11-06-2010 03:36 AM - edited 03-16-2019 01:46 AM
Hi All,
My CUCM version is "Version: 6.0.1.2000-3". And I am trying to install a device pack (version: cmterm-devicepack6.0.1.3129-1.cop.sgn) for supporting phone 7965. I trying installing by remote option usinf sftp. Everything is fine upto downlading the file to CUCM and it shows validaing the file, then the web page refresh back to same install options window. And if I try to access the install/upgrade opting again it shows a warning like "Warning: Another session is installing software, click Assume Control to take over the installation" and for hours. I tried to reboot the CUCM, after reboot its same old CUCM without support for 7965. Please help me...
11-07-2010 07:56 AM
If you click the assume control button you should after the validating file step see a question asking if you want to continue installing the file. If the webpage times out and you see the assume control try and click on the assume control button to continue the installation. Otherwise you can do the install from the command line with "utils system upgrade" to install the device pack.
11-07-2010 08:18 PM
Thank you for your replay. I have tried everything that you said with no success, thats why I posted this problem. But I resovled the problenm buy, istalling another version of the device pack "cmterm-devicepack6.0.1.2111-1.cop.sgn" which is also includes support for the 7965 phones but its too lower version than the one which I tried to install.
11-08-2010 02:35 PM
Cisco changed some rsa keys, the older version of cucm didn't know about them and would fail. You might be running into this. We patched to a newer 6.x and the device pack worked flawlessly.
11-08-2010 08:37 PM
thank you for your suggestion, I'll try to patch the CUCM and then 'll try to install the newest version of the device pack and let you know the result.
