Problem with cisco 3905 and FAC
Information:
I have 3 phone models: 3905 (sip), 6921 (SCCP), 6941 (SCCP)
I have the following route pattern with FAC:
9.00!                                International
9.0 [2-8] X [2-7] XXXXX
9.9XXXXXXXX
9. [2-7] XXXXXX
9.10X
9080 [0-1]!                       Number 0800
Callmanager BE version -> 8.6.1.20000-1
Version of phone Fimware -> CP3905.9-2-1-0
Symptoms:
When I call to international numbers or 0800 numbers from the phone model 3905 with the FAC, it holds and there is no routing of the call. But when I disable the FAC of the route-pattern the call is established.
For the other phone models, 6921 and 6941, there is no problem if I make the call to international numbers or 0800 numbers with the FAC enable.
Thanks for your help.
Everyone's tags (3)
1 ACCEPTED SOLUTION
Hello Rob,
Thanks for the rating
Yes i open a case on TAC and they provide the CP3905.9-2-2ES1.
Leonardo Santana
c.carrion,
You could be hitting this defect: CSCty26479
Best regards,
-FMS
Anybody knows when the IOS 9.2(2)ES1 would be released? Only the cmterm-3905-qed.9-2-2-0.cop.sgn (9.2.(2)) is available and the problem continues.
I have the same problem. I have enabled debugs and apparently once the call with the application requesting the FAC, this looks like there is no exchange of digits (DTMFs)
Another issue on Cisco IP Phone 3905 in the scenario is that the clock is not OK.
Scenario:
IOS:c2900-universalk9-mz.SPA.152-4.M1.bin
Cisco Unified Communications Manager Express Version 9.1
Cisco IP Phones 3905
Firmware: CP3905.9-2-2ES1
I opened a TAC Case but the problem has not been fixed.
Jesus Morales
Mx
I forgot apply a "create profile" command in "voice register global". After that both issues was fixed.
You can download from: https://hotfile.com/dl/181450233/abafd25/3905.9-2-2ES1.zip.html
Remember that this version is not released yet and could have another Bugs not fixed.
Regards.
JM
Did you solved your issue?
I have he same problem with the FAC.
CUCM 8.6, firmware 3905.9-2-2-0 , GW c2900-universalk9-mz.SPA.151-4.M4.bin.
TIA.
Cristian
Like Fabricio said its a bug:
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?caller=pluginredirector&method=fetchBugDetails&bugId=CSCty26479
I was using the version 9-2-2-0 and FAC and CMC did not work, after i upgrade to version CP3905.9-2-2ES1 it works!
Leonardo Santana
Dear Leonardo
I have a Cisco Unified CM and not CME.
The system version: 8.6.2.20000-2
TIA.
Cristian
Hello Cristian,
Which firmware version do you use to Cisco SIP IP Phone 3905?. I have had the same problem with this kind of Phones in CME and CM but the issue disappear with the Firmware: CP3905.9-2-2ES1.
TIA
Jesus
The firmware is 3905.9-2-2-0, the latest releases for 3905.
TIA
Cristian.
I changed the T302 timer to 5000. The problem continues.
I changed the route pattern to 9.123322939100 and uncheck the Require Forced Authorization Code and the call is performed.
TIA
Cristian
Hello
Someone happens something like this?
Need help..!!...please..!!
TIA
Cristian
I implement the recommendation of adding a # at the end of the variable range but still does not work.
Helpme please.
TIA
Cristian.
Hello Cristian,
Could you download the firmware version: CP3905.9-2-2ES1. I attach the link to download.
Could you try with this version, because is newer than CP3905.9-2-2-0.
TIA
JM
Dear Jesus
I donloaded the file, it contain CP3905.9-2-2ES1.loads. The firmware for CUCM have extension .cop.sgn.
TIA
Cristian,
Re: Problem with cisco 3905 and FAC
I using the same CUCM version 8.6.2 and FAC and CMC are working with this 3905 firmware!
Leonardo,
What version of CUCM 8.6?, I´m using system version: 8.6.2.20000-2.
TIA
Regards.
Is the same version 8-6-2-20000.2
Leonardo Santana
Hall of Fame Super Red
Hi Leonardo/Cristian/JM,
I've added my +5 votes for this great help
I think the only question that remains here is where did the
CP3905.9-2-2ES1 CUCM files come from as they aren't available
for download. We know that the problem is phone firmware related
and not CUCM or CME version related.
Leonardo, did you have to get these files from TAC directly?
Cheers!
Rob
"Spend your life waiting,
for a moment that just don't come,
Well, don't waste your time waiting"
-Springsteen
Hello Rob,
Leonardo Santana
Hi Leonardo,
Thanks for this very kind follow up my friend!
Cheers!
Rob
-Springsteen
From magician hat...
This 3905.9-2-2ES1 folder ontain APP3905.9-2-2ES1.zz and CP3905.9-2-2ES1.loads files, suported CME only.
TIA
Cristian
Hello Cristian,
You need to upload both files to Cisco Unified OS Administration -> Software Upgrades -> TFTP Files Management. After that you need to restart the TFTP Service from Cisco Unified Serviciability -> Tools -> Control Center - Features Services -> Cisco Tftp. Having done that apply changes in Cisco Unified CM Administration -> Device -> Device Settings -> Device Defaults.
JM
Dear Jesus
I performed your procedure but nothing happened.
TIA
Cristian.
Hello Cristian,
You need to change CP3905.9-2-2-0 in Captura2.JPG to CP3905.9-2-2ES1. After that reset a Cisco SIP IP Phone 3905.
JM
Hello Cristian,
If you want to change the firmware of one IP Phone to test, put the CP3905.9-2-2ES1 at Phone Load Name field at the 3905 IP Phone.
When you install the firmware what was the result that appears after? Sucess?
Leonardo Santana
Hey Guys, .....Very cool, It´s working ...finally.
Thanks a lot.
Cristian
Hey Cristian,
Thanks for share the results!!! (+5)
Best Regards
Leonardo Santana
Hello Cristian,
Great news!
BR
JM
4979
