Problem with Cisco Attendant console
We Have Cisco attendant console 8.x at site .
As per user they are
" able to log into the “Attendant Console” and access the outgoing numbers located at the bottom of the screen. As far as the internal directory, it does not allow them to access due to the database connection issue. They are getting error “database not connected” on Attendant Console.
Can you please suggest solution to resolve this . Thanks
RJ
1 REPLY
Have a look at this link on page 33 and 34:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucmac/arc/CiscoTSGv8_6_x.pdf
Directory Issues
Directory will not display and C
onsole shows "Database not connected"
message
On the Attendant Console PC:
Verify that the Windows User has Full Control access to the following registry key and it’s child
objects: HKEY_LOCAL_MACHINE\Softwar
e\Arc Solutions (See, the section
“Client preferences
do not save / are not retained” section on page
4-4
which shows how the permissions can be found
and changed). (If version is older than 8.0.3 verify HKEY_LOCAL_MACHINE\Software\Borland
as w
ell)
Verify that the CUEAC Server can be pinged from the command line by IP Address and Hostname
If it cannot be reached via hostname, have this ad
ded to DNS or to the host file on the machine.
On the CUEAC Server:
Ensure that the contact database is populated:
Open a synchronization log file in C:\Program
Files\Cisco\Logging\LDAP\Log\SSLog_xxxx.txt
Check that contacts have been inserted or updated:
Voice CCIE #37771
530
