problem with auto attended 2 "Application aa in dial-peer 1000 not found"
still not workng .
please check my configuration again after imade some chages.
application
service app-b-acd-aa flash:bacdprompts/app-b-acd-aa-2.1.2.2.tcl
  param max-time-call-retry 600
  param voice-mail 5000
  paramspace english index 1
  param service-name app-b-acd
  param number-of-hunt-grps 2
  param handoff-string aa
  paramspace english language en
  param dial-by-extension-option 5
  param max-time-vm-retry 2
  param max-extension-length 4
  paramspace english location flash:
  param aa-pilot 0217155841
  param second-greeting-time 60
  param welcome-prompt _aa1_welcome.au
  param call-retry-timer 15
service app-b-acd flash:bacdprompts/app-b-acd-2.1.2.2.tcl
  param app-b-acd-len 10
  param aa-hunt3 5100
  param aa-hunt4 5220
  param app-b-acd-manager-debugs 1
dial-peer voice 1000 pots
incoming called-number 0217155841
port 1/1/1
the line still hang up the moment i call.
please help me
Re: problem with auto attended 2 "Application aa in dial-peer 10
I wonder where are your hunts defined.
You might want to add this:
ephone-hunt 1 sequential
pilot 5100
list 4010, 4011
timeout 5
where 4010 and 4011 are DNs defined that are supposed to ring.
hope this helps, if it does, please rate.
cheers.
i created the hunt group  like you suggested but it doesn't show in the configuration that i entered
run the following command
call application voice load app-b-acd-aa
if still have the problem, collect debugs
deb voip ccapi inout
deb vpm signal
deb voice application script
thanks,
Yan
Hall of Fame Super Gold
Already discussed in another thread, please do not post duplicates.
thanks evry body for your replaies , now when i call the pilot number of the AA service the line is opened and there is no measage heared.
this measage apear in the router when i call "B-ACD service is started"
maybe the problem is form the audio prmpt file from the flash is corupted or som thing .
please help me.
application
  param aa-hunt3 5100
  param aa-hunt4 5220
port 1/1/1
this is the debug:
   Transfer Number Is Null
*Nov  1 17:51:04.707: htsp_process_event: [1/1/0, FXOLS_PROCEEDING, E_HTSP_RELEASE_REQ]fxols_offhook_release
*Nov  1 17:51:04.707: htsp_timer_stop
*Nov  1 17:51:04.707: htsp_timer_stop2
*Nov  1 17:51:04.707: htsp_timer_stop3
*Nov  1 17:51:04.707: [1/1/0] set signal state = 0x4 timestamp = 0
*Nov  1 17:51:04.707: htsp_timer - 2000 msec
*Nov  1 17:51:04.707: //25/6E9A930C8062/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x29E368C8, Tag=0x0, Call Id=25,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
*Nov  1 17:51:04.707: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Nov  1 17:51:04.707: :cc_free_feature_vsa freeing 2A53DD08
*Nov  1 17:51:04.707:  vsacount in free is 0
*Nov  1 17:51:04.975: htsp_process_event: [1/1/0, FXOLS_GUARD_OUT, E_DSP_SIG_0110]
*Nov  1 17:51:06.707: htsp_process_event: [1/1/0, FXOLS_GUARD_OUT, E_HTSP_EVENT_TIMER]fxols_guard_out_timeout
*Nov  1 17:51:06.707: htsp_process_event: [1/1/0, FXOLS_ONHOOK, E_DSP_SIG_0100]
*Nov  1 17:51:08.615: htsp_process_event: [1/1/0, FXOLS_ONHOOK, E_DSP_SIG_0000]fxols_onhook_ringing
*Nov  1 17:51:08.615: htsp_timer - 125 msec
*Nov  1 17:51:08.743: htsp_process_event: [1/1/0, FXOLS_WAIT_RING_MIN, E_HTSP_EVENT_TIMER]fxols_wait_ring_min_timer
*Nov  1 17:51:08.743: htsp_timer - 10000 msec
*Nov  1 17:51:09.703: htsp_process_event: [1/1/0, FXOLS_RINGING, E_DSP_SIG_0100]
