10-14-2009 11:40 AM - edited 03-15-2019 08:04 PM
Checking the status menu of my 7941 it show me the SCCP41.8-5-3S version, this was upgraded from CUCM v7.
Now I need put this phone in a CME7 installation. It is working fine, but the phone show me the âerrorâ word when it try to upgrade the firmware from CME7 on every reset.
I downloaded the latest CME 7 files. The cme-124-24T.zip file and extract the 7941-7961-sccp.8-4-2S.tar content. Also I have the cme-full-7.1.0.1.tar file.
I extract the 7941 files using the archive tar /xtract tftp://xxxx/7941-7961-sccp.8-4-2S.tar flash:/phones command and executing the following tftp-server and load commands:
tftp-server flash:/phones/7941-7961-sccp/apps41.8-4-1-23.sbn alias apps41.8-4-1-23.sbn
tftp-server flash:/phones/7941-7961-sccp/cnu41.8-4-1-23.sbn alias cnu41.8-4-1-23.sbn
tftp-server flash:/phones/7941-7961-sccp/cvm41sccp.8-4-1-23.sbn alias cvm41sccp.8-4-1-23.sbn
tftp-server flash:/phones/7941-7961-sccp/dsp41.8-4-1-23.sbn alias dsp41.8-4-1-23.sbn
tftp-server flash:/phones/7941-7961-sccp/jar41sccp.8-4-1-23.sbn alias jar41sccp.8-4-1-23.sbn
tftp-server flash:/phones/7941-7961-sccp/SCCP41.8-4-2S.loads alias SCCP41.8-4-2S.loads
tftp-server flash:/phones/7941-7961-sccp/term41.default.loads alias term41.default.loads
tftp-server flash:/phones/7941-7961-sccp/term61.default.loads alias term61.default.loads
telephony-service
load 7941 SCCP41.8-4-2S
Can somebody tell me what is the error in this configuration?. Why the phone is showing the "error" word ?
Thanks.
Solved! Go to Solution.
10-14-2009 11:46 AM
Witj cme 7.1, you do not need anymore to configure tftp-server, just configure
load 7941 SCCP41.8-4-2S.loads
You can observe files correctly loads with "debug tftp events" and "term mon".
10-14-2009 11:46 AM
10-21-2009 06:12 AM
Iam still having problems with this....
I tested the following command unter telephony-service
user-locale ES load CME-locale-es_ES-Spanish-7.0.1.1.tar (work fine!!)
But when I try :
load 7945 7945-7965-sccp.8-4-2S.tar
or
load 7945 SCCP45.8-4-2S.loads
the ip phone still showing the error message when it try upgrade the firmware.
Im using cme 7.1.0.1 and 12.4(24T) ios.
I put the firwmare files in the root of the flash: , in the flash:/phones directory and
in the its directory.
Im using the cnf-file location flash:
what is the trick?
10-21-2009 06:17 AM
The correct command is load xxx.loads
Files must be in root directory.
Remove any tftp-server comamnds
Sometime reloading the router helps a lot.
If still problem take "debug tftp events" with "term mon" and you will see what happens.
