07-01-2012 08:34 AM - edited 03-16-2019 11:57 AM
Hi everybody,
In our office we buy new phones 7965 and 6945, 7965 is working, but the 6945 dosen't work in SRST mode.
Any ideas ??
CUCM - 7.1.5
6945 - SCCP-6945.9-2-2-4
Router - 3925 - Version 15.2(3)T1
Tks,
07-01-2012 09:16 AM
Are you sure you are running it as SCCP not SIP?
Can you post "debug ephone register" and "sho run"?
Is the phone registered properly in CUCM and does its device pool reference proper SRST reference?
Chris
07-03-2012 08:17 AM
Yes, is running in SCCP.
Show run:
call-manager-fallback
secondary-dialtone 0
max-conferences 8 gain -6
transfer-system full-consult
timeouts interdigit 6
ip source-address 10.154.116.2 port 2000 strict-match
max-ephones 200
max-dn 400
system message primary SURVIVAL MODE
transfer-pattern .T
time-format 24
date-format dd-mm-yy
in debug shows nothing on the 6945 only the 7965
7965 and 6945 using the same device pool.
07-03-2012 08:45 AM
Can you post the debug?
Chris
12-04-2012 06:50 PM
Hello Sir,
I am running into the same issue as well. My 6945 phones will not register to CUCM 8.6 with gateway running 15.2(3) T1 code on it running SRST. Did you have any luck getting those phones registered on SRST mode?
Kindly let me know please.
Jeesh
