Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
problem with CIPC call forwarding
Guys,
Please help me. My client has a 7960 phone configured. He prefers using the CIPC phone instead because he prefers the microphone. I tried configuring call forward to his cell phone but it does not work . Please advice me on how to solve the problem.
ephone-dn  56  dual-line
number 154 no-reg both
pickup-group 7
label xxx 154
name xxx
call-forward busy 099
call-forward noan 989226446321 timeout 10
corlist incoming In001-015-8
huntstop channel
ephone-dn  137  dual-line
number 007 no-reg both
name Group7
call-forward noan 099 timeout 10
ephone  56
video
mac-address 0021.5555.13B3
ephone-template 1
username "xxx" password xxx
type 7960
button  1o56,137
ephone  59
mac-address 50E5.4950.BDAB
username "RomanovIV"
type CIPC
button  1o56,137
I have tried it on a test call but there is no sucess
ephone-dn  5  dual-line
number 999 no-reg both
pickup-group 7
label Faith_Test 999
name Faith_Test
call-forward noan 989268993633 timeout 10
huntstop channel
ephone  6
mac-address 1111.2222.3333
username "Faith_Test"
type CIPC
button  1:5
Does this configuration affect the call forwarding and limit it to only 3 digits ?
transfer-pattern 9.T
transfer-pattern ...
transfer-pattern 8.T
Everyone's tags (4)
1 ACCEPTED SOLUTION
VIP Super Bronze
Faith,
Three things that we see is this
1. The CIPC is redirecting the call properly
Called Number=989268993633(TON=Unknown, NPI=Unknown),
   Redirect Number=999, Display Info=Support
2. The second thing is that the voip leg shows us that the correct number is passed to the POTS leg with outgoing dial-peer 34
cisco-username=Support
   ----- ccCallInfo IE subfields -----
   cisco-ani=701000105
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=989268993633
3. The debug isdn shows us what is going on at the POTS leg. The leading 9 is been stripped..
Calling Party Number i = 0x0081, '701000105'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '89268993633'
Now question is why is the 9 stripped off. Without seeing your config I am only taking a guess. And my guess is that you have
1. either configure destination-pattern 9T on dial-peer 34 and by default pots dial-peer will strip the 9 or any defined digit
2. Or configured the wrong forward digits length on dial-peer voice 34 pots.
To resolve this you need to do the ff:
1. Either configure a prefix 9 on that dial-peer or configure forward-digits 12 on it. Please know that all calls will be sent to the PSTN with the 9. If you only want to send this particular number with 9 then you need to create a differenet dial-peer and apply the suggestions I mentioned above
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
VIP Super Bronze
You need call-forward pattern .T under telephony-service.
Transfer-pattern ... (will limit xfer of calls to only 3 digits)
"There is a wideness in God's mercy Like the wideness of the sea.There's a kindness in His justice Which is more than liberty"
Thank you.
Call forward pattern is already configured but it still does not forward the calls
call-forward pattern ...
VIP Super Bronze
Remove the "call-forward pattern ..." and try again. Leave the call-forward pattern .T in place
That still does not work. What else can i check?
