Community Member
Problem to login Cisco Unity Connection Administration !!!
Hi!
I need your help please, I am stuck
I tried the login to access the web based Cisco Unified Communications Operating System Administration and Disaster Recovery System, the logging was successful.
I used the same login to access Cisco Unity Connection Administration and Cisco Unified Serviceability, the logging failed with the following error message"Log on failed -Invalid User ID or Password"
Please let me know what is wrong.
Alain
Re: Problem to login Cisco Unity Connection Administration !!!
Theres a separate user for those systems that was configured during install, use that user to log in.
java
if this helps, please rate
www.cisco.com/go/pdi
VIP Super Bronze
Also, if you don't recall the username or password for the application-level UIs, it can be reset.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cli_ref/8_6_1/cli_ref_861.html#wp222740
Please remember to rate helpful responses and identify helpful or correct answers.
195