*Nov  1 17:51:09.703: fxols_ringing_not
*Nov  1 17:51:09.703: htsp_timer_stop
*Nov  1 17:51:09.703: htsp_timer_stop3 htsp_setup_ind
*Nov  1 17:51:09.703: [1/1/0] get_local_station_id calling num= calling name= calling time=11/01 17:51  orig called=
*Nov  1 17:51:09.703: //-1/7195838C8066/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=0   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
*Nov  1 17:51:09.703: //-1/7195838C8066/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x29E368C8, Call Info(
   Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=1000, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
*Nov  1 17:51:09.703: //-1/7195838C8066/CCAPI/ccCheckClipClir:
   In: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
*Nov  1 17:51:09.703: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Nov  1 17:51:09.703: :cc_get_feature_vsa malloc success
*Nov  1 17:51:09.703:  cc_get_feature_vsa count is 1
*Nov  1 17:51:09.703: :FEATURE_VSA attributes are: feature_name:0,feature_time:710139152,feature_id:26
*Nov  1 17:51:09.703: //26/7195838C8066/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown))
*Nov  1 17:51:09.703: htsp_process_event: [1/1/0, FXOLS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]
*Nov  1 17:51:09.703: fxols_wait_setup_ack:
*Nov  1 17:51:09.703: [1/1/0] set signal state = 0xC timestamp = 0fxols_check_auto_call
*Nov  1 17:51:09.703: //26/7195838C8066/CCAPI/cc_process_call_setup_ind:
   Event=0x29DCF730
*Nov  1 17:51:09.703: //26/7195838C8066/CCAPI/ccCallSetContext:
   Context=0x2A550E68
*Nov  1 17:51:09.707: //26/7195838C8066/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 26 with tag 1000 to app "_ManagedAppProcess_app-b-acd-aa"
*Nov  1 17:51:09.707: //26/7195838C8066/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
*Nov  1 17:51:09.707: //26/7195838C8066/CCAPI/cc_api_get_transfer_info:
*Nov  1 17:51:09.707: htsp_process_event: [1/1/0, FXOLS_PROCEEDING, E_HTSP_RELEASE_REQ]fxols_offhook_release
*Nov  1 17:51:09.707: htsp_timer_stop
*Nov  1 17:51:09.707: htsp_timer_stop2
*Nov  1 17:51:09.707: htsp_timer_stop3
*Nov  1 17:51:09.707: [1/1/0] set signal state = 0x4 timestamp = 0
*Nov  1 17:51:09.707: htsp_timer - 2000 msec
*Nov  1 17:51:09.707: //26/7195838C8066/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x29E368C8, Tag=0x0, Call Id=26,
*Nov  1 17:51:09.707: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Nov  1 17:51:09.707: :cc_free_feature_vsa freeing 2A53DD08
*Nov  1 17:51:09.707:  vsacount in free is 0
*Nov  1 17:51:09.975: htsp_process_event: [1/1/0, FXOLS_GUARD_OUT, E_DSP_SIG_0110]
*Nov  1 17:51:11.707: htsp_process_event: [1/1/0, FXOLS_GUARD_OUT, E_HTSP_EVENT_TIMER]fxols_guard_out_timeout
*Nov  1 17:51:11.707: htsp_process_event: [1/1/0, FXOLS_ONHOOK, E_DSP_SIG_0100]
*Nov  1 17:51:13.615: htsp_process_event: [1/1/0, FXOLS_ONHOOK, E_DSP_SIG_0000]fxols_onhook_ringing
*Nov  1 17:51:13.615: htsp_timer - 125 msec
*Nov  1 17:51:13.743: htsp_process_event: [1/1/0, FXOLS_WAIT_RING_MIN, E_HTSP_EVENT_TIMER]fxols_wait_ring_min_timer
*Nov  1 17:51:13.743: htsp_timer - 10000 msec
*Nov  1 17:51:14.703: htsp_process_event: [1/1/0, FXOLS_RINGING, E_DSP_SIG_0100]
*Nov  1 17:51:14.703: fxols_ringing_not
*Nov  1 17:51:14.703: htsp_timer_stop
*Nov  1 17:51:14.703: htsp_timer_stop3 htsp_setup_ind
*Nov  1 17:51:14.703: [1/1/0] get_local_station_id calling num= calling name= calling time=11/01 17:51  orig called=
