problem with calls between 2 routers
I want to configure a call which will ring on a phone through a PSTN line situated on the router of the branch office. The call is initiated from the head quarter.But it does not work. When the call is initiated, when I look the voice call status I see nothing. It seems as there is no dial peer. Can someone help ?
This the configuration of the dial-peer on the router of the head quarter:
dial-peer voice 200 voip
destination-pattern 899201282
voice-class codec 1
session target ipv4:10.128.36.3
dtmf-relay h245-alphanumeric
On the Branch office this is the dial-peer which is configured:
dial-peer voice 899201282 pots
port 1/0/12
forward-digits 8
Thanks in advance !
1 REPLY
Re: problem with calls between 2 routers
implementation ipt,
The dial peer at headquarters will be a pots dial peer if I am understanding your situation correctly. You want a station (phone) off of the router to go through PSTN to hit a phone at the branch.
I would "debug dialpeer" on your gateway and see if a dial peer matches with your outbound call to see if anything is matching. Let me know.
-Shikamaru
94
