Problem to do the call with mgcp protocol
Hi Guys,
My customer have a gateway 2801 with 04 Fxo port (using 03 port's only in this moment) and the CCM version 5.1.3 working with mgcp protocol. We are have the following problem: In fallback mode its possible to do 03 Calls or receive 03 call the same time. In mode normal (using mgcp) Its possible receive 03 call the same time, but, only is possible to do a one call by time. Anybody have any idea about that is occurring?
Wilson
Re: Problem to do the call with mgcp protocol
Do you have dial-peers that PLAR the destination number for each FXO port?
example:
voice-port 0/1/0
connection plar 201
caller-id enable
voice-port 0/1/1
connection plar 202
caller-id enable
voice-port 0/1/2
connection plar 203
caller-id enable
voice-port 0/1/3
connection plar 204
caller-id enable
Or you can set the default-destination under call manager fallback
Or use the alias command.
See the SRST admin guide
Hi Rycks,
The configuration alredy previous. The port number 0/0/0 stopped worked and change the configuration in port 0/0/3. In callmanager I delete port 0/0/0 and create port 0/0/3. The bellow the configuration of gateway:
voice-port 0/0/0
translation-profile outgoing Local_DDD_DDI_0800_0300
supervisory disconnect dualtone mid-call
cptone BR
timeouts call-disconnect 5
timeouts wait-release 5
timing hookflash-out 50
timing guard-out 500
timing sup-disconnect 50
connection plar 3003
station-id name NSB
station-id number 44323377
voice-port 0/0/1
cptone BR
station-id name Teste
station-id number 44180975
voice-port 0/0/2
cptone BR
connection plar 3004
station-id number 44323961
dial-peer voice 1 pots
service mgcpapp
port 0/0/0
forward-digits all
dial-peer voice 2 pots
service mgcpapp
port 0/0/1
forward-digits all
dial-peer voice 3 pots
service mgcpapp
port 0/0/2
forward-digits all
dial-peer voice 4 pots
service mgcpapp
port 0/0/3
forward-digits all
dial-peer voice 10 pots
description CHAMADAS SRST
destination-pattern 0T
port 0/0/0
forward-digits all
dial-peer voice 20 pots
port 0/0/1
forward-digits all
dial-peer voice 30 pots
port 0/0/2
forward-digits all
dial-peer voice 40 pots
port 0/0/3
forward-digits all
dial-peer voice 999000 pots
service mgcpapp
port 0/0/0
dial-peer voice 999001 pots
service mgcpapp
port 0/0/1
dial-peer voice 999002 pots
service mgcpapp
port 0/0/2
dial-peer voice 999003 pots
service mgcpapp
port 0/0/3
Wilson
115
