Problem with 6945 - dont register in SRST
Hi everybody,
In our office we buy new phones 7965 and 6945, 7965 is working, but the 6945 dosen't work in SRST mode.
Any ideas ??
CUCM - 7.1.5
6945 - SCCP-6945.9-2-2-4
Router - 3925 - Version 15.2(3)T1
Tks,
Everyone's tags (3)
Hall of Fame Super Silver
Are you sure you are running it as SCCP not SIP?
Can you post "debug ephone register" and "sho run"?
Is the phone registered properly in CUCM and does its device pool reference proper SRST reference?
Chris
Re: Problem with 6945 - dont register in SRST
Yes, is running in SCCP.
Show run:
call-manager-fallback
secondary-dialtone 0
max-conferences 8 gain -6
transfer-system full-consult
timeouts interdigit 6
ip source-address 10.154.116.2 port 2000 strict-match
max-ephones 200
max-dn 400
system message primary SURVIVAL MODE
transfer-pattern .T
time-format 24
date-format dd-mm-yy
in debug shows nothing on the 6945 only the 7965
7965 and 6945 using the same device pool.
Can you post the debug?
Chris
Hello Sir,
I am running into the same issue as well. My 6945 phones will not register to CUCM 8.6 with gateway running 15.2(3) T1 code on it running SRST. Did you have any luck getting  those phones registered on SRST mode?
Kindly let me know please.
Jeesh
652