VIP Super Bronze
Try and remove this
Then do a test again and send me a debug voip ccapi inout and debug isdn q931 if you are using ISDN
aokanlawon I am still in a dilemma. My currect configuration is this :
ephone-dn  10  dual-line
pickup-group 7
name Faith_Test
ephone  6
type CIPC
button  1:10
I have noticed that the 9 is being dropped. By the was, i tried sth like this without the prefix and there was a connection to God knows where. But i read that we always have to include the dialed prefix (98):
call-forward noan 9268993633 timeout 10
Jul 12 12:07:10.965 YEKT: %IPPHONE-6-REG_ALARM: 14: Name=SEP0023049B0E66 Load= SCCP11.8-5-2S Last=UCM-closed-TCP
Jul 12 12:07:19.297 YEKT: //-1/0031A2D20B01/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-ani=701000105
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=1#705900999
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Jul 12 12:07:19.297 YEKT: //-1/0031A2D20B01/CCAPI/cc_api_call_setup_ind_common:
   Interface=0xC08D825C, Call Info(
   Calling Number=701000105,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=1#705900999(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=2000, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=207764
Jul 12 12:07:19.297 YEKT: //-1/0031A2D20B01/CCAPI/ccCheckClipClir:
   In: Calling Number=701000105(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
   Out: Calling Number=701000105(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Jul 12 12:07:19.297 YEKT: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jul 12 12:07:19.297 YEKT: :cc_get_feature_vsa malloc success
Jul 12 12:07:19.297 YEKT:  cc_get_feature_vsa count is 5
Jul 12 12:07:19.297 YEKT: :FEATURE_VSA attributes are: feature_name:0,feature_time:1772202416,feature_id:306539
Jul 12 12:07:19.297 YEKT: //207764/0031A2D20B01/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=701000105(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=1#705900999(TON=Unknown, NPI=Unknown))
Jul 12 12:07:19.301 YEKT: //207764/0031A2D20B01/CCAPI/cc_process_call_setup_ind:
   Event=0x7070D9A8
Jul 12 12:07:19.301 YEKT: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 1#705900999
Jul 12 12:07:19.301 YEKT: //207764/0031A2D20B01/CCAPI/ccCallSetContext:
   Context=0x69A3F600
   >>>>CCAPI handed cid 207764 with tag 2000 to app "_ManagedAppProcess_Default"
Jul 12 12:07:19.301 YEKT: //207764/0031A2D20B01/CCAPI/ccCallProceeding:
Jul 12 12:07:19.305 YEKT: //207764/0031A2D20B01/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=20167, Params=0x69A32D60, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Jul 12 12:07:19.305 YEKT: //207764/0031A2D20B01/CCAPI/ccCheckClipClir:
   Destination Pattern=999$, Called Number=999, Digit Strip=TRUE
   Called Number=999(TON=Unknown, NPI=Unknown),
   Redirect Number=, Display Info=Support
   Account Number=Support, Final Destination Flag=TRUE,
   Guid=0031A2D2-9369-E1FF-0B01-3E010A0A0A2E, Outgoing Dial-peer=20167
Jul 12 12:07:19.305 YEKT: //207764/0031A2D20B01/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-ani=701000105
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=999
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Jul 12 12:07:19.305 YEKT: //207764/0031A2D20B01/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x7327A3B8, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=701000105,(Calling Name=Support)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=999(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=20167, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Jul 12 12:07:19.305 YEKT: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jul 12 12:07:19.305 YEKT: :cc_get_feature_vsa malloc success
