problem is that Publisher DB doesn't upgrade Subscriber DB
Community Member
Re: PROBLEM Replication between Subscriber and Publisher!!!
UP!
which version?
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
Hall of Fame Super Red
Hi Alexandr,
I'm guessing this is a 4.x version of CCM, if so, here is a very good doc;
Using DBLHelper to Reestablish a Broken Cisco CallManager Cluster SQL Subscription
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00801e7ddf.shtml
Hope this helps!
Rob
Community Member
but I don't have DBHelper file on my Clusters. How can I download it? the reason is that I don't have privilege access for downloading files from cisco. Can You help me?
Community Member
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=General&topicID=.ee6c82b&CommCmd=MB?cmd=pass_through&location=outline@^1@@.1dde3772/3#selected_message
javalenc
java
Community Member
One question. Can be the problem between Publisher and Subscriber when each other don't see for a long period? Example: The network is down during 3-4 hours.
Community Member
I want to understand all possible problems that can occur such problem in the future
if a phone is registered to a SUB and no connection to PUB is on, no changes to the DB can be made, no new phones, no auto-registration, no CFA changes, no EM login or logout, anything related to a DB change won't work if a SUB is not able to reach the PUB
javalenc
java
after that a cluster reboot would be a good idea to resync the SDL layer and you may use the DBLHelper to reestablish the agreements. but if it's messed up really bad you would need to do it manually
javalenc
java
Community Member
1)After run DBhelper should I do anything else(maybe rerun some service etc.)?
2)Is this procedure with DBhelper safely? Because I use working cluster of CCM.
in some cases you need to restart the database layer monitor to get this to work.
the procedure is safe, though it can cause high CPU if the DBs are really not in sync and a lot of information needs to be replicated
javalenc
java
Community Member
the link upper is saying:
The SQL replication relies on NetBios name resolution. Make sure the c:\winnt\system32\drivers\etc\"lmhosts" file is populated if needed.
As I see, I have files lmhosts and hosts, but my real IP address is situated in file hosts, not lmhosts. What should I do in this case? Modify "lmhosts" file? How does file "lmhost" is linked by CCM. Where I can see this?
yes, modify the lmhosts file
javalenc
java
Community Member
Unpack DBLHelper.zip and place it under C:\Program files\Cisco\Bin on Publisher. Run the Utility, Hit republish. It will take couple of minutes so wait for it to complete the job.
Should I run only button "REPUBLISH" or REINITILIEZE too?
from the same doc you're posting all the questions:
The Republish button deletes the current subscription and recreates it. The Reinitialize button reinitializes all subscriptions and starts the snapshot agent. It also attempts to rebuild the subscription with the current database.
javalenc
java
Community Member
Is this DBHelper is good?
Community Member
Now I have the problem, that was earlier. Phones don't register. On the phone displaying "Configuring IP"
Community Member
After I user DBhelper, I receive error from the job that export phones:
Job 'telefon' : Step 1, 'select telefon' : Began Executing 2008-05-28 11:00:00
Msg 4604, Sev 16: There is no such user or group 'report'. [SQLSTATE 42000]
Community Member
Here is the situation on the cluster. As I see, there isn't database CDR on the subscriber.... :(
CDR DB HAS NEVER BEEN IN A SUBSCRIBER IN ANY VERSION, IT'S ONLY ON THE PUB
javalenc
java
Community Member
And what about report user? what rights he should have on subscriber? And what about error that appears about job?
at this point you better raise a TAC
javalenc
java
379
