04-17-2007 11:41 PM - edited 03-14-2019 09:01 PM
I have CDR version: 4.0(0.24).
The latest record for billing data and CallDetailRecord was 29 Dec 2006.
Where I can find what was the problem and what I have to do that it is up to date.
Solved! Go to Solution.
04-18-2007 03:51 PM
Hi Vlaho,
This document describes why this might happen and how to resolve this issue;
Data is Absent in Reports Created by the CAR Tool
From this good doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a008056bd4e.shtml
Hope this helps!
Rob
04-18-2007 03:51 PM
Hi Vlaho,
From this good doc;
Hope this helps!
Rob
04-26-2007 07:55 AM
Hi Rob,
I have restarted the Cisco CAR Scheduler service and it works.
But, some other problem happened. I tried to
purge the ART database with procedure (as in document):
Select Start > Programs > Microsoft SQL Server > Query Analyzer.
but I couldn't log in with sa password. I have sa password but I don't know why it doesn't work. Maybe you have some idea?
04-26-2007 08:15 AM
Hi Vlaho,
Good stuff! I am pretty sure that you need to use the Directory Manager username/password.
Hope this helps!
Rob