Jul 12 12:07:19.305 YEKT:  cc_get_feature_vsa count is 6
Jul 12 12:07:19.305 YEKT: :FEATURE_VSA attributes are: feature_name:0,feature_time:1772189200,feature_id:306540
Jul 12 12:07:19.305 YEKT: //207765/0031A2D20B01/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
Jul 12 12:07:19.305 YEKT: //207765/0031A2D20B01/CCAPI/ccCallSetContext:
   Context=0x69A32D10
Jul 12 12:07:19.305 YEKT: //207764/0031A2D20B01/CCAPI/ccSaveDialpeerTag:
Jul 12 12:07:19.305 YEKT: //207765/0031A2D20B01/CCAPI/cc_api_update_call_info:
   Interface=0x7327A3B8, Call Id=0x32B95
Jul 12 12:07:19.309 YEKT: //207765/0031A2D20B01/CCAPI/cc_api_call_proceeding:
   Interface=0x7327A3B8, Progress Indication=NULL(0)
Jul 12 12:07:19.309 YEKT: //207765/0031A2D20B01/CCAPI/cc_api_call_alert:
   Interface=0x7327A3B8, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
Jul 12 12:07:19.313 YEKT: //207765/0031A2D20B01/CCAPI/cc_api_call_alert:
   Call Entry(Retry Count=0, Responsed=TRUE)
Jul 12 12:07:19.313 YEKT: //207764/0031A2D20B01/CCAPI/ccCallAlert:
   Call Entry(Responsed=TRUE, Alert Sent=TRUE)
Jul 12 12:07:19.313 YEKT: //207765/0031A2D20B01/CCAPI/cc_api_get_called_ccm_detected:
   CallInfo(ccm detected=0)
Jul 12 12:07:19.313 YEKT: //207765/0031A2D20B01/CCAPI/ccCallFeature:
   Feature Type=25, Call Id=207765
Jul 12 12:07:19.313 YEKT: //207764/0031A2D20B01/CCAPI/ccCallNotify:
   Data Bitmask=0x7, Call Id=207764
Jul 12 12:07:19.317 YEKT: //207764/0031A2D20B01/CCAPI/cc_api_get_delay_xport:
   CallInfo(delay xport=FALSE)
Jul 12 12:07:22.373 YEKT: %IPPHONE-6-REG_ALARM: 24: Name=SEP0023049B0E66 Load= SCCP11.8-5-2S Last=Phone-Reg-Rej
Jul 12 12:07:22.393 YEKT: %IPPHONE-6-REG_ALARM: 14: Name=SEP0023049B0E66 Load= SCCP11.8-5-2S Last=UCM-closed-TCP
Jul 12 12:07:22.441 YEKT: %IPPHONE-6-REG_ALARM: 14: Name=SEP0023049B0E66 Load= SCCP11.8-5-2S Last=UCM-closed-TCP
Jul 12 12:07:22.445 YEKT: %IPPHONE-6-REG_ALARM: Name=ATA22900406E101 Load=ATA030203SCCP051201A.zup Last=Initialized
Jul 12 12:07:28.237 YEKT: //207760/768A93A1B6D5/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0xC1B05090, Call Id=207760
   Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Jul 12 12:07:28.237 YEKT: //207750/768A93A1B6D5/CCAPI/ccConferenceDestroy:
   Conference Id=0xB139, Tag=0x0
Jul 12 12:07:28.237 YEKT: //207750/768A93A1B6D5/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0xB139, Source Interface=0x68E37AFC, Source Call Id=207750,
   Destination Call Id=207760, Disposition=0x0, Tag=0x0
Jul 12 12:07:28.237 YEKT: //207760/768A93A1B6D5/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0xB139, Source Interface=0xC1B05090, Source Call Id=207760,
   Destination Call Id=207750, Disposition=0x0, Tag=0x0
Jul 12 12:07:28.237 YEKT: //207750/768A93A1B6D5/CCAPI/cc_generic_bridge_done:
Jul 12 12:07:28.237 YEKT: //207750/768A93A1B6D5/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Jul 12 12:07:28.237 YEKT: //207750/768A93A1B6D5/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
Jul 12 12:07:28.237 YEKT: //207760/768A93A1B6D5/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Jul 12 12:07:28.237 YEKT: //207760/768A93A1B6D5/CCAPI/cc_api_get_transfer_info:
Jul 12 12:07:28.241 YEKT: //207760/768A93A1B6D5/CCAPI/cc_api_call_feature:
   Feature Type=6, Interface=0xC1B05090, Call Id=207760
Jul 12 12:07:28.241 YEKT: //207760/768A93A1B6D5/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0xC1B05090, Tag=0x0, Call Id=207760,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Jul 12 12:07:28.241 YEKT: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jul 12 12:07:28.241 YEKT: :cc_free_feature_vsa freeing 69A199E8
