Problem while CUE initialization
I'm getting the following error while the CUE initialization using the CUE GUI initialization wizard...
"JTAPI login failed. Error while determining CCM version -1."
What could be problem?? can someone give your inputs on this..
I'm using NM-CUE with CUE version 2.3 and the CCM version 4.2(3)...
1 ACCEPTED SOLUTION
Re: Problem while CUE initialization
While initializing, CUE tries to access a file at CCM server at the following URL: http:///CCMPluginsServer/CiscoJTAPIClient.exe
IIS in the CallManager is configured to "require SSL" in the CCMPluginsServer directory. Disable this requirement and install will continue.
Hall of Fame Super Silver
Is CTI Manager service started on CM? Did you configure CTI Ports, etc?
Chris
Yes, it solved my problem.
But should I have to enable the SSL requirement again??..
Yes, it should not influence on further work of both CCM&CUE.
186
