Problem with 2921 and fax t.38
telefonie
Level 5
Level 5
Hello Group
we have to renew our gateways and have now new 2921 router with pri interfaces.
now we have Problems sending and receving faxes with t.38. Most of the faxes can be sent and received without any problem. However some are not transmitted at all. Has anyone a similar situation and can give me some hints on how to configure the gateways and waht IOS we could load in order to get all the faxes to be sent and received.
thank you for any hints
Regrds Reto
GW#sh ver
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.3(2)T, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Thu 28-Mar-13 11:05 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
GW uptime is 14 weeks, 4 days, 2 hours, 23 minutes
System restarted at 11:53:45 MEZ Thu May 30 2013
System image file is "flash:c2900-universalk9-mz.SPA.153-2.T.bin"
Last reload type: Normal Reload
Last reload reason: power-on
Cisco CISCO2921/K9 (revision 1.0) with 479232K/45056K bytes of memory.
Processor board ID xxx
3 Gigabit Ethernet interfaces
124 Serial interfaces
1 terminal line
4 Channelized E1/PRI ports
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
Jorge Armijo
Level 4
Level 4
Please start describing the call flow, devices involve, protocols and sh commands from the GW:
sh run
sh version
show isdn status
show controller t1/e1
You may also check the follwoing link:
http://www.cisco.com/en/US/products/sw/voicesw/ps5640/products_configuration_example09186a0080bf23f2.shtml
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