Jul 12 12:07:28.241 YEKT:  vsacount in free is 5
Jul 12 12:07:28.257 YEKT: %ISDN-6-DISCONNECT: Interface Serial0/0/0:0  disconnected from 3422949866 , call lasted 98 seconds
Jul 12 12:07:28.261 YEKT: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0xD780
        Cause i = 0x8090 - Normal call clearing
Jul 12 12:07:28.281 YEKT: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x5780
        Cause i = 0x83BB - Unknown cause value
Jul 12 12:07:28.281 YEKT: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0xD780
Jul 12 12:07:28.285 YEKT: //207750/768A93A1B6D5/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x68E37AFC, Tag=0x0, Call Id=207750,
Jul 12 12:07:28.285 YEKT: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jul 12 12:07:28.285 YEKT: :cc_free_feature_vsa freeing 69A19048
Jul 12 12:07:28.285 YEKT:  vsacount in free is 4
Jul 12 12:07:29.313 YEKT: //207765/0031A2D20B01/CCAPI/cc_api_call_disconnected:
   Cause Value=19, Interface=0x7327A3B8, Call Id=207765
   Call Entry(Responsed=TRUE, Cause Value=19, Retry Count=0)
Jul 12 12:07:29.313 YEKT: //207764/0031A2D20B01/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
Jul 12 12:07:29.313 YEKT: //207765/0031A2D20B01/CCAPI/cc_api_get_transfer_info:
Jul 12 12:07:29.313 YEKT: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectingNumber:
   type=6 redirecting_number=999
Jul 12 12:07:29.313 YEKT: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectNumber:
   type=6  Original Called Number=999, Called Number=999, Calling Number=701000105, Calling DN=-1 Calling Id=207764,
   Redirect Number=989268993633, Redirect Reason=2
Jul 12 12:07:29.313 YEKT: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jul 12 12:07:29.313 YEKT: :cc_get_feature_vsa malloc success
Jul 12 12:07:29.313 YEKT:  cc_get_feature_vsa count is 5
Jul 12 12:07:29.313 YEKT: :FEATURE_VSA attributes are: feature_name:0,feature_time:1772195920,feature_id:306541
Jul 12 12:07:29.313 YEKT: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
Jul 12 12:07:29.313 YEKT:  feature_vsa is 69A1A9A8,featname is 0
Jul 12 12:07:29.313 YEKT:  cc_get_feature_vsa count is 6
Jul 12 12:07:29.313 YEKT: :FEATURE_VSA attributes are: feature_name:0,feature_time:1772198384,feature_id:306542
Jul 12 12:07:29.313 YEKT: : Generating new featurevsa,inserting it
Jul 12 12:07:29.313 YEKT:  feature call forward featname is 3
Jul 12 12:07:29.313 YEKT:  feature_vsa is 69A17608,featname is 0
Jul 12 12:07:29.317 YEKT: :cc_get_feature_vsa malloc success
Jul 12 12:07:29.317 YEKT: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jul 12 12:07:29.317 YEKT:  cc_get_feature_vsa count is 7
Jul 12 12:07:29.317 YEKT: :FEATURE_VSA attributes are: feature_name:0,feature_time:1772200624,feature_id:306543
Jul 12 12:07:29.317 YEKT: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
Jul 12 12:07:29.317 YEKT: : Generating new featurevsa,inserting it
Jul 12 12:07:29.317 YEKT:  feature call forward featname is 3
Jul 12 12:07:29.317 YEKT: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jul 12 12:07:29.317 YEKT: :cc_free_feature_vsa freeing 69A19048
Jul 12 12:07:29.317 YEKT:  vsacount in free is 6
Jul 12 12:07:29.317 YEKT: //207765/0031A2D20B01/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=19)
   Cause Value=19, Call Entry(Responsed=TRUE, Cause Value=19)
Jul 12 12:07:29.317 YEKT: //207765/0031A2D20B01/CCAPI/cc_api_get_transfer_info:
Jul 12 12:07:29.321 YEKT: //207765/0031A2D20B01/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x7327A3B8, Tag=0x0, Call Id=207765,
