problem with CME license
If I put the command ´sh license detail cme-srst´ I receive this :
RouterVallecas#sh license detail cme-srst
Feature: cme-srst                        Period left: 5  weeks 6  days
Index: 1        Feature: cme-srst                          Version: 1.0
        License Type: EvalRightToUse
        License State: Active, In Use
            Evaluation total period: 8  weeks 4  days
            Evaluation period left: 5  weeks 6  days
            Period used: 2  weeks 4  days
            Transition date: Sep 03 2012 20:02:37
        License Count: 32/0  (In-use/Violation)
        License Priority: Low
        Store Index: 7
        Store Name: Built-In License Storage
This mean is already installed the license? because althoug says ´License State: Active, In Use´ there is only a Evaluation period of 8 w and 4 d.
When this period expire, should I keep on using the CME router?
Do I need to do anything else or is all ok?
Thanks and regards!
1 ACCEPTED SOLUTION
Blue
I Ivan,
CME / SRST licenses are honor based and hence you have to just
accept the EULA. After the 60 days of evaluation the license will change to
"right to use" for 12 years.
Ronak Patel
Rate helpful posts by clicking stars below the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Blue
I Ivan,
Ronak Patel
Ok thanks, now i see in the cme
Feature name             EULA Accepted
ipbasek9                 n/a
securityk9               yes
uck9                     n/a
datak9                   yes
gatekeeper               no
SSL_VPN                  no
ios-ips-update           no
SNASw                    no
hseck9                   n/a
cme-srst                 yes
WAAS_Express             no
UCVideo                  no
so, as you say, there is already accepted, and after 2 weeks the license will expire in 12 y.
Regards!
Blue
HI
Yes.
Basically as per me, Cisco consider 12 year as life of the product so you can use the CME/SRST till the product is alive ( i.e 12 years).
regards
Ronak patel
Hall of Fame Super Red
Hi Ivan,
+5 to Ronak for these excellent tips!
Just thought that I would add that in newer IOS's the 12 year RTU ( right to use)
license has been replaced with a "Lifetime" RTU license
http://www.cisco.com/en/US/docs/routers/access/sw_activation/SA_on_ISR.pdf
Cheers!
Rob
"Always movin' ahead and never lookin' back" - Springsteen
247
