12-02-2008 04:09 AM - edited 03-15-2019 02:51 PM
Hello everybody,
I have a problema with 7914 module.I make a new button template with SPEED DIAL BFL. I configure each field and everything is ok , but when the user make a logout and log in all the speed dial disapear , i think that is a hardware problem.
Carlos
12-10-2008 03:13 PM
Does the user have the speed dials set up in the extension mobility profile? Are you logging into a 7940 or a 7960? The profile that the customer is using has how many speed dials in the template?
12-11-2008 12:46 PM
Just to confirm have you set the following
To enable BLF in the cluster:
1. Enable the BLF for Call Lists (enterprise parameter).
2. Allow subscriptions for presence cluster wide (service parameter)
To allow phones to use BLF:
1. Configure phone button templates using speed dial BLF.
2. Assign templates to phones.
3. Add BLF speed dials to phones.
4. Configure subscription CSS on the phones.
Paul