   Call Entry(Disconnect Cause=19, Voice Class Cause Code=0, Retry Count=0)
Jul 12 12:07:29.321 YEKT: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jul 12 12:07:29.321 YEKT: :cc_free_feature_vsa freeing 69A1A2A8
Jul 12 12:07:29.321 YEKT:  vsacount in free is 5
Jul 12 12:07:29.321 YEKT:  vsacount in free is 4
Jul 12 12:07:29.321 YEKT: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jul 12 12:07:29.321 YEKT: :cc_get_feature_vsa malloc success
Jul 12 12:07:29.321 YEKT:  cc_get_feature_vsa count is 5
Jul 12 12:07:29.321 YEKT: :FEATURE_VSA attributes are: feature_name:0,feature_time:1772189200,feature_id:306544
Jul 12 12:07:29.321 YEKT: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
Jul 12 12:07:29.321 YEKT:  feature call forward featname is 3
Jul 12 12:07:29.321 YEKT: :cc_free_feature_vsa freeing 69A17608
Jul 12 12:07:29.325 YEKT: //207764/0031A2D20B01/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=34, Params=0x700D8354, Progress Indication=NULL(0)
Jul 12 12:07:29.325 YEKT: //207764/0031A2D20B01/CCAPI/ccCheckClipClir:
   Destination Pattern=98[0,3-9]........., Called Number=989268993633, Digit Strip=TRUE
   Guid=B1FA50B4-CB1E-11E1-B289-87E95FB69081, Outgoing Dial-peer=34
Jul 12 12:07:29.325 YEKT: //207764/0031A2D20B01/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-ani=701000105
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=989268993633
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=73
   cisco-rdn=999
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=2   fwd_final_type =0
Jul 12 12:07:29.325 YEKT: //207764/0031A2D20B01/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x68E37AFC, Interface Type=6, Destination=, Mode=0x0,
   Called Number=989268993633(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=34, Call Count On=FALSE,
Jul 12 12:07:29.325 YEKT: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jul 12 12:07:29.325 YEKT: :cc_get_feature_vsa malloc success
Jul 12 12:07:29.325 YEKT:  cc_get_feature_vsa count is 5
Jul 12 12:07:29.325 YEKT: :FEATURE_VSA attributes are: feature_name:0,feature_time:1772189200,feature_id:306545
Jul 12 12:07:29.325 YEKT: //207766/0031A2D20B01/CCAPI/ccIFCallSetupRequestPrivate:
Jul 12 12:07:29.325 YEKT: //207766/0031A2D20B01/CCAPI/ccCallSetContext:
   Context=0x700D8304
Jul 12 12:07:29.325 YEKT: //207764/0031A2D20B01/CCAPI/ccSaveDialpeerTag:
Jul 12 12:07:29.325 YEKT: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
Jul 12 12:07:29.325 YEKT:  feature call forward featname is 3
Jul 12 12:07:29.325 YEKT:  feature_vsa is 69A17608,featname is 0
Jul 12 12:07:29.325 YEKT:  cc_get_feature_vsa count is 6
Jul 12 12:07:29.325 YEKT: :FEATURE_VSA attributes are: feature_name:0,feature_time:1772200624,feature_id:306546
Jul 12 12:07:29.325 YEKT: : Generating new featurevsa,inserting it
Jul 12 12:07:29.329 YEKT: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 701000105
Jul 12 12:07:29.329 YEKT: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0x3F15 callID = 0xBE96 switch = primary-net5 interface = User
Jul 12 12:07:29.329 YEKT: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x3F15
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA9839E
                Exclusive, Channel 30
Jul 12 12:07:29.513 YEKT: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0xBF15
        Cause i = 0x8381 - Unallocated/unassigned number
Jul 12 12:07:29.513 YEKT: //207766/0031A2D20B01/CCAPI/cc_api_call_disconnected:
   Cause Value=1, Interface=0x68E37AFC, Call Id=207766
   Call Entry(Responsed=TRUE, Cause Value=1, Retry Count=0)
Jul 12 12:07:29.513 YEKT: //207764/0031A2D20B01/CCAPI/ccCallReleaseResources:
