Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Problem with Cisco 3825 router
Hi all,
I'm using a router Cisco 3825 as a voice gateway in my network (IOS version 12.4). When I put it on it started with a ROMMON mode. I then type the command "confreg". When I type reset command the router starts and some strange characters appears on my screen and can no more access to my router.
Can someone help ?
1 REPLY
Hall of Fame Super Gold
Re: Problem with Cisco 3825 router
most likely the console serial parameters are misconfigured, use confreg again to change them to 9600 / 8N1.
108
