Problem sending faxes from Brooktrout through h.323 gateway
I have a RightFax server configured with a Brooktrout card. It sends Faxes via h.323 through a Cisco voice gateway router.
I have two of these RightFax servers. One is having no problem sending through a different gateway configured the same way, and one is experiencing call failures. The Brooktrout card is licensing for 24 channels, so I don't think that is the issue.
My gateway setup:
isdn switch-type primary-ni
voice class h323 1
  h225 timeout tcp establish 5
voice class h323 2
  h225 timeout tcp establish 3
  call start fast
voice translation-rule 1
rule 1 /^31720417/ /417/
rule 2 /^31720418/ /418/
voice translation-profile fax
translate called 1
(these are for inbound faxes to the RightFax server)
dial-peer voice 10 pots
description outgoing dialpeer
preference 2
destination-pattern 9.T
incoming called-number .
direct-inward-dial
port 0/0/0:23
(for outbound)
dial-peer voice 101 voip
translation-profile outgoing fax
destination-pattern 3172041[7-8]..
progress_ind setup enable 3
session target ipv4:10.100.1.41
voice-class codec 2
voice-class h323 2
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
(this is the RightFax server that is working)
dial-peer voice 102 voip
description To pla-2k3-ipfx-01
preference 1
session target ipv4:10.6.1.41
voice-class codec 2
voice-class h323 2
(this is the one that can't send out)
This is the error I am getting on the gateway when trying to dial out:
Apr 11 19:44:02.201: ISDN Se0/0/0:23 Q931: TX -> SETUP pd = 8  callref = 0x23F8
Bearer Capability i = 0x9090A2
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98397
Exclusive, Channel 23
Called Party Number i = 0xA1, '16305050125'
Plan:ISDN, Type:National
Apr 11 19:44:02.281: ISDN Se0/0/0:23 Q931: RX <- CALL_PROC pd = 8  callref = 0xA3F8
PLA-c2821-RTR-MDF-01#
Apr 11 19:44:02.285: ISDN Se0/0/0:23 Q931: RX <- PROGRESS pd = 8  callref = 0xA3F8
Cause i = 0x8081 - Unallocated/unassigned number
ot sure what is going on here. Other calls go through this gateway just fine ...
1 ACCEPTED SOLUTION
Colin,
What I was asking was if the same fax attempt was successful on the working fax server? Both have the same destination pattern in dial peer 101/102 (3172041[7-8]...). Your called number from the debug shows a number 163....
That was the only thing I saw from your configuration.
Steven
Colin,
Your debug shows the called number is different from the destination pattern provided. Does this same exact fax work over the other gateway?
http://www.cisco.com/en/US/partner/tech/tk801/tk379/technologies_tech_note09186a008012e95f.shtml
Steven
Steven:
Wouldn't the pots dial peer be used for the called number?
preference 2
direct-inward-dial
port 0/0/0:23
It is set up the same way on the other gateway for the other server
Or am I missing something?
Colin,
Steven
Steve:
The other FAX server is on another subnet and uses
dial-peer voice 111 voip
preference 1
destination-pattern 3314576[0-3]..
voice-class codec 2
voice-class h323 2
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none
as its inbound voip dial-peer.
Same codecs, same translation-profile parameters (which shouldn't matter here), and fax protocol type
409
