Problem with B-ACD CME 7.1 overlap with 0.
I configured the following B-ACD, It has  problem when I try to reach extension with option " dial by extension".
Menu option  is " if yoy know extension number dial 1, for sales 2, for credit 3, dial 0 or hold on the line if you want to be assisted by operartor".
after pressing 1 , if I  try to dial extension 0104, just the first digit 0 is accepted. immediately the call is  routed to  ephone-hunt 4 that correspond to operator.
all extension begins with 01XX.
How can I avoid this issue?
application
service aa flash:app-b-acd-aa-3.0.0.2.tcl
  param number-of-hunt-grps 4
  paramspace english index 1
  param dial-by-extension-option 1
  param handoff-string aa
  paramspace english language en
  param max-time-vm-retry 2
  param aa-pilot 0100
  param max-extension-length 4
  paramspace english location flash:
  param second-greeting-time 45
  param call-retry-timer 5
  param voice-mail 4000
  param max-time-call-retry 120
  param service-name queue
service queue flash:app-b-acd-3.0.0.2.tcl
  param aa-hunt3 1003
  param queue-len 5
  param aa-hunt4 1004
  param aa-hunt2 1002
  param queue-manager-debugs 1
dial-peer voice 20 pots
service aa
incoming called-number 0100
port 0/1/0:1
forward-digits 4
ephone-hunt 2 sequential
pilot 1002
list 162, 142, 161, 131, 152, 112, 173, 140
final 1004
timeout 10, 10, 10, 10, 10, 10, 10, 10
ephone-hunt 3 sequential
pilot 1003
list 0110, 0145, 0123, 0151, 0111
final 1004
ephone-hunt 4 sequential
pilot 1004
list 0101
timeout 10
ephone-dn  4  octo-line
number 0104
pickup-group 5003
label 0104
ephone  4
mac-address xxxxxxxx
ephone-template 1
type 7940
keep-conference drop-last
button  1:4
Re: Problem with B-ACD CME 7.1 overlap with 0.
Hi Filiberto
DTMF option "0" routes the call to the operator. By default, the highest aa-huntX group is defined as the operator one. Here's the sample configuration which I followed to configure my CME.
Call-Queue and AA Tcl Scripts in Flash Memory
Router(config)#application
Router(config-app)#service queue flash:app-b-acd-3.0.0.2.tcl
Router(config-app-param)#param number-of-hunt-grps 3
! -- MUST BE SET. Tells the system how many entries are present in the menu
Router(config-app-param)#param aa-hunt1 6100
! -- Menu option 1 goes to 6100
Router(config-app-param)#param aa-hunt2 6101
! -- Menu option 2 goes to 6101
!-- DTMF option "0" routes the call to the operator. By default, the highest aa-huntX group is defined as the operator one
Router(config-app-param)#param aa-hunt10 1000
! -- Here I put aa-hunt10 to 1000 where 1000 is the extension of the operator
Router(config-app-param)#param queue-len 15
Router(config-app-param)#param queue-manager-debugs 1
Here's the link for BACD configuration for your reference.
Lavanya
Hi Lavanya,
thanks a lot for your explanation.
I understand the default option "0", but in this case the issue comes up after dialing "1"  (option that correspond when extension number is known) then a prompt  is listened " enter extension number".
in this case  all extension begins with 0  (01XX).
regards
Hall of Fame Super Gold
Can you take "debug voice application scripts" with "term mon", when pressing 1 and then 0.
Hi Paolo,
Thanks a lot for your suggestions.
I run the commands you recommended me.I tried with extension number and  0118 and 0104
I can't see in the logs the moment when I dial 1 an then extension number 0104 or 0118.
in all tries I just see destinatino hunt group =1004
Something weird happends because yesterday I can not dial 0104, today I could enter extension 0118 and 0104. I haven't change anything in config.
I'll try once again after office hour because I don't know if there is a period of time where the call is routed directly to operator ;eventhough I haven't defined that option.
regards
360
