ā05-04-2010 09:52 AM - edited ā03-15-2019 10:36 PM
PROBLEM TO ACCESS TO GLOBAL DIRECTORY IN THE CCM WEB. CCM 4.1(3)sr3a
When I try in the CCM web administration to the Global directory I obtain the next error:
Active Server Pages error 'ASP 0115'
Unexpected error
/ccmadmin/usersidebar.asp
A trappable error (E06D7363) occurred in an external object. The script cannot continue running.
In the Event Viwer there is the next:
Date 04/05/2010 Source: Active Server Pages
Time 11:33
Type Error Event ID 5
Computer OTAWCM1
Error: File /CCMAdmin/userprefsbasiclist.asp Unexpected error. A trappable error (E06D7363) occurred in an external object. The script cannot continue running..
For additional information specific to this message please visit the Microsoft Online Support site located at: http://www.microsoft.com/contentredirect.asp.
After of all this the DC Directory Server service is Disabled, I change it to automatic and started. I reset this service and the ISS Admin service and I canĀ“t to log in the CCM web administration.
I have done this: ://www.cisco.com/en/US/partner/products/sw/voicesw/ps556/products_tech_note09186a0080557ba5.shtml to sincronizate the passwords but I canĀ“t access.
If I reset the CCM server all works ok during a time but the problem happens again.
Thanks for your help.
Esteban
Solved! Go to Solution.
ā05-13-2010 08:36 AM
Esteban,
Can you access other pages in CCM or no? What browser are you using to access the CCM Admin page?
Hailey
ā05-11-2010 10:15 PM
Do you have AD integration?
Are you using MLA?
How long it takes before it breaks again?
HD space engough in server?
Happens the same to publisher and other susbcribers?
Which OS version?
Any AV/CSA ?
You need to go at least to the latest SR 4.1.3/ Please check above and you can open a TAC case to further look into this, but take into account that having those servers still in that version means proper maintenance and SW updates have not been applied in years!
ā05-13-2010 08:31 AM
Hi gogasca
Just have a server "Publisher" where the CCM is integrated with the AD external.
OS is OS 2000.4.2sr5a
I've been checking the HD space, 72.5 GB, 13GB used space.
I found procedures performed by Cisco Web does not work:
Esteban,
Hailey
ā05-14-2010 02:28 AM
Hi Hailey
Both with https: / / xxxx / ccmadmin from my PC (Internet Explorer 8), for VNC -> WEB CCM Administration (Internet Explorer 6), I can not access the "user" and "global directory", but the rest of menu ok.
When I restart the server if you let me access without problems but when certain time elapses, the problem starts.
We make an update of the version to 4.1 (3) sr8a.
Greetings and thanks
ā05-17-2010 08:53 AM
Hi all
- When I access the area of User-> Add a New User, through the administration of the CCM website, in the Event Viewer I see the error:
Error: File /CCMAdmin/usersidebar.asp Unexpected error. A trappable error (E06D7363) occurred in an external object. The script cannot continue running..
Error: File /CCMAdmin/usermainpage.asp Unexpected error. A trappable error (E06D7363) occurred in an external object. The script cannot continue running..
- When I access the area of the Global Directory, through the administration of the CCM website, in the Event Viewer I see the error:
regards