Jul 12 12:07:29.513 YEKT: //207766/0031A2D20B01/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=207766
Jul 12 12:07:29.513 YEKT: //207766/0031A2D20B01/CCAPI/ccCallDisconnect:
   Cause Value=1, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=1)
   Cause Value=1, Call Entry(Responsed=TRUE, Cause Value=1)
Jul 12 12:07:29.513 YEKT: //207766/0031A2D20B01/CCAPI/cc_api_get_transfer_info:
Jul 12 12:07:29.513 YEKT: //207766/0031A2D20B01/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x68E37AFC, Tag=0x0, Call Id=207766,
   Call Entry(Disconnect Cause=1, Voice Class Cause Code=0, Retry Count=0)
Jul 12 12:07:29.517 YEKT: //207766/0031A2D20B01/CCAPI/cc_api_call_disconnect_done:
Jul 12 12:07:29.517 YEKT: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jul 12 12:07:29.517 YEKT: :cc_free_feature_vsa freeing 69A1A2A8
Jul 12 12:07:29.517 YEKT:  vsacount in free is 5
Jul 12 12:07:29.517 YEKT:  vsacount in free is 4
Jul 12 12:07:29.517 YEKT: //207764/0031A2D20B01/CCAPI/ccCallDisconnect:
   Cause Value=1, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Jul 12 12:07:29.517 YEKT: //207764/0031A2D20B01/CCAPI/cc_api_get_transfer_info:
Jul 12 12:07:29.549 YEKT: //207764/0031A2D20B01/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0xC08D825C, Tag=0x0, Call Id=207764,
Jul 12 12:07:29.549 YEKT: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jul 12 12:07:29.549 YEKT: :cc_free_feature_vsa freeing 69A199E8
Jul 12 12:07:29.549 YEKT:  vsacount in free is 3
Debug isdn q931
Jul 12 12:32:54.857 YEKT: %IPPHONE-6-REG_ALARM: 14: Name=SEP0023049B0E66 Load= SCCP11.8-5-2S Last=UCM-closed-TCP
Jul 12 12:32:58.181 YEKT: %IPPHONE-6-REG_ALARM: Name=ATA22900406E101 Load=ATA030203SCCP051201A.zup Last=Initialized
debug isdn q931 is              ON.
P00-5900-01#
P00-5900-01#
P00-5900-01#term mon
Jul 12 12:33:06.277 YEKT: %IPPHONE-6-REG_ALARM: 24: Name=SEP0023049B0E66 Load= SCCP11.8-5-2S Last=Phone-Reg-Rej
Jul 12 12:33:06.297 YEKT: %IPPHONE-6-REG_ALARM: 14: Name=SEP0023049B0E66 Load= SCCP11.8-5-2S Last=UCM-closed-TCP
Jul 12 12:33:06.345 YEKT: %IPPHONE-6-REG_ALARM: 14: Name=SEP0023049B0E66 Load= SCCP11.8-5-2S Last=UCM-closed-TCP
P00-5900-01#
P00-5900-01#
P00-5900-01#
P00-5900-01#
P00-5900-01#
P00-5900-01#
Jul 12 12:33:17.742 YEKT: %IPPHONE-6-REG_ALARM: 24: Name=SEP0023049B0E66 Load= SCCP11.8-5-2S Last=Phone-Reg-Rej
Jul 12 12:33:17.826 YEKT: %IPPHONE-6-REG_ALARM: 14: Name=SEP0023049B0E66 Load= SCCP11.8-5-2S Last=UCM-closed-TCP
Jul 12 12:33:17.870 YEKT: %IPPHONE-6-REG_ALARM: 14: Name=SEP0023049B0E66 Load= SCCP11.8-5-2S Last=UCM-closed-TCP
Jul 12 12:33:22.814 YEKT: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 701000105
Jul 12 12:33:22.818 YEKT: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0x3F1F callID = 0xBEA0 switch = primary-net5 interface = User
Jul 12 12:33:22.818 YEKT: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x3F1F
                Standard = CCITT
        Channel ID i = 0xA9839F
                Exclusive, Channel 31
Jul 12 12:33:22.998 YEKT: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0xBF1F
VIP Super Bronze
Faith,
   cisco-ani=701000105
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=989268993633
aokanlawon Thank you for leading me in the right direction. The 9 was being dropped, that is ok since i had configured it to drop the index. Unfortunately, the translation rule that i had configured did not translate the number so i added
rule 2 /.+/ /3422205005/
voice translation-rule 4
rule 1 /^106$/ /3422205024/
voice translation-profile AONtoPOTS
translate calling 4
VIP Super Bronze
Thanks Faith for the nice rating and good luck.
620
