Problem to add any parameters
Hi Guys,
I am trying configure any parameter: region, location, user, etc.. and I receive the message "error on page". This version is CCM 4.2.1. What could is occuring? any ideia?
Thank You,
Wilson
1 ACCEPTED SOLUTION
Re: Problem to add any parameters
goga means don't do it from a remote computer, either do a RDP, VNC or directly on the console from the server.
java
if this helps, please rate
java
www.cisco.com/go/pdi
Green
Do it directly from the server and make sure you authenticate twice if you get java auth window
Hi Gogasca,
I am sorry, but I don't understand that you speak? Could be more clear?
Thank You,
Wilson
java
java
100
