Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Problem with CDR Report
Dear all,
I am using CCM 5.1. Suddenly I am facing a problem to generate the Call Report by CDR. Last some days In my Server Outgoing calls not Generating but incoming call is genrating normally.
plz help me as soon as possible.
Thanks & Regards
Madhab
thanks
Anonymous
N/A
Re: Problem with CDR Report
Under Select Call Types, Select Outgoing under Select QOS, Make sure that you have selected all the parameters.
Confirm whether CDR files are populated with the correct call classification codes.
hii
yes I am confirmed about that. bcz what parameter I have selected here the same I am selected for another cluster. and that cluster report is generating properly.
so I can't understand whats wrong with this cluster.
regards
madhab
try restarting service..
137