*Nov  1 17:51:14.703: //-1/74907373806A/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
*Nov  1 17:51:14.703: //-1/74907373806A/CCAPI/cc_api_call_setup_ind_common:
*Nov  1 17:51:14.703: //-1/74907373806A/CCAPI/ccCheckClipClir:
*Nov  1 17:51:14.703: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Nov  1 17:51:14.703: :cc_get_feature_vsa malloc success
*Nov  1 17:51:14.703:  cc_get_feature_vsa count is 1
*Nov  1 17:51:14.703: :FEATURE_VSA attributes are: feature_name:0,feature_time:710139152,feature_id:27
*Nov  1 17:51:14.703: //27/74907373806A/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
*Nov  1 17:51:14.703: htsp_process_event: [1/1/0, FXOLS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]
*Nov  1 17:51:14.703: fxols_wait_setup_ack:
*Nov  1 17:51:14.703: [1/1/0] set signal state = 0xC timestamp = 0fxols_check_auto_call
*Nov  1 17:51:14.703: //27/74907373806A/CCAPI/cc_process_call_setup_ind:
   Event=0x29DCF730
*Nov  1 17:51:14.703: //27/74907373806A/CCAPI/ccCallSetContext:
   Context=0x2A552170
*Nov  1 17:51:14.707: //27/74907373806A/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 27 with tag 1000 to app "_ManagedAppProcess_app-b-acd-aa"
*Nov  1 17:51:14.707: //27/74907373806A/CCAPI/ccCallDisconnect:
*Nov  1 17:51:14.707: //27/74907373806A/CCAPI/cc_api_get_transfer_info:
*Nov  1 17:51:14.707: htsp_process_event: [1/1/0, FXOLS_PROCEEDING, E_HTSP_RELEASE_REQ]fxols_offhook_release
*Nov  1 17:51:14.707: htsp_timer_stop
*Nov  1 17:51:14.707: htsp_timer_stop2
*Nov  1 17:51:14.707: htsp_timer_stop3
*Nov  1 17:51:14.707: [1/1/0] set signal state = 0x4 timestamp = 0
*Nov  1 17:51:14.707: htsp_timer - 2000 msec
*Nov  1 17:51:14.707: //27/74907373806A/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x29E368C8, Tag=0x0, Call Id=27,
*Nov  1 17:51:14.707: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Nov  1 17:51:14.707: :cc_free_feature_vsa freeing 2A53DD08
*Nov  1 17:51:14.707:  vsacount in free is 0
*Nov  1 17:51:15.299: htsp_process_event: [1/1/0, FXOLS_GUARD_OUT, E_DSP_SIG_0110]
*Nov  1 17:51:16.707: htsp_process_event: [1/1/0, FXOLS_GUARD_OUT, E_HTSP_EVENT_TIMER]fxols_guard_out_timeout
*Nov  1 17:51:16.707: htsp_process_event: [1/1/0, FXOLS_ONHOOK, E_DSP_SIG_0100]
Router#
*Nov  1 17:54:14.707: //-1/xxxxxxxxxxxx/CCAPI/ccAppShutdownMode:
   ccAppShutdownMode: remove it from the queue
Router#
*Nov  1 18:05:37.135: htsp_process_event: [1/1/0, FXOLS_ONHOOK, E_DSP_SIG_0000]fxols_onhook_ringing
*Nov  1 18:05:37.135: htsp_timer - 125 msec
*Nov  1 18:05:37.263: htsp_process_event: [1/1/0, FXOLS_WAIT_RING_MIN, E_HTSP_EVENT_TIMER]fxols_wait_ring_min_timer
*Nov  1 18:05:37.263: htsp_timer - 10000 msec
*Nov  1 18:05:38.223: htsp_process_event: [1/1/0, FXOLS_RINGING, E_DSP_SIG_0100]
*Nov  1 18:05:38.223: fxols_ringing_not
*Nov  1 18:05:38.223: htsp_timer_stop
*Nov  1 18:05:38.223: htsp_timer_stop3 htsp_setup_ind
*Nov  1 18:05:38.223: [1/1/0] get_local_station_id calling num= calling name= calling time=11/01 18:05  orig called=
*Nov  1 18:05:38.223: //-1/77432434806E/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
*Nov  1 18:05:38.223: //-1/77432434806E/CCAPI/cc_api_call_setup_ind_common:
please help me
zdh
param handoff-string aa,the
param handoff-string aa,the aa name should be exactly the same one as you put at service app-b-acd-aa flash:bacdprompts/app-b-acd-aa-2.1.2.2.tcl. And where is param service-name command?
337
